need help with choice of cams stroker gsr
AKA DICK FITSWELL
on
I'm up and down with a choice of cams.trying to get a tunes advice..The.run Down 94 gsr headsuper tech duel vssuper tech retainerssuper tech flat face valvesport to match obx itbs 94gsr bottom endDeckedBored and honed to 81.511:8.1 wisco pistons ls eagle rodsb18a1 crank blanced to 10kv2 headerswhat cams should I use?
camo krew
IM SO JDM I GOT A ASIAN GIRLFRIEND..BAHAHAH
camo krew
^ I second the opinion on the Skunk2 Pro 1's. And ditch that replica header, it will KILL your mid range. Look into the Skunk2 Alpha header, for the price, can't be beat
I advised the Alpha header because like I said, you won't find a better name brand header for the B series for $360 shipped to your door. All the companies that you mentioned are priced in another league completely.
