+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 23
  1. #1
    GB
    GB is offline
    Great Cornholio GB has a reputation beyond repute GB has a reputation beyond repute GB has a reputation beyond repute GB has a reputation beyond repute GB has a reputation beyond repute GB has a reputation beyond repute GB has a reputation beyond repute GB has a reputation beyond repute GB has a reputation beyond repute GB has a reputation beyond repute GB has a reputation beyond repute GB's Avatar
    Join Date
    Feb 2005
    Location
    In Debt
    Posts
    1,001
    Feedback Score
    1 (100%)
    Same Car, New Powerplant Build
    Been gathering parts and waiting on the shortblock since February. Should start to go together next week.
    347 Liberator Dart Complete Shortblock
    Dart SHP Machined Block
    Scat 4340 Forged Steel 3.400 Crankshaft
    Scat 4340 Forged Steel H Beam Connecting Rods 5.400
    Probe SRS 2618 Forged Pistons (15.3cc TFS ONLY) 4.
    030
    Perfect Circle Moly File Fit Rings
    Clevite 77 H Main Bearings
    Clevite 77 H Rod Bearings
    Dart Coated Cam Bearings
    Screw in Oil Galley Plugs
    Fel Pro Rear Main Seal
    ARP Main Studs
    Freeze Plugs
    FordStrokers Custom HYD Roller Camshaft
    SA Gear Billet Timing Chain w/Torrington Bearing
    Melling Oil Pump M68
    Moroso Oil Pump Pick up 24519
    ARP Billet Oil Pumpshaft
    Fel Pro 1 Piece Pan Gasket
    Moroso 7qt Oil Pan - 20511
    Mr. Gasket Oil Pan Bolts
    Timing Chain Cover - Fox Body
    Fel Pro Timing Chain Gasket Set
    Fuel Pump Eccentric, if using a mechanical fuel pump
    Powerbond SFI 28oz Balancer 1060-SS
    ARP Balancer Bolt 150-2501
    Ford Racing 157 Tooth Billet Steel Flywheel M6375-
    A302B
    MACHINE BLOCK
    -Cylinders bored on Kwik-Way Boring Bar and Table
    -Finish honed on Sunnen SV-616 Hone with BHJ
    Aluminum Torque Plates, Fel Pro Head Gaskets and ARP
    Hardware (.0001-0002 Taper MAX)
    -Plateau Brushed (Provides Instant Ring Seal)
    -Main Bearing Bores Align Honed on a Sunnen CH-100
    Hone
    -Deck surfaced on a Winona Van Norman CBN surfacer
    (Ra Finish compatible with MLS Gaskets)
    -Screw In Oil Galley Plugs
    -Lifter Valley Oil Drain Backs Chamferred
    -Oil Filter Inlet Chaferred
    -Threaded Holes Chased
    -Lifter Bores Honed
    BALANCE
    Crankshaft Balancing done on Hines Dominator XP Digital
    Balancer - Balanced to 28oz
    BLOCK PAINTED - Cast Aluminum #1650
    Aeromotive A1000 Fuel Kit #17147
    Moser 31 Spline Axles #MSR-A883151
    Moser Axle Bearing Kit #MSR-9563
    Digital MSD6AL #6425
    Detroit Truetrac #DTL-913A561
    Ratech 8.8 Seal Kit Complete #RAT-305K
    Ford Motorsport Driveshaft Yoke #FMS-M-4841A
    PA130 Amp Altenator #PA-16196B1
    Ford Motorsport Water Pump #M-8501-C50
    Pro-M 80MM Mass Air Recalibration
    Delphi 62 lb Injectors
    Bosch O2 Sensors #13942
    Trick Flow 8.8 Differential Cover #TFS-8510500
    Dorman 620-104 Contour Electric Fan #RNB-620-104
    Flex-a-Lite Variable Speed Controller #FLX-33054
    Trick Flow 205cc CNC Head Work
    Trick Flow R Upper/Lower Intake(Black)
    Oxygen Sensor Harness-Extended #FH-026E
    Tremec TKO600 #TRE-TCET5008
    McLeod Clutch Disc 10.5x1 - 1-1/8x26 Kevlar #MCL-260970
    Throttle Body Gaskets #BBK-1572
    ARP 1/2" Head Studs #ARP154-4003
    My S-Trim will be going back on as well. Can't wait to hear it fire up. More pics to come as progress is made.Same Car, New Powerplant Build-3.jpgSame Car, New Powerplant Build-4.jpgSame Car, New Powerplant Build-2.jpgSame Car, New Powerplant Build-1.jpgSame Car, New Powerplant Build-9.jpg
    SLEEPER
  2. #2
    GB
    GB is offline
    Join Date
    Feb 2005
    Location
    In Debt
    Posts
    1,001
    Feedback Score
    1 (100%)
    Same Car, New Powerplant Build-8.jpgSame Car, New Powerplant Build-6.jpgSame Car, New Powerplant Build-7.jpgSame Car, New Powerplant Build-5.jpg
    SLEEPER
  3. #3
    I gota Cheby Zman has a reputation beyond repute Zman has a reputation beyond repute Zman has a reputation beyond repute Zman has a reputation beyond repute Zman has a reputation beyond repute Zman has a reputation beyond repute Zman has a reputation beyond repute Zman has a reputation beyond repute Zman has a reputation beyond repute Zman has a reputation beyond repute Zman has a reputation beyond repute Zman's Avatar
    Join Date
    Jul 2003
    Location
    Indian Rocks Beach
    Posts
    2,649
    Feedback Score
    23 (100%)
    ooohhh everything so shinny, looks great.
    Only 1/4 mile track I know is Gandy Bridge
  4. #4
    Registered User diamonddog has a reputation beyond repute diamonddog has a reputation beyond repute diamonddog has a reputation beyond repute diamonddog has a reputation beyond repute diamonddog has a reputation beyond repute diamonddog has a reputation beyond repute diamonddog has a reputation beyond repute diamonddog has a reputation beyond repute diamonddog has a reputation beyond repute diamonddog has a reputation beyond repute diamonddog has a reputation beyond repute
    Join Date
    Jul 2008
    Location
    Bradenton
    Posts
    216
    Feedback Score
    3 (100%)
    Beautiful build and sounds very well planned. One question .... is the S-trim temporary til an upgrade?
  5. #5
    GB
    GB is offline
    Join Date
    Feb 2005
    Location
    In Debt
    Posts
    1,001
    Feedback Score
    1 (100%)
    For now the S-trim will suffice. Just a street car, not a track car.
    SLEEPER
  6. #6
    Join Date
    Jul 2003
    Location
    Indian Rocks Beach
    Posts
    2,649
    Feedback Score
    23 (100%)
    but Im not sure if its still a sleeper when you probably will hear it coming.
  7. #7
    GB
    GB is offline
    Join Date
    Feb 2005
    Location
    In Debt
    Posts
    1,001
    Feedback Score
    1 (100%)
    Yeah, I'm going to have to come up with something else.
    SLEEPER
  8. #8
    Join Date
    Jul 2003
    Location
    Indian Rocks Beach
    Posts
    2,649
    Feedback Score
    23 (100%)
    ah just tell people its an alternator bearing starting to go
  9. #9
    GB
    GB is offline
    Join Date
    Feb 2005
    Location
    In Debt
    Posts
    1,001
    Feedback Score
    1 (100%)
    Been making some progress. Dropped in car yesterday.
    Same Car, New Powerplant Build-imag0003.jpgSame Car, New Powerplant Build-imag0004.jpgSame Car, New Powerplant Build-imag0009.jpg
    SLEEPER
  10. #10
    Bondsman GNs-r-slow has a reputation beyond repute GNs-r-slow has a reputation beyond repute GNs-r-slow has a reputation beyond repute GNs-r-slow has a reputation beyond repute GNs-r-slow has a reputation beyond repute GNs-r-slow has a reputation beyond repute GNs-r-slow has a reputation beyond repute GNs-r-slow has a reputation beyond repute GNs-r-slow has a reputation beyond repute GNs-r-slow has a reputation beyond repute GNs-r-slow has a reputation beyond repute GNs-r-slow's Avatar
    Join Date
    Oct 2005
    Location
    Brandon
    Posts
    8,017
    Feedback Score
    13 (100%)
    Edited: I see you bought an assemble SB
  11. #11
    Registered User slowmoving1 has a reputation beyond repute slowmoving1 has a reputation beyond repute slowmoving1 has a reputation beyond repute slowmoving1 has a reputation beyond repute slowmoving1 has a reputation beyond repute slowmoving1 has a reputation beyond repute slowmoving1 has a reputation beyond repute slowmoving1 has a reputation beyond repute slowmoving1 has a reputation beyond repute slowmoving1 has a reputation beyond repute slowmoving1 has a reputation beyond repute
    Join Date
    Mar 2006
    Posts
    998
    Feedback Score
    42 (100%)
    nice set up
    All American Street Car Performance<--- Facebook page link, check us out!
    6187 126th Ave North
    Largo fl 33773
    MV#72427
    (727)535-6905 - Shaun
  12. #12
    GB
    GB is offline
    Join Date
    Feb 2005
    Location
    In Debt
    Posts
    1,001
    Feedback Score
    1 (100%)
    Quote Originally Posted by GNs-r-slow View Post
    Yep
    SLEEPER
  13. #13
    Join Date
    Oct 2005
    Location
    Brandon
    Posts
    8,017
    Feedback Score
    13 (100%)
    Are you gonna break it in with the charged disconnected?
  14. #14
    Registered User Iraq&Roll has a reputation beyond repute Iraq&Roll has a reputation beyond repute Iraq&Roll has a reputation beyond repute Iraq&Roll has a reputation beyond repute Iraq&Roll has a reputation beyond repute Iraq&Roll has a reputation beyond repute Iraq&Roll has a reputation beyond repute Iraq&Roll has a reputation beyond repute Iraq&Roll has a reputation beyond repute Iraq&Roll has a reputation beyond repute Iraq&Roll has a reputation beyond repute Iraq&Roll's Avatar
    Join Date
    Aug 2007
    Location
    St Pete, Fl
    Posts
    834
    Feedback Score
    3 (100%)
    Break it in on the chassis dyno with boost! Any reason you went with a 4.030 bore and not 4.125?
    Blessed are those, who in the face of death, focus on the front site.
    - Col. Jeff Cooper
  15. #15
    GB
    GB is offline
    Join Date
    Feb 2005
    Location
    In Debt
    Posts
    1,001
    Feedback Score
    1 (100%)
    No, everything will be connected, just going to be easy on it for a little while.
    SLEEPER
Thread Information
Users Browsing this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204
