tamparican's LS Vtec build
ECU all put away and back to normal after tuning
USDM Type R Cluster in nice and snug
the 440g weighted Type R style gunmetal knob - lovin it
little side shot
how she idles after two minutes of warm up after cold-start fireup..
All Done!
little side shot
All Done!
Finally hit the Dyno today w/ Dane at Proveit Dyno in Clearwater.....Clayton with The Honda Connection stopped by w/ another one of his customers who had a nice legit full Type R swap getting dyno'ed as well..
Are you considering changing the header for maybe a Toda replica? Interested to see the numbers post dyno tune. Yeah the port matching should help you out too. Maybe a custom intake setup with a velocity stack?
Yes def down the road later on I'd like to real nice intake v/stack combo and ofc the bigger TB/IM setup...I have thought about a better header, when the time comes if the $ is there I'll pick one up...not sure how much of a gain I would see to justify spending a few hundred on a nice header though...Right now my next immediate focus will be on the suspension..
I think you would make increase your peak numbers a bit, but the header would really play a part in midrange power too. Because as we know peak numbers aren't everything. Yeah suspension is key too lol gotta be able to put that power to the ground.
