+ Reply to Thread
Results 61 to 68 of 68
04-01-2011 03:34 PM #61
excited to see it ! Keep us updated !
Proven Power LLC
8602 Temple Terrace Hwy C14
Temple Terrace FL 33637
813-988-DYNO(3966)
www.ProvenPowerTampa.com
$30 DYNOJET DYNO PULLS
CHIPPING & SOCKETING/ELECTRICAL TROUBLESHOOTING/WIRING/ALARMS/AUDIO
04-21-2011 03:25 PM #62yaaa boy fuk wat u heard
- Join Date
- Nov 2009
- Posts
- 1,812
- Feedback Score
- 5 (100%)
they make 1,2 and 3 bar... some obd1 ecu's dnt get along with 3 bars.
sig by: skunkdsir
04-21-2011 03:38 PM #63
04-21-2011 03:41 PM #64
This thing was for sale On Columbus near Himes a while while back
04-21-2011 04:05 PM #65
This is bc there is 2 different GM 3 bar map sensors/part numbers. There is also a GM 2.5 bar. If you get one of the map sensors that are not preset in your software you can easily figure the scalar/offset.
1. You need minimum and maximum voltage and absolute pressures.
2. Convert the pressures to mbar.
3. Subtract the minimum and maximum voltages to find the range, then do the same for the pressures.
4. Divide the pressure range by the voltage range to calculate the scalar.
5. Multiply the minimum voltage by the scalar to calculate the offset. Note that a positive voltage gives a negative offset.
Just a little FYi
Proven Power LLC
813-988-DYNO(3966)
04-22-2011 12:25 AM #66TR Balla Donor Supreme
- Join Date
- May 2006
- Posts
- 3,278
- Feedback Score
- 8 (90%)
and THAT ^^^ right there is why i go here to get my shii worked/tuned by and will always rec them. not no half ass tuner that thinks he knows what hes doing. A+++ peeps.
04-22-2011 11:19 AM #67yaaa boy fuk wat u heard
- Join Date
- Nov 2009
- Posts
- 1,812
- Feedback Score
- 5 (100%)
04-22-2011 11:20 AM #68yaaa boy fuk wat u heard
- Join Date
- Nov 2009
- Posts
- 1,812
- Feedback Score
- 5 (100%)
i love reading these proven power threads, i learn alot here.
sig by: skunkdsir
Thread Information
Users Browsing this Thread
LinkBack URL
About LinkBacks
