Trunk Mount Intercooler MR2 T
Old 07-17-2005, 12:04 PM
lofer's Avatar
well, theres a guy in the for sale forum selling an a2w alltrac ic core and original pump(the two hardest things to get money wise and availability) for 250.00 bucks. Thats a good deal. It fits almost stock like and will perform great in the 1/4 mile , and for daily driving. You can use all the rubber hoses from your stock set up with a metal flange for your bov until you can have a custom one made .Also eliminate alot of piping.Its a very streetable setup, even better than the alltrac original setup. You run the water lines under the stock heat sheild under the car all the way to the front.Mine actually fits right in front od both the ac heat exchanger and the radiator with a 850 cfm pusher fan on it. I have the original alltrac heat exchanger wich is very big.The heat exchanger run to the front of the car is the key to setup ability to pull the hot water/antifreeze to the heat exchanger, cool the fluid , push it back to the ic while on and off boost.And for 1/4 mile runs you can implement a small resevoir to fill with ice and have below ambient intake temps. Its A night and day difference in performance when the a2w is working properly.
Old 07-18-2005, 09:24 AM
SOOFIERCE
Love Doctor's Avatar
Default Intercooler Hose
Although the A2W Intercooler sounds good, I just dont want to add anymore weight plus worry about additional hoses and stuff....
So, Im going to try simply adding better IC hoses. I found this place below:
http://www.turbohoses.com/turbokits.htm
Looks like for a couple hundred duckets I can upgrade my IC pipes and hoses. Anyone has a better angle on this? Please share.
PEACE-
Old 07-18-2005, 11:06 AM
THE HAMMER
Slash's Avatar
What it really come down to doc is if you want to go fast and not add weight or complexity then you need to go trunkmount, There is no other solution for 300whp on a Gen 2.
And Orion, you said TOP mount, and i re-quoted you to say trunk mount. which is different.
I dont feel like a sig today.
Old 07-18-2005, 12:14 PM
SOOFIERCE
Thumbs down Trunkmount
If a Trunkmount IC and a Greddy side cost about the same ($75 give or take), I rather go with the side mount.
Both of these IC should be good for my "about 300RWHP goal" correct?
So, if this is the case... I'll go for the Greddy. Besides, I just saw some pics of a few trunkmount applications and they had more bends that a question mark. = LAG
PEACE-
Old 07-18-2005, 05:12 PM
lofer's Avatar
yea the major bends are a turn off. I think the greddy or spearco will suffice for 300 rwhp just fine. Upgrade those pipes like you said and youll be in there like swim wear. Upgrading your fuel system is just as important , but I guess thats a whole other topic.I personally like the spearco better as far as the flow design and I hink there are about the same in price.Theres a local pro drag racer who is sponsered by spearco/turbonetics , you might get a better deal through him, I dont know,but cant hurt to try.
Good luck with your goal btw
Old 07-18-2005, 05:37 PM
7M 2JZ bird in pear tree
Orion ZyGarian's Avatar
I see...whats the difference? Top mount too low in the engine bay on a 3S? "Trunk" mount (should be hood...hood is over the engine and trunk is for leftovers) mean its at the top and the hood is cut for it? Or is trunk mount actually that...up in front?
ASE: Brakes
Old 07-19-2005, 05:05 PM
  #17 (permalink)
SOOFIERCE
Exclamation Trunk Mount example
Check this out:
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
Can anyone tell me where the hot air that comes out of the intercooler is suppose to go? The piping on the this probrably would cost too much and it would end up with big time LAG.
I hate LAG on BF2 and even more on a Turbo car!
PEACE-
Old 07-19-2005, 06:27 PM
  #18 (permalink)
not available
MR2driver's Avatar
You would need to cut a whole in the trunk floorboard. That thing has a nice sized core. Too bad he doesnt include the trunk lid in his auction.
OMG Orion. The MR2 has a trunk, right behind the engine bay. So when we speak of trunk mount, it is actually an intercooler mounted in the rear of the car in the trunk. The MR2 has a trunk and front compartment.
The major downside to the side mount is the surface area. The largest core you can realistically stick in there is 400 cubic inches where as the trunk you could mount a much larger intercooler. Another downside is that it's mounted in the engine bay, so it heats up easier.
For 300hp any side mount kit will do.
Old 07-20-2005, 01:33 AM
  #19 (permalink)
Thanks for the clarification
ASE: Brakes
Old 07-20-2005, 04:23 AM
  #20 (permalink)
SOOFIERCE
Exclamation Trunk Lid Included
Look again, the trunk lid is included (Well for another $ 100.00 bones). Not sure how much air you would get with those fins, but I guess you can always install a puller fan to help.
For my 300rwhp, I will stick to a side mount. I just have to find one.
NEW:
Just bought a 3" downpipe. I'm thinking about installing my parts as soon as I receive the downpipe. I now have:
1) CT20B (Never sold it)
2) SAFC II (Bought it a month ago)
3) FPG (Yeah, I didnt make it... I simply through down $ 80 bones for it)
4) 3" Downpipe (Being shipped)
I think this should be enough stuff to do my next install and dyno tune over at XAT.
The only thing is... is that I will be running the stock IC setup. What boost should I run untill I find a Greddy side mount IC? Will I need a new clutch cause of the extra power?
PEACE-
