Subaru Tech All We'll Drive
Grounding mod
Old Aug 5, 2005 | 11:06 AM
DubtecV2's Avatar
...in da hause!!!
Default Grounding mod
As some may know already, the factory grounds Subaru picked are very weak. This home-made kit will reinforce the grounds in the entire front part of the car and engine.
Total cost was just over $30, total build time was just over 30 minutes. For tools, you need a 10mm wrench and/or socket, a 12mm deep socket, allen wrenches for your distribution block, either some strong pliers or a hammer to connect the ring terminals, and some scissors or sire strippers. For the wires and stuff, you need about a foot and a half of speaker-quality 4ga wire, and 15-20 feet of speaker-quality 8ga wire. I got two feet of 4ga wire and twenty feet of 8ga wire to be on the safe side. I had just under a foot of 4ga wire left over, and a few feet of 8ga wire left over. You also need a 4ga into 8ga distribution block, one 4ga 1/4" ring terminal, two 8ga 1/4" ring terminals, and two 8ga 5/16" ring terminals. A few zip-ties come in handy, also.
First, disconnect the negative battery terminal, then onnect one end of the 4ga wire to the negative battery terminal via the 1/4" ring terminal, and the other end into the distribution block. Now take your 8ga wire and cut individual pieces to the appropriate length (one goes to driver side strut tower, one to driver side intake manifold, one to passenger side strut tower, and one to passenger side intake manifold).
Connect the 8ga wires to the distribution block, then route them to their locations. Connect two to the strut towers via 1/4" ring terminals, and two to the top side of the intake manifold via the 5/16" ring terminals.
Tighten everything up and zip-tie the wires in place. Done! I will say it's $30 well spent. My engine runs much smoother, idles better, and feels a little peppier. Before I made my grounding kit, then engine would stumble a little bit when the fans kicked on, now it doesn't. It would also stumble a little bit when accelerating with the a/c on, now it doesn't. Pulls smooth to redline.
Old Aug 5, 2005 | 12:27 PM
StiGuy's Avatar
4 doors & 6 on the floor
One banana for a excellent write up with excellent pics and one banana for a very clean installation. Heck it was so clean it deserves a second !
Old Aug 5, 2005 | 01:32 PM
Franklin's Avatar
Originally Posted by fadedSTi
want to do another STi?
I second this motion.
Old Aug 5, 2005 | 03:11 PM
JonLGT's Avatar
Just for decoration
I had a HKS circle earth on my car. I took it off because my volts were jumping around and not staying consistant.
Old Aug 5, 2005 | 03:28 PM
Bill's Avatar
Livin' in Seattle
Bleh. Looks like a lot of effort went into but it's not my cup o' tea. Too flashy for me and the fact that it adds to the bird's nest of tubing/wires already under the hood doesn't help when it comes time to work on it. The car runs fine without 'em right? What exactly is end-result of your hardwork? Japan produces a lot of interesting car accessories but most are equivalent to late-night infomercial merchandise.
Old Aug 5, 2005 | 09:10 PM
Alizarin's Avatar
Gravel fiend
In all honesty, Bill, you'll find argument either way. There are some people who swear by it, there are some who say they're worthless and its all in your head, and people in between both camps.
Personally, I'm willing to try it if it smooths out my idle and helps with my sensors. For only $20-30 in materials that's not a bad mod. I'm not entirely convinced it works (if it does anything at all, it seems to depend on the car), but I'm willing to spend the small amount to give it a shot.
Old Aug 5, 2005 | 09:47 PM
DubtecV2's Avatar
...in da hause!!!
Like I said, it is a $30 well spent. The car revs, idles, and driver smoother. Made me like my STi all over again!
I'd be glad to do yours, faded and Franklin. I'm kindof wishing I had gone with black wire instead of red, but it's all good. I had like 4 feet of 8ga wire left over -- I may reroute the wire to the driver side shock tower to have it down lower.
I bought everything at A&B Audio in Tarpon Springs. Fell free to shoot me an email or PM for more information.
Old Aug 5, 2005 | 09:49 PM
DubtecV2's Avatar
...in da hause!!!
Thanks
Old Aug 6, 2005 | 04:41 AM
mantra1's Avatar
Shaggin' Wagon IV
Good write up. Perhaps we can see it tonight in person at TGIF.
