+ Reply to Thread
Results 1 to 5 of 5
08-04-2011 12:06 PM #1Registered User
- Join Date
- Dec 2006
- Location
- Tampa
- Posts
- 880
- Feedback Score
- 0
THE BEST SERVICE DEALS IN THE SE! Power, Maintenance, Rebuild, Drivetrain & TUNING.
S&R Performance works hard to be the busiest and most reliable Suby shop in the region. We build, service and rebuild more Suby's than anyone that we know of in the area.
We want to be sure to always be ahead of the pack to offer the very best deals and services. We've also grown and added another GREAT technician, new shop manager and a whole new system to make sure that all parts are available and allow for jobs to be turned around as quickly as possible. We've turned around full motor builds in 7 business days!
Rebuild Packages:
Got Rod Knock, Piston Ring Land Failure?
We offer various levels of rebuilds and replacement motor builds! We use CP, Manley, Wiseco, Cosworth and more to offer you the very best in build internal parts.
Goes from the way it looks above and then go goes to this....
And ends up looking like this....
Sample Service Deal:
Remove your rebuildable 2.5L Block
Machine Block (Bore, Hone, Deck)
Rebuild with CP Pistons & Manley Rods)
New OEM Oil Pump
Complete Timing Belt Kit w/ Water Pump
OEM Engine Gasket Kit
ARP Head Studs
Install Rebuild Long Block
$Starting at only $4449! Parts and Labor
No matter what you want to build towards or what kind of rebuild you need, S&R Performance is your one stop shop!
Doing your own engine install? We offer an extensive selection of drop off and pick up build options for both short and long blocks! We are your best choice for your build/rebuild, let us know what we can build for you! :disco:
08-04-2011 12:07 PM #2Registered User
- Join Date
- Dec 2006
- Location
- Tampa
- Posts
- 880
- Feedback Score
- 0
Folks, I cannot even begin to tell you how many Suby's we see at the shop that put off the timing belt service. We've seen some real disasters, unfortunately, some that have gone on to cause major damage.
We want to offer the very best deal around on a complete timing service. We want to help you avoid situations like this....
We make it looks like this...
This is just one particular bundle! We've got several options.
S&R Timing Service
Gates Racing Timing Belt (Blue Belt)
Timing Belt Tensioner
Small Idler
Water Pump w/ Gaskets
Thermostat
Installation
Coolant System Flush
$619.00
This is service that we can turn around in a few hours.
08-04-2011 01:01 PM #3HPC tuned / DRAG CARTEL
- Join Date
- Aug 2010
- Posts
- 494
- Feedback Score
- 1 (100%)
Damn those motor are weird as hell. Good to know there's ppl like you guys that know what their doing
K*Squad
08-04-2011 03:58 PM #4Registered User
- Join Date
- Dec 2006
- Location
- Tampa
- Posts
- 880
- Feedback Score
- 0
08-04-2011 03:58 PM #5Registered User
- Join Date
- Dec 2006
- Location
- Tampa
- Posts
- 880
- Feedback Score
- 0
We perform several clutch and other drive train services every single week. We've got some really great deals on some of the best performing kits in the business.
ACT HDSS Clutch Kit:
The HDSS Clutch Kit utilizes ACT's Full Face Street Disc with their HD Pressure Plate. This kit offers a moderate increase in pedal pressure with the ability to handle greater torque loads, track trips and plain our "spirited driving". We love these clutches and use quite a bit of them in our builds.
WRX
ACT HDSS
Flywheel Resurface
Torque Solution Cable Bushings
Labor
$1023.41
STi
ACT HDSS
Flywheel Resurface
Labor
$1115.01
Legacy GT
ACT HDSS Clutch Kit
Flywheel Resurface
Labor
$1023.67
Keep in mind, these are just samples, guys. We can add, subtract, change up anything you'd like!
Thread Information
Users Browsing this Thread
LinkBack URL
About LinkBacks
