Finally parted out 302. Lots of Ford 302 performance parts.
Thread TERRORIST
on
Some of you may remember this 302 motor. Well, nobody wanted it as a whole so its been parted out:
Motor:
Part descriptions and pictures are below. All parts are for a 302, bored .030 over. All prices are firm unless you plan on buying a bunch, then I'll consider a bulk discount on a case by case basis. No trades please. I accept cash, money order, check (it'll have to clear before I ship). I DO NOT use Paypal. All prices are + shipping at buyer's expense. The best way to reach me is just calling me or texting me at 813-245-0090, but PMs are checked periodically, and I'll poke my head back in the thread every once in a while.
302 Y block. .030 over. Cylinders are fine. That oil filter is new. Free to a good home.
Fuel Injector harness. $10. No pic, but its an injector harness, nothing special.
Eagle Forged 4340 Crankshaft. PN 30230005090. Zero balance. These were apparently factory .010 regrinds. I've got the main bearings it used, they're still in good shape. Markings on them read 3 05 MB212P STD. $250.
Eagle Forged 4340 Rods. Couldn't find a PN on 'em, but they're out of a 302 bored .030. Have bearings in them, still in good shape. "ARP Eagle" bolts, whatever that means. They've got Ross Pistons 302 .030 over, PN 400 39949 attached to them. The sideskirts are a little rough, but should still be usable, faces are alright - ask someone smarter than me, rings are good. $200
Edelbrock Water Pump. Only numbers I found were 893 1337. Looks like an 8840 Victor Series Very little use. $75.
Timing cover. Small chunk out of the bottom right bolt hole, does not affect performance. $15.
Tensioner Pulley. Works fine. Looks fairly new. $20.
Double Roller timing chain and gear. PN E3Ae-A3A. $25.
Zero balance Balancer. No markings to speak of (I had it repainted a while back), but IIRC its a Powerbond SFI spec. $40.
SFI Flexplate. I thought it was a JW The Wheel, but the part number and apparance matches a Performance Automatic. Anyways, 0 balance. 157 tooth. PN FLX30213. $60.
Autolite 3924 Plugs. 8 of 'em. Unused. $5.
Moroso dual sump oil pan with a Melling M68 oil pump. Have pan bolts with it too. $100 for the pair.
No name bottom-end girdle. Somewhere in its lifetime a rod must've hit it, because theres a gouge in it. I also clearanced it to work with the Moroso oil pan. Fits fine and works fine. $30.
MSD Pro Billet Distributor for fuel injected 302. PN 8455. steel gear. Used, very low miles, excellent shape. $125
3.27 gears for an 8.8. Look unused, but box said used, might have a little use on it. $50
Erson Cams pushrods. Used. 5/16, A-A ends. 6.250. http://www.american-automobile.com/E...valvetrain.pdf $30
Comp Cams chromemoly pushrods. Look new, can't be much if any use on them. 6.550, 5/16. $60
Stock replacement lifters. All look good, but used. Don't know much about them. They came out of a running 302. $20
Mystery valvesprings. I doubt they're the ones pictures on the box, but they fit heads for a 302. Buy 'em cheap, figure out what they are, save me the hassle. $20.
Power setting pump. Looks almost new. Comes with stock and aftermarket cooler as well as lines. $40.
Ice maker. Pour in water and it makes ice cubes. Cool, huh? $20.
Motor:
"They were crying when their sons left, God is wearing black. Hes gone so far to find no hope, hes never coming back. They were crying when their sons left, all young men must go. Hes come so far to find the truth hes never going home."
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Chains info
I'll take the injectors, stage 8 locks and plugs. Maybe the dizzy, cam and pan also.
I have cash and can come see you today!
Thread TERRORIST
on
Forgot to note, I've got ARP headstuds too.
That's funny, I wanted it and still want it.. Your brother was here not too long ago getting his bottle filled and I even mentioned to him I wanted it but since I hadn't heard from you I figured you had sold it..
6187 126th Ave North
Largo fl 33773
MV#72427
(727)535-6905 - Shaun
Largo fl 33773
MV#72427
fokissed
09-17-2005 06:23 PM
fokissed
08-29-2005 09:10 PM
