+ Reply to Thread
Page 8 of 8 FirstFirst ... 5 6 7 8
Results 106 to 116 of 116
  1. #106
    Registered User Iraq&Roll has a reputation beyond repute Iraq&Roll has a reputation beyond repute Iraq&Roll has a reputation beyond repute Iraq&Roll has a reputation beyond repute Iraq&Roll has a reputation beyond repute Iraq&Roll has a reputation beyond repute Iraq&Roll has a reputation beyond repute Iraq&Roll has a reputation beyond repute Iraq&Roll has a reputation beyond repute Iraq&Roll has a reputation beyond repute Iraq&Roll has a reputation beyond repute Iraq&Roll's Avatar
    Join Date
    Aug 2007
    Location
    St Pete, Fl
    Posts
    834
    Feedback Score
    3 (100%)
    What is wrong with the engine in it now? If it handled the Novi, hit it with the turbo.
    Blessed are those, who in the face of death, focus on the front site.
    - Col. Jeff Cooper
  2. #107
    Registered User 500HPLX has a reputation beyond repute 500HPLX has a reputation beyond repute 500HPLX has a reputation beyond repute 500HPLX has a reputation beyond repute 500HPLX has a reputation beyond repute 500HPLX has a reputation beyond repute 500HPLX has a reputation beyond repute 500HPLX has a reputation beyond repute 500HPLX has a reputation beyond repute 500HPLX has a reputation beyond repute 500HPLX has a reputation beyond repute
    Join Date
    Apr 2009
    Posts
    638
    Feedback Score
    6 (100%)
    It is still a great engine. But it is the orginal 131K shortblock. It needs at least a rear main seal and likely oil pan gaskets, hell it still has the orginal oil pump.
    It has P heads and I doubt the turbo headers will fit them. Besides I have a set of 185's I want to run with the turbo and the stock pistons wont clear the bigger valves.
  3. #108
    Still CREEPIN Stealth Mode has a reputation beyond repute Stealth Mode has a reputation beyond repute Stealth Mode has a reputation beyond repute Stealth Mode has a reputation beyond repute Stealth Mode has a reputation beyond repute Stealth Mode has a reputation beyond repute Stealth Mode has a reputation beyond repute Stealth Mode has a reputation beyond repute Stealth Mode has a reputation beyond repute Stealth Mode has a reputation beyond repute Stealth Mode has a reputation beyond repute Stealth Mode's Avatar
    Join Date
    May 2008
    Location
    Begining Of The End
    Posts
    5,106
    Feedback Score
    27 (100%)
    Ben!!! Hurry Up!
    TurboRAM Member #5
    24psi & Stable
    GET SOME
  4. #109
    Join Date
    Apr 2009
    Posts
    638
    Feedback Score
    6 (100%)
    I'm a big wuss!
    I am waiting on it to get cooler!
    Actually work has been in overdrive and I am trying ot get all the parts together.
    I am going to start putting the 306 together soon.
    306 is SOLD!
    On with the Boss build!
  5. #110
    Join Date
    Apr 2009
    Posts
    638
    Feedback Score
    6 (100%)
    Got the rods, pistons, gaskets, studs and such. Shit adds up quick!
    Damn Mustang CRACK!
    I am mocking up the hotside on the engine stand and will get some picks up this weekend.
    Next it's off to the the machine shop with the block and rotating assembly!
  6. #111
    Bondsman GNs-r-slow has a reputation beyond repute GNs-r-slow has a reputation beyond repute GNs-r-slow has a reputation beyond repute GNs-r-slow has a reputation beyond repute GNs-r-slow has a reputation beyond repute GNs-r-slow has a reputation beyond repute GNs-r-slow has a reputation beyond repute GNs-r-slow has a reputation beyond repute GNs-r-slow has a reputation beyond repute GNs-r-slow has a reputation beyond repute GNs-r-slow has a reputation beyond repute GNs-r-slow's Avatar
    Join Date
    Oct 2005
    Location
    Brandon
    Posts
    8,017
    Feedback Score
    13 (100%)
    Quote Originally Posted by 500HPLX View Post
    Shit adds up quick!
    This is what most dont realize, its expensive to buy the good stuff. Marshall will be down to pick up the ole 306 around Christmas
  7. #112
    Join Date
    Apr 2009
    Posts
    638
    Feedback Score
    6 (100%)
    I know, I bet I droped $700 on gaskets and stud kits for the heads and mains, oil pump pick up. All Ford Racing Boss items.
  8. #113
    Join Date
    Oct 2005
    Location
    Brandon
    Posts
    8,017
    Feedback Score
    13 (100%)
    Just dropped 900 on brakes....now I need all the braided hoses and new plumping front to back
  9. #114
    Join Date
    Apr 2009
    Posts
    638
    Feedback Score
    6 (100%)
    See, it never ends!
    Aint it great!
  10. #115
    Join Date
    Apr 2009
    Posts
    638
    Feedback Score
    6 (100%)
    I am back!
    Been lurking and working my ass off.
    Have made progress in getting the new motor done. But mostly just working to keep it running and some minor upgrades.
    Internals are coming home from the machine shop this week.
    Then in goes the block for final machine work.
    Should be putting it together in mid-January at the latest.
    Still buying parts to finish up the details. Went overboard and decided to have "everything" on the new engine actually be new.
    Boy did that open up a can of worms and my wallet.
    Here is the rundowm on it so far.
    New std bore Boss 302 block
    Eagle 4340 3" stroke crank
    Eagle H beams with ARP 2000 bolt up grade
    SRP -5 cc 4" bore pistons
    King bearings
    Billet flywheel
    SFI balancer
    Netural balanced assembly
    Mains and heads studded
    MLS gaskets
    AFR 185 heads decked to 55 cc chambers P/N 1388
    10:1 compression
    I do have a new F cam, lifters and spyder assembly.
    But the decision is still out on the cam, lifters and rockers.
    I had been planning to run this with the 76mm turbo and kit I have. If so, I decided to go with a B & G hot side. But now seeing where the compression has worked out to, I may just go all out with a N/A build with a little N2O. If so, I want a put in a kick ass cam and valve train.
    Any way, away we go again!
  11. #116
    stang stroker stang stroker has a reputation beyond repute stang stroker has a reputation beyond repute stang stroker has a reputation beyond repute stang stroker has a reputation beyond repute stang stroker has a reputation beyond repute stang stroker has a reputation beyond repute stang stroker has a reputation beyond repute stang stroker has a reputation beyond repute stang stroker has a reputation beyond repute stang stroker has a reputation beyond repute stang stroker has a reputation beyond repute stang stroker's Avatar
    Join Date
    Nov 2006
    Location
    tampa
    Posts
    1,021
    Feedback Score
    14 (89%)
    nice build!!
    Pony Express Racing
    Team Lopez motorsports
    Tampa horsemen motorsports
+ Reply to Thread
Thread Information
Users Browsing this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204
