+ Reply to Thread
Page 5 of 17 FirstFirst ... 2 3 4 5 6 7 8 15 ... LastLast
Results 61 to 75 of 244
  1. #61
    Registered User Hurstmeister has a reputation beyond repute Hurstmeister has a reputation beyond repute Hurstmeister has a reputation beyond repute Hurstmeister has a reputation beyond repute Hurstmeister has a reputation beyond repute Hurstmeister has a reputation beyond repute Hurstmeister has a reputation beyond repute Hurstmeister has a reputation beyond repute Hurstmeister has a reputation beyond repute Hurstmeister has a reputation beyond repute Hurstmeister has a reputation beyond repute
    Join Date
    Mar 2008
    Location
    NPR
    Posts
    3,488
    Feedback Score
    11 (100%)
    Coming along nicely Frank.
    Hurst
    Quote Originally Posted by Tiffiny
    "We all heart the Hurst"
  2. #62
    Registered User franktf has a reputation beyond repute franktf has a reputation beyond repute franktf has a reputation beyond repute franktf has a reputation beyond repute franktf has a reputation beyond repute franktf has a reputation beyond repute franktf has a reputation beyond repute franktf has a reputation beyond repute franktf has a reputation beyond repute franktf has a reputation beyond repute franktf has a reputation beyond repute franktf's Avatar
    Join Date
    Mar 2007
    Location
    Pinellas Park, FL
    Posts
    1,273
    Feedback Score
    17 (100%)
    Thanks Hurst.....
    I stripped some more today..... Got the pass side done, did the panel on both side in front of the door pillar and started on the cowl panel..... This paint removal crap is gettin old but it's a necessary evil so it's done right..... Some good news though, I only found 2 small spot of bondo on the pass side not even as big as the ones on the driver side.....
  3. #63
    Join Date
    Mar 2007
    Location
    Pinellas Park, FL
    Posts
    1,273
    Feedback Score
    17 (100%)
    Finished the cowl after work today..... Also started working aon the engine compartment a little.....
  4. #64
    Registered User slow poke has a reputation beyond repute slow poke has a reputation beyond repute slow poke has a reputation beyond repute slow poke has a reputation beyond repute slow poke has a reputation beyond repute slow poke has a reputation beyond repute slow poke has a reputation beyond repute slow poke has a reputation beyond repute slow poke has a reputation beyond repute slow poke has a reputation beyond repute slow poke has a reputation beyond repute slow poke's Avatar
    Join Date
    Oct 2004
    Location
    pinellas park
    Posts
    1,337
    Feedback Score
    4 (100%)
    WOW frank !!!!! looks amazingly solid !!!!!
    just visiting this screwwey planet.
    woohoo, 9.84 @ 137.7 mph on a 9" slick !!!!
    Quote Originally Posted by Gooser View Post
    just cause you have a cowl hood on your Honda doesn't mean you can hang out here.
  5. #65
    Join Date
    Mar 2007
    Location
    Pinellas Park, FL
    Posts
    1,273
    Feedback Score
    17 (100%)
    Quote Originally Posted by slow poke View Post
    Doesn't seem to be bad at all for an almost 40 year old car.....
    I have been getting a bunch of stuff coming to the house(parts and supplies) that I had to get to the shop..... Got all of my POR15, some epoxy primer, new paint gun, some nice blue powder coated front upper/lower control arms and a bunch of other stuff.....
    Also stripped the rest of the firewall and the pass side tower.....
  6. #66
    Bondsman GNs-r-slow has a reputation beyond repute GNs-r-slow has a reputation beyond repute GNs-r-slow has a reputation beyond repute GNs-r-slow has a reputation beyond repute GNs-r-slow has a reputation beyond repute GNs-r-slow has a reputation beyond repute GNs-r-slow has a reputation beyond repute GNs-r-slow has a reputation beyond repute GNs-r-slow has a reputation beyond repute GNs-r-slow has a reputation beyond repute GNs-r-slow has a reputation beyond repute GNs-r-slow's Avatar
    Join Date
    Oct 2005
    Location
    Brandon
    Posts
    8,017
    Feedback Score
    13 (100%)
    Are you doing away with the shock towers?
  7. #67
    Join Date
    Mar 2007
    Location
    Pinellas Park, FL
    Posts
    1,273
    Feedback Score
    17 (100%)
    Quote Originally Posted by GNs-r-slow View Post
    Not completely, but they will be notched.....
  8. #68
    Join Date
    Mar 2007
    Location
    Pinellas Park, FL
    Posts
    1,273
    Feedback Score
    17 (100%)
    I needed to get some protection on the shell because it was starting to surface rust, specially the roof where it had surface rust before..... Plus I needed a little break from stripping paint.....
    So I cleaned every bit of old seam sealer out of the drip rail area so the rust in those areas could be treated properly..... Then I sanded the roof and pillars, cleaned all remaining paint and debis out of the window openings and trunk jam..... Next I finished prepping the rust areas for POR15 by first cleaning the surfaces with Marine Clean and then Metal Prep..... Dried everything off after rinsing and wiped it down with solvent..... Then I sprayed 2 coats of POR15 on the rust affected areas of the roof, pillars and drip rails.....
    Tomorrow I'll get some epoxy primer on the roof, pillars, trunk jam and drip rails.....
  9. #69
    I gota Cheby Zman has a reputation beyond repute Zman has a reputation beyond repute Zman has a reputation beyond repute Zman has a reputation beyond repute Zman has a reputation beyond repute Zman has a reputation beyond repute Zman has a reputation beyond repute Zman has a reputation beyond repute Zman has a reputation beyond repute Zman has a reputation beyond repute Zman has a reputation beyond repute Zman's Avatar
    Join Date
    Jul 2003
    Location
    Indian Rocks Beach
    Posts
    2,649
    Feedback Score
    23 (100%)
    ya know Frank I would send a picture to the owner and tell him your upset as you found some rust and you want your money back or a partial refund. I would love the look on his face seeing his old car apart.
    Only 1/4 mile track I know is Gandy Bridge
  10. #70
    Join Date
    Mar 2007
    Location
    Pinellas Park, FL
    Posts
    1,273
    Feedback Score
    17 (100%)
    Quote Originally Posted by Zman View Post
    He'd probably want to know why I did it, being that they did the body work and painted not to long ago(if you could call it that).....
  11. #71
    Join Date
    Mar 2007
    Location
    Pinellas Park, FL
    Posts
    1,273
    Feedback Score
    17 (100%)
    I went down this morning and sanded the top and sprayed it with the PPG DP60LF Epoxy Primer..... Everything is looking good so far..... I have a little metal replacement to do around the left tail light opening and right lower quater right behind the door jamb this week, then I can spray the rest of the quaters and rear panel with epoxy.....
  12. #72
    Join Date
    Mar 2007
    Location
    Pinellas Park, FL
    Posts
    1,273
    Feedback Score
    17 (100%)
    Haven't got anything done to the car since the weekend, but I did get some goodies from Calvert Racing..... Got some Caltrac's, Split Mono Leaf Springs and 90/10 front shocks..... Some other stuf also came but this is the fun stuff, man I wish I was closer to using it.....
  13. #73
    Join Date
    Mar 2007
    Location
    Pinellas Park, FL
    Posts
    1,273
    Feedback Score
    17 (100%)
    Did some rust repair today and got it almost ready for some more epoxy primer..... This is what I consider proper rust repair.....
    Here is the hole after I cut out the rust.....
    With the patch cut and fitted.....
    After welding and grinding.....
  14. #74
    Join Date
    Mar 2007
    Location
    Pinellas Park, FL
    Posts
    1,273
    Feedback Score
    17 (100%)
    Also repaired around the driver side tail light and rolled the lip on the rear fenderwell openings..... I also sanded everything else in prep for epoxy primer.....
    Before and after of the tail light opening.....
  15. #75
    Join Date
    Mar 2007
    Location
    Pinellas Park, FL
    Posts
    1,273
    Feedback Score
    17 (100%)
    Got the rest of it in epoxy primer this morning, and got it back on the tires again..... Now I can get back to stripping the front end, then remove the cowl for clean up.....
+ Reply to Thread
Thread Information
Users Browsing this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204
