Closed Thread
Page 2 of 21 FirstFirst 1 2 3 4 5 12 ... LastLast
Results 16 to 30 of 303
  1. #16
    MPG FTW! xxBoost Junkiexx has  hit bottom,  and can only go up! xxBoost Junkiexx has  hit bottom,  and can only go up! xxBoost Junkiexx has  hit bottom,  and can only go up! xxBoost Junkiexx has  hit bottom,  and can only go up! xxBoost Junkiexx has  hit bottom,  and can only go up! xxBoost Junkiexx has  hit bottom,  and can only go up! xxBoost Junkiexx has  hit bottom,  and can only go up! xxBoost Junkiexx has  hit bottom,  and can only go up! xxBoost Junkiexx has  hit bottom,  and can only go up! xxBoost Junkiexx has  hit bottom,  and can only go up! xxBoost Junkiexx has  hit bottom,  and can only go up! xxBoost Junkiexx's Avatar
    Join Date
    Apr 2006
    Location
    Tampa, Fl.
    Posts
    1,714
    Feedback Score
    2 (75%)
    I've got 2.5l's and 2.0l's in stock
    2.0: $1700
    2.5: $1900 - Recommended parts include ARP head studs and Cometic head gaskets.
    Gasket Set: $300
    Manny
  2. #17
    ENGAGED,WOOT WOOT!!! 1BDREX has a reputation beyond repute 1BDREX has a reputation beyond repute 1BDREX has a reputation beyond repute 1BDREX has a reputation beyond repute 1BDREX has a reputation beyond repute 1BDREX has a reputation beyond repute 1BDREX has a reputation beyond repute 1BDREX has a reputation beyond repute 1BDREX has a reputation beyond repute 1BDREX has a reputation beyond repute 1BDREX has a reputation beyond repute 1BDREX's Avatar
    Join Date
    Jan 2007
    Location
    TAMPA
    Posts
    845
    Feedback Score
    5 (100%)
    yeah, spun bearing= new block
    i spun like 3 bearings on my prelude a few years ago and it wasnt a cheap fix.a brand new H22 block cost me $2600 just for the bottom end. WRXBDBY just had his done last year too,same problem spun bearing. so he got the 2.5block. big difference.
    99 Prelude SH-slow but sooo SEXY
    04 WRX-300WHP silver bullet
    09 Si SEDAN UNDER CONSTRUCTION
  3. #18
    mech engineer stiscooby has a reputation beyond repute stiscooby has a reputation beyond repute stiscooby has a reputation beyond repute stiscooby has a reputation beyond repute stiscooby has a reputation beyond repute stiscooby has a reputation beyond repute stiscooby has a reputation beyond repute stiscooby has a reputation beyond repute stiscooby has a reputation beyond repute stiscooby has a reputation beyond repute stiscooby has a reputation beyond repute stiscooby's Avatar
    Join Date
    Aug 2005
    Location
    St. Pete
    Posts
    1,439
    Feedback Score
    5 (100%)
    wow, 75w90? dude. Who told you to put that in??? If im not mistaken, but isnt that the type of oil that goes into a tranny?
    For the oil experts, wouldnt the 75w mean that it would be tested at a cold starting temp of like 45 degrees? unlike a 5w or 10w would be around -20 to -30? so, isnt he basically putting in an oil that is just to high in starting temp and too thick? He would want a lower viscosity number (like 30 or 40, instead of 90) to help everything in the motor function with less friction with movable motor parts? I havent really studied oil enough to exactly know what it will do, but, what it sounds like is that when the temps got into the 40's around here, he cold-started the car and the oil was way to thick which had cause the motor to start and seize up.
    All in all man, you need to start saving up for a new one. If you plan on sti motor, be ready to shell out some money. Call around and start getting prices with install. Good luck man. Next time, just look at the owners manual and it will tell you which oil to use.
    -Matt
  4. #19
    frankenSTIen KanoWRX is on a distinguished road KanoWRX is on a distinguished road KanoWRX is on a distinguished road KanoWRX is on a distinguished road KanoWRX is on a distinguished road KanoWRX is on a distinguished road KanoWRX is on a distinguished road KanoWRX is on a distinguished road KanoWRX is on a distinguished road KanoWRX is on a distinguished road KanoWRX is on a distinguished road KanoWRX's Avatar
    Join Date
    Sep 2007
    Location
    Wesley Chapel
    Posts
    178
    Feedback Score
    Quote Originally Posted by 13Brotary View Post
    Dude you were running 75w-90 in your engine??? That's not exactly what is recommended...
    ...actually I ran Redline 75w90NS to be exact...and it recommended for +02 Subaru models...it's supposedly suited best according to this site...
    Redline 75w90NS Transmission Oil
    Quote Originally Posted by ryan_west06 View Post
    omfg
    it says it on the fuckin cap man, you cant be serious. 5W30
    ...I was doing research and what I found out is that 75w90NS is the best...It is even mentioned a couple of times in ClubWRX.net......maybe I should've researched my engine first......
    Quote Originally Posted by flystiguy01 View Post
    not trying to be mean man, but you really should trade/sell the WRX for whatever you can get out of it and get into a stock honda and DO NOT mod it. You pretty much just raped and murdered a good WRX motor that under normal conditions should've went another 200k.
    look forward to ATLEAST $1000 worth of work and it'll probably be much higher.
    ...well, there is this guy selling a Civic H22 Turbo for $5,200...which was 400+ to the wheel...and thats faster than my suby...but I can't buy something that slower, especially a stock civic...I'd rather die along with me suby......
    Quote Originally Posted by xxBoost Junkiexx View Post
    2.0: $1700
    Gasket Set: $300
    Manny
    ...thanks for the info man, I'll pm you if anything...
    Quote Originally Posted by 1BDREX View Post
    ...yea, I might as well get a 2.5 block...any other parts he had to buy along with it??...
    Quote Originally Posted by stiscooby View Post
    ...crap it is a tranny oil...my friends stupid dad mechanic said it was freaking fine......it'll probably be a new STi motor...or that H22 Turbo Civic...or sell/trade my suby and use the money for a down payment to get another subaru......I was misledded into putting the wrong oil and now I'm facing the consequences......I should've asked you guys but back then I didn't know about tr...
    ~Kano~
    [God Bless You]
    Bugeye Mafioso #149 from www.ClubWRX.net
    Subaru, friends included:
    http://www.youtube.com/watch?v=NeoDkny6BBg
  5. #20
    Registered User wrx_kid has a reputation beyond repute wrx_kid has a reputation beyond repute wrx_kid has a reputation beyond repute wrx_kid has a reputation beyond repute wrx_kid has a reputation beyond repute wrx_kid has a reputation beyond repute wrx_kid has a reputation beyond repute wrx_kid has a reputation beyond repute wrx_kid has a reputation beyond repute wrx_kid has a reputation beyond repute wrx_kid has a reputation beyond repute
    Join Date
    Jun 2006
    Posts
    277
    Feedback Score
    with the way your goin man you better buy a bicycle bc honestly i dont think you have to maturity to deal with a high maintenance car.. i can get a sweet hook up on sum shocks and pegs..lol hey maybe a baseball card to make a cool sound for you..it can be like your wannabe bov..
    If you have been mislead or fraudulently persuaded into buying a timeshare in the last 2 years.. I CAN HELP!!
  6. #21
    Registered User Wrxgurl06 has a reputation beyond repute Wrxgurl06 has a reputation beyond repute Wrxgurl06 has a reputation beyond repute Wrxgurl06 has a reputation beyond repute Wrxgurl06 has a reputation beyond repute Wrxgurl06 has a reputation beyond repute Wrxgurl06 has a reputation beyond repute Wrxgurl06 has a reputation beyond repute Wrxgurl06 has a reputation beyond repute Wrxgurl06 has a reputation beyond repute Wrxgurl06 has a reputation beyond repute Wrxgurl06's Avatar
    Join Date
    Apr 2006
    Location
    Brandon, FL
    Posts
    1,605
    Feedback Score
    2 (100%)
    I seriously doubt anyone on ANY forum would recommend 75w90NS for motor oil....
    Do better research next time and don't trust your friend's dad. He obviously doesn't know what he's talking about or you misunderstood him.
    Sucks you're in this situation but good luck on whatever you decide.
    -2006 Subaru WRX Limited
    -2009 Chevrolet Cobalt SS
  7. #22
    Join Date
    Sep 2007
    Location
    Wesley Chapel
    Posts
    178
    Feedback Score
    Quote Originally Posted by wrx_kid View Post
    ...just as expected from a KID...what does this have to do anything with maturity??...I was misinformed, DEAL WITH IT!...how about you buy me the bike since you think I'm better of with one......I know I asked for help, but you're definitely not helping...
    Quote Originally Posted by Wrxgurl06 View Post
    ...I know, I know...but what happened, happened...and the lesson has been learned...
    ~Kano~
    [God Bless You]
  8. #23
    Registered User 13Brotary has a reputation beyond repute 13Brotary has a reputation beyond repute 13Brotary has a reputation beyond repute 13Brotary has a reputation beyond repute 13Brotary has a reputation beyond repute 13Brotary has a reputation beyond repute 13Brotary has a reputation beyond repute 13Brotary has a reputation beyond repute 13Brotary has a reputation beyond repute 13Brotary has a reputation beyond repute 13Brotary has a reputation beyond repute
    Join Date
    Feb 2004
    Posts
    464
    Feedback Score
    Just think of it as an opportunity to jump into a STi sb and have a nice torquey motor that would make a great dd. Just for reference, how much oil were you running in your motor? And fyi, that Redline lightweight shockproof is great rear end oil.
  9. #24
    Join Date
    Sep 2007
    Location
    Wesley Chapel
    Posts
    178
    Feedback Score
    ...yes, it is an opportunity...since I have a steady job...I'm gonna get a loan...and buy an STi engine...and pay it off monthly...
    ~Kano~
    [God Bless You]
  10. #25
    Join Date
    Jan 2007
    Location
    TAMPA
    Posts
    845
    Feedback Score
    5 (100%)
    [quote=KanoWRX;4993606...yea, I might as well get a 2.5 block...any other parts he had to buy along with it??...[/quote]
    yeah u gotta get a few more parts. although it bolts right on, u still need to get more. if u running on the stock turbo u might wanna think on getting a VF39 or higher. regarding the other parts im not %100 sure, but Manny might know, if not just pm WRXBDBY and he can tell u all he got for the conversion. then u gotta think about saving some money to beef up ur tranny.
  11. #26
    WOMBAT Racing WhiteGhost2.5 has a reputation beyond repute WhiteGhost2.5 has a reputation beyond repute WhiteGhost2.5 has a reputation beyond repute WhiteGhost2.5 has a reputation beyond repute WhiteGhost2.5 has a reputation beyond repute WhiteGhost2.5 has a reputation beyond repute WhiteGhost2.5 has a reputation beyond repute WhiteGhost2.5 has a reputation beyond repute WhiteGhost2.5 has a reputation beyond repute WhiteGhost2.5 has a reputation beyond repute WhiteGhost2.5 has a reputation beyond repute WhiteGhost2.5's Avatar
    Join Date
    Sep 2003
    Location
    N.C.
    Posts
    701
    Feedback Score
    2 (100%)
    Yes!! Please use this as a lesson learned the Very hard way. If you are unsure when maintaining your subaru, you can always call up Mastro Subaru and Talk to Will, Ray, or Manny and they will point you in the right direction.
    Josh
  12. #27
    Registered User ryan_west06 has a reputation beyond repute ryan_west06 has a reputation beyond repute ryan_west06 has a reputation beyond repute ryan_west06 has a reputation beyond repute ryan_west06 has a reputation beyond repute ryan_west06 has a reputation beyond repute ryan_west06 has a reputation beyond repute ryan_west06 has a reputation beyond repute ryan_west06 has a reputation beyond repute ryan_west06 has a reputation beyond repute ryan_west06 has a reputation beyond repute
    Join Date
    Jan 2007
    Location
    Tampa
    Posts
    1,821
    Feedback Score
    1 (100%)
    Honeslty, if YOU dont know what kind of oil goes in your car you need to be on the fourms asking ppl.... US!
    I Highly doubt 75W90 would even leave your oil pan. Its a heavy oil. Did you even look at the cap and see what it says 5W30.
    Please look at your post, you responded to a reply saying redline oil was recommended.... But it says "transmission oil" MAN!....
    I hope you dont own another subaru! Untill.... you atleast find out what kind of fucking oil to use....
    Do you even know the difference between the engine and transmission?
  13. #28
    Join Date
    Apr 2006
    Location
    Tampa, Fl.
    Posts
    1,714
    Feedback Score
    2 (75%)
    Let me know if you have any questions on anything.
    Manny
  14. #29
    Registered User blackturbocivic is a jewel in the rough blackturbocivic is a jewel in the rough blackturbocivic is a jewel in the rough blackturbocivic is a jewel in the rough blackturbocivic is a jewel in the rough blackturbocivic is a jewel in the rough blackturbocivic is a jewel in the rough blackturbocivic is a jewel in the rough blackturbocivic is a jewel in the rough blackturbocivic is a jewel in the rough blackturbocivic is a jewel in the rough blackturbocivic's Avatar
    Join Date
    Feb 2007
    Posts
    555
    Feedback Score
    2 (100%)
    my husband killed my car and he swore he wasn't hitting it hard....says it blew switching from 1st to 2nd in normal speed and my car had plenty of oil and good oil pressure....been sitting in the garage for almost 2 months now....subaru engines are not cheap and its no point to just change the bearings and then of course I need a clutch...sometimes I think I should have just stuck to my honda's...blow a motor you can pickup a block for a couple of hundred anywhere...
  15. #30
    Join Date
    Sep 2007
    Location
    Wesley Chapel
    Posts
    178
    Feedback Score
    ...well I have warranty on my engine, hopefully that fixes all...
    Quote Originally Posted by WhiteGhost2.5 View Post
    Josh
    ...I sure will...I think i'm setting an appointment over at Mastros to all that needs to be done...
    Honeslty, if YOU dont know what kind of oil goes in your car you need to be on the fourms asking ppl....US!
    ...I usually research any old posts first before I ask...well you're Highly wrong, it leave my oil pan...yes, I looked at the cap today......wow, you're a high definition of a donkey's synonym...ASS......and for the record I didn't freakin change the oil...some other guy did at his house....he's the tard that doesn't know where the motor and tranny is......get it straight......
    Manny
    ...I'll pm you if anything...thanks...
    Quote Originally Posted by blackturbocivic View Post
    ...I agree...hopefully my warranty covers everything...
    ~Kano~
    [God Bless You]
Closed Thread
Thread Information
Users Browsing this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201
