+ Reply to Thread
Results 1 to 4 of 4
  1. #1
    Registered User Frostdragon1 is an unknown quantity at this point
    Join Date
    Sep 2010
    Posts
    65
    Feedback Score
    need some help on a d16z6 1.6 vtec build. idle, and valve slap.
    so my stock d16z6 vtec blew a rod and i baught a fresh build d16z6 wich has the following mods. je high comp pistions egal rods gurdle aroung the pistion sleeves freshly machened head w stage 2 cam & new valve springs headders w/ o2 sensor located near the cat. it was sitting in a eg w/ obdo ecu and ran like a champ before i baught the engine. bolted it up swapped with my intake maini with all the obd1 sensors / injectors. starts right up every time. once it heats up the idle flucuated and bounces till it stalls, EXCEPT if i have the a/c switch on it will idle perfectly. second issue is that the valve train sounds horrable. it rattles really bad upon accel and deccleration. ive done a valve lash ajustment 4 times making it tighter by .001 mm every ajustment and still get the noise. thinking i might just swap with stock cam but i wanted input form you guys first. lastly i have no visable leaks yet white smoke is light/ moderate from the rear of the engine when it wasnt in the eg. maybe new head gasket? my ecu is a virgin p28, would a socket chip n tune fix my issues or is it more mecanical. i already cleaned and ajusted the TB sensors and the stock motor ran strong b4 the rod shattered. thanks for your help and knowledge.
  2. #2
    Join Date
    Sep 2010
    Posts
    65
    Feedback Score
    anyone have some advice?
  3. #3
    Registered User SolScifen has a reputation beyond repute SolScifen has a reputation beyond repute SolScifen has a reputation beyond repute SolScifen has a reputation beyond repute SolScifen has a reputation beyond repute SolScifen has a reputation beyond repute SolScifen has a reputation beyond repute SolScifen has a reputation beyond repute SolScifen has a reputation beyond repute SolScifen has a reputation beyond repute SolScifen has a reputation beyond repute SolScifen's Avatar
    Join Date
    Feb 2011
    Location
    Largo
    Posts
    304
    Feedback Score
    4 (100%)
    you need a chipped ecu and tune if its high compression. its cant adjust the a/f ratio properly probably. And for the valvetrain, look up what the company specs are for clearance. maybe you have them to tight and you hear it tapping the piston.
    Is it throwing any codes?
    2000 Prelude- Totaled
    1993 Del Sol Si- DD/Future track toy
  4. #4
    Join Date
    Sep 2010
    Posts
    65
    Feedback Score
    no codes are being showen. im going to have to take the cam out and research the company whom made it as i dont know its maker.
Thread Information
Users Browsing this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204
