+ Reply to Thread
Page 1 of 9 1 2 3 4 ... LastLast
Results 1 to 15 of 135
  1. #1
    Not harsh, just truthful Paulino has a reputation beyond repute Paulino has a reputation beyond repute Paulino has a reputation beyond repute Paulino has a reputation beyond repute Paulino has a reputation beyond repute Paulino has a reputation beyond repute Paulino has a reputation beyond repute Paulino has a reputation beyond repute Paulino has a reputation beyond repute Paulino has a reputation beyond repute Paulino has a reputation beyond repute
    Join Date
    Jul 2007
    Location
    Somewhere in Florida....
    Posts
    8,302
    Feedback Score
    52 (100%)
    Paulino's Ls/Vtec build thread!
    A few months ago I got started on this. I have an eg hatch si model painted EBP off of the 2000 Si with some silver pearl in it. Will try and get some pics of the hatch as soon as time allows. Picture I will post is with it's previous swap, still looks the same minus the special K.
    Head:
    - P72 base (GSR)
    - Ported/polished/3 angle valve job Done by USW w/ receipt
    - Ferrea Stainless Steel valves (standard spec)
    - Supertech titanium valve springs/retainers
    - Head was shaved .010"
    - NEW ARP headstuds
    - NEW Port matched AEBS intake manifold, fully polished outside casing, ported by Rogue
    - NEW Omni Power 68 mm TB
    - NEW Toda timing belt
    - NEW OEM Cam caps
    - NEW OEM RDX 410 CC injectors
    - Outlaw Engineering thermoblok spacer kit
    - 3" Intake routed to the front bumper with BPI Velocity Stack
    - Skunk2 Pro 2 + camshafts
    - Skunk2 Pro series cam gears (newer design 6 bolt)
    - Skunk2 3 O-ring Cam Seal
    - Skunk2 Alpha series header
    - Skunk2 Vtec solenoid cap
    - Skunk2 magnetic drain bolt set
    Block:
    - B18B1 base
    - 81.5 mm Usdm ITR spec pistons (P73-A0)
    - Decked/honed by United Speed World in Tampa
    - Balanced to 10k (by Proven Power w/ receipt)
    - NEW NPR Piston rings
    - NEW Main caps
    - NEW ARP Rod bolts on stock rods
    - NEW ARP Main studs
    - NEW OEM gaskets/seals used throughout build
    - NEW OEM connecting rod bearings
    - NEW OEM main bearings
    - NEW OEM thrust washers
    - NEW OEM ITR oil pump
    - NEW OEM ITR water pump
    - Align honed by United Speed World
    Misc:
    - NEW Golden Eagle LS/V kit (Bought BNIB, have receipt)
    - OEM Gsr valve cover professionally powdercoated forrest green pearl (oem teggy dark green) by Tranceologist..cleanly shaven to say "oh vtec" instead of "dohc vtec", moon cuts for fine dyno tuning
    - Killerglass upper and lower radiator hoses..Only 3 made for the states, other two are in California so this will really set this swap apart from the "usual" ls/vtec swaps
    - Exedy Stage 2 clutch/flywheel/pressure plate
    - B16 transmission
    - OBD1 gsr wiring harness (bought mint with labels, not hacked for better "vtec" )
    - Chipped P61 Ecu by Neal Sutton
    - OEM mounts
    - OEM axles
    - OEM shift linkage (Bought brand new, still in Honda packaging)
    - Skunk2 2.5" Exhaust
    - Mickey Thompson E.T. street's 225/50/15 drag radials
    - How the head was shaved and the block was decked, with all pieces put into perspective, the static compression of this motor sits at 12.4:1
    - The over boring leaves the motor at 1857 cc's.
    - Yes I could have bought many of these parts used off of here but I spared no expense. Reliability does not come cheap or easy. Absolutely no second thoughts with this work.
    - All machine shop work was done at United Speed World in Tampa.
    - Have a manila folder filled with over $1,200 in machine shop receipts alone.
    - Motor was put together with time, plastigauge and stock factory torque specs were used
    - Motor was also clayed just to make sure everything would be perfect
    - Really took my time with this, did not cut any corners
    Comments/questions are welcome! If it's negative just hit that big red/white X at the top right of the screen!
  2. #2
    Join Date
    Jul 2007
    Location
    Posts
    8,302
    Feedback Score
    52 (100%)
    42 views no comments? Jeez thanks TR!!
  3. #3
    HPC tuned / DRAG CARTEL jdm-az has a reputation beyond repute jdm-az has a reputation beyond repute jdm-az has a reputation beyond repute jdm-az has a reputation beyond repute jdm-az has a reputation beyond repute jdm-az has a reputation beyond repute jdm-az has a reputation beyond repute jdm-az has a reputation beyond repute jdm-az has a reputation beyond repute jdm-az has a reputation beyond repute jdm-az has a reputation beyond repute
    Join Date
    Aug 2010
    Posts
    494
    Feedback Score
    1 (100%)
    Nice set up man. U should post up some numbers
    K*Squad
  4. #4
    Kiss Mi Ras!!!!!! 97EJ-6 has a reputation beyond repute 97EJ-6 has a reputation beyond repute 97EJ-6 has a reputation beyond repute 97EJ-6 has a reputation beyond repute 97EJ-6 has a reputation beyond repute 97EJ-6 has a reputation beyond repute 97EJ-6 has a reputation beyond repute 97EJ-6 has a reputation beyond repute 97EJ-6 has a reputation beyond repute 97EJ-6 has a reputation beyond repute 97EJ-6 has a reputation beyond repute 97EJ-6's Avatar
    Join Date
    Apr 2008
    Location
    Where Everyone's A Thief
    Posts
    4,822
    Blog Entries
    Feedback Score
    11 (100%)
    Since you put new main caps the means you got the block line homed correct? And how is your compression higher then mine and i have ctrs instead of itrs lol
    JumpManPm me for any needs for a Honda/Acura/Evo. From tune ups to motor builds TR "Old Skool DA" Member #91Still Jokie!!!!!!!!!
  5. #5
    Join Date
    Jul 2007
    Location
    Posts
    8,302
    Feedback Score
    52 (100%)
    Quote Originally Posted by 97EJ-6 View Post
    Yessir. And did you take into account the head milling and the block decking? FUCK CTR PISTONS.
  6. #6
    Join Date
    Apr 2008
    Location
    Posts
    4,822
    Blog Entries
    Feedback Score
    11 (100%)
    Lol that raises it up soo much lol (sarcasm) fuck.you i still make more power
  7. #7
    Join Date
    Jul 2007
    Location
    Posts
    8,302
    Feedback Score
    52 (100%)
    It all flows together nice, I'm not looking to make 250 to the wheels all motor, just a fun motor for my hatch. You a trip Jordan.
  8. #8
    Registered User BABILLARACING has a reputation beyond repute BABILLARACING has a reputation beyond repute BABILLARACING has a reputation beyond repute BABILLARACING has a reputation beyond repute BABILLARACING has a reputation beyond repute BABILLARACING has a reputation beyond repute BABILLARACING has a reputation beyond repute BABILLARACING has a reputation beyond repute BABILLARACING has a reputation beyond repute BABILLARACING has a reputation beyond repute BABILLARACING has a reputation beyond repute BABILLARACING's Avatar
    Join Date
    May 2005
    Posts
    3,200
    Feedback Score
    15 (94%)
    looking good
    My shit still slow
    618 whp 492 ft/lbs at 22 psi (Low Boost)on pump gas ,
    stock block ,more power coming soon ,stay tuned
    Tuned by Alpha @ Induction Performance
  9. #9
    Join Date
    Jul 2007
    Location
    Posts
    8,302
    Feedback Score
    52 (100%)
    Quote Originally Posted by BABILLARACING View Post
    looking good
    Appreciate it Omar! The S14 ain't looking too shabby either
  10. #10
    99CivicSi Importracer13 has a reputation beyond repute Importracer13 has a reputation beyond repute Importracer13 has a reputation beyond repute Importracer13 has a reputation beyond repute Importracer13 has a reputation beyond repute Importracer13 has a reputation beyond repute Importracer13 has a reputation beyond repute Importracer13 has a reputation beyond repute Importracer13 has a reputation beyond repute Importracer13 has a reputation beyond repute Importracer13 has a reputation beyond repute Importracer13's Avatar
    Join Date
    Jan 2008
    Location
    st.pete
    Posts
    590
    Feedback Score
    9 (100%)
    thats similar to 1st lsv setup..... the bitch rode ... good luck bro
    I <3 BOOST
    EM1 Crew Member #16
  11. #11
    Join Date
    Jul 2007
    Location
    Posts
    8,302
    Feedback Score
    52 (100%)
    Quote Originally Posted by Importracer13 View Post
    Word. Appreciate the comment bro..Updates added
  12. #12
    Join Date
    Apr 2008
    Location
    Posts
    4,822
    Blog Entries
    Feedback Score
    11 (100%)
    Its definatly gonna ride
  13. #13
    Join Date
    Jul 2007
    Location
    Posts
    8,302
    Feedback Score
    52 (100%)
    Yeah with the new updates I should be damn near 220-230
  14. #14
    Join Date
    Jul 2007
    Location
    Posts
    8,302
    Feedback Score
    52 (100%)
    I'd like to hear more opinions TR!!
  15. #15
    Join Date
    Apr 2008
    Location
    Posts
    4,822
    Blog Entries
    Feedback Score
    11 (100%)
    You think so?
+ Reply to Thread
Thread Information
Users Browsing this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204
