+ Reply to Thread
Results 1 to 12 of 12
  1. #1
    You boys like Mexico!!! dohcvtec has a reputation beyond repute dohcvtec has a reputation beyond repute dohcvtec has a reputation beyond repute dohcvtec has a reputation beyond repute dohcvtec has a reputation beyond repute dohcvtec has a reputation beyond repute dohcvtec has a reputation beyond repute dohcvtec has a reputation beyond repute dohcvtec has a reputation beyond repute dohcvtec has a reputation beyond repute dohcvtec has a reputation beyond repute dohcvtec's Avatar
    Join Date
    Feb 2004
    Location
    Springhill
    Posts
    2,455
    Feedback Score
    17 (100%)
    My Built Y8 On Boost In My 91 Ef
    Well I Picked Up A EF Shell In Yampa For 300 Bucks & A Complete Y8 Motor Swap From A Buddy Outta His 98 EK For $500 Bucks....The Car As I Speak Is Getting Painted Type R White With Blue Rims On Slick..But Ima Have Pics Posted As I Go Along With The Build...The List As Followed Tells You Whats Being Done To The Car...Im Shooting For 400+ Whp & Wld Be Happy With Some 10 second Passes...Rep Will Be Returned As Recieved..Thanks For Lookin
    98 D16y8
    Vitera 75mm Pistons & Rings
    Eagle H Beam Rods
    Supertech Block Guard
    Supertech Valve Springs & Retainers
    Ferrea Valves
    Im Stuck On What Cam To Order Tho?????!!!!?????
    Skunk2 Intake Mani & Throttle Body
    LSD (Which I Got For A Killer Deal)
    4 Puck Clutch W/ 7.5lb Fly Wheel & Pressure Plate
    Hasport Mounts
    Hasport Cable To Hydrolic Clutch Conversion
    28x10x15 Slicks For The Front
    8 Point Roll Cage
    Chipped p28 Ecu (Dnt Know Which Program To Run)
    T/3 T/4 .62 Trim Turbo For 20 Pounds
    FMIC & Piping
    Turbo Timer & Boost Control
    External Waste Gate & Down Pipe Out Driver Side Of The Bumper
    Complete Gasket Kit With Water Pump & Timing Belt
    Im Sure Theres More To List Is Jus My Mine Is So Blank From This Damn Project I Need A Break..Hes Some Pics I Got Before Paint & No Motor Build Pics Yet
    My Built Y8 On Boost In My 91 Ef-223629_174210692649078_100001804457748_410436_7465575_n.jpg
    My Built Y8 On Boost In My 91 Ef-254655_174211499315664_100001804457748_410438_6032496_s.jpg
    My Built Y8 On Boost In My 91 Ef-283862_174211599315654_100001804457748_410439_1388027_s.jpg
    Springhill
    22" Nothing less
  2. #2
    Join Date
    Feb 2004
    Location
    Springhill
    Posts
    2,455
    Feedback Score
    17 (100%)
    How do i post pics!!!????!!!!????
    Springhill
    22" Nothing less
  3. #3
    I © my Honda xSWAG has a reputation beyond repute xSWAG has a reputation beyond repute xSWAG has a reputation beyond repute xSWAG has a reputation beyond repute xSWAG has a reputation beyond repute xSWAG has a reputation beyond repute xSWAG has a reputation beyond repute xSWAG has a reputation beyond repute xSWAG has a reputation beyond repute xSWAG has a reputation beyond repute xSWAG has a reputation beyond repute
    Join Date
    Dec 2009
    Location
    Spring Hill, FL
    Posts
    553
    Feedback Score
    1 (100%)
    go on photbucket, upload your pics then copy & paste the IMG Code in the post bro
    Mugen Power .
  4. #4
    Registered User Sol Flavor is an unknown quantity at this point
    Join Date
    Apr 2011
    Posts
    245
    Feedback Score
    2 (100%)
    hey man, your build is almost the same as mine. I just need my Hondata S300 and clutch and flywheel. As far as which cam to use I went with the Zex Comp 59300. Due to its all around gains and improved Mid range cause its still my DD, not because of its peak power. This article tests some major cams against each other and there dyno charts and numbers compared to the stock Z6 cam. Hope it helps.
    LS14: D16 Sohc Vtec Camshafts Bump & Grind
  5. #5
    Join Date
    Feb 2004
    Location
    Springhill
    Posts
    2,455
    Feedback Score
    17 (100%)
    Hell Yeah I Was Also Leaning Towards A ZEX....But I Got My LSD The Other Day In The Mail But I Also Got It For A Killer Price...The Motors all Torn Dwn So ITLL Be Done This Month Or End Of Sept
    My Built Y8 On Boost In My 91 Ef-205826_177464135657067_100001804457748_420510_1889728_s.jpg
    My Built Y8 On Boost In My 91 Ef-216782_177464062323741_100001804457748_420509_6358568_n.jpg
    Springhill
    22" Nothing less
  6. #6
    TR Balla Donor Supreme poorboy44 has a reputation beyond repute poorboy44 has a reputation beyond repute poorboy44 has a reputation beyond repute poorboy44 has a reputation beyond repute poorboy44 has a reputation beyond repute poorboy44 has a reputation beyond repute poorboy44 has a reputation beyond repute poorboy44 has a reputation beyond repute poorboy44 has a reputation beyond repute poorboy44 has a reputation beyond repute poorboy44 has a reputation beyond repute poorboy44's Avatar
    Join Date
    May 2004
    Posts
    2,425
    Feedback Score
    21 (100%)
    good luck with your build and goals... but just a little bit of helpful advice, those 28 inch slicks are way too big for what you're doing... they will actually hurt your times and slow you down... look into a good set of 24.5's or maybe even some 23's depending on what kinda power you end up making..
    http://www.inductionperformance.com/
    R.I.P
    Kevin "Slo_Si" Gonzalez
    6/21/86-9/13/06
    Pablo Garcia
    9/28/85-9/05/07
    You will be missed and remembered forever!!!!
  7. #7
    Join Date
    Feb 2004
    Location
    Springhill
    Posts
    2,455
    Feedback Score
    17 (100%)
    Quote Originally Posted by poorboy44 View Post
    Yeah I Never Was Able To Have A Honda Where I Needed Slicks But Ill Deff Take That Advice....Whats The Best Place For Pricing To Get Slicks?
    Springhill
    22" Nothing less
  8. #8
    swappin & tuckin bays JDMjunkie has a reputation beyond repute JDMjunkie has a reputation beyond repute JDMjunkie has a reputation beyond repute JDMjunkie has a reputation beyond repute JDMjunkie has a reputation beyond repute JDMjunkie has a reputation beyond repute JDMjunkie has a reputation beyond repute JDMjunkie has a reputation beyond repute JDMjunkie has a reputation beyond repute JDMjunkie has a reputation beyond repute JDMjunkie has a reputation beyond repute JDMjunkie's Avatar
    Join Date
    Jul 2005
    Location
    Glock.40
    Posts
    7,054
    Feedback Score
    51 (100%)
    28's are huge bro i think 23x9x13's would be ideal depending on power you make... maybe some 22x9's can maybe doing it
    I HATE FLAKER'S CREW MEMBER #1
  9. #9
    TR Balla Donor Supreme Sno Wyte has a reputation beyond repute Sno Wyte has a reputation beyond repute Sno Wyte has a reputation beyond repute Sno Wyte has a reputation beyond repute Sno Wyte has a reputation beyond repute Sno Wyte has a reputation beyond repute Sno Wyte has a reputation beyond repute Sno Wyte has a reputation beyond repute Sno Wyte has a reputation beyond repute Sno Wyte has a reputation beyond repute Sno Wyte has a reputation beyond repute Sno Wyte's Avatar
    Join Date
    Mar 2008
    Location
    The Swamp
    Posts
    2,330
    Feedback Score
    looks like its going to be a good build
  10. #10
    Join Date
    Feb 2004
    Location
    Springhill
    Posts
    2,455
    Feedback Score
    17 (100%)
    ******UPDATE*****
    ype r
    So The Blocks Fully Built & The Head As Well With A Bisimoto 2.4 Turbo Cam I Finally Went With...The Cars Fully Painted & The Roll Cage Is Being Welded Today....I Still Got The 15 Gallon Fuel Cell & The Type R Seats With 5 Point Harness, Also Its Getting Full Carpet To Cover The Roll Cage Plates With The Welds But The Cars Fully Painted & Looking Great..Im Stuck On Finding Any 4x100 Lug Rims That Are 14 or 15x10 To Fit A Wide Enough Slick So IF ANYONE KNOWS WHERE TO GET A SET OF 2 DRAG RIMS CAPIABLE OF FITTING A 10INCH SLCIK OR WIDER PLS LMK ASAP????!!!????..Other Then That Im Waiting For A Couple More Parts Thinking OF Going With ThE Water/methanol Kit & Need Someone To Make Me A Custom Manifold For My Turbo & Down Pipe So If Anyone Cld Lmk Who Cld Do This Pls Lmk Also...Other Then That My Gator Axles Are Looking Sexy I Got A Big Brake Set Up Going On Along With Full New Suspension ,Bushings Tie Rods......Im Planning On 500whp Or Close To That Now...The EMS Is An Aem Ems But Was Wondering If 1000cc Injectors Wld Be Too Big For What Im Wanting....Im Trying To Find Someone To Put My Lsd In My Tranny But Yet To Do So..Long Story Short Its In The Process & Needs Some More Work...9k Into everything minus some labor This Better Be Worth It
    Springhill
    22" Nothing less
  11. #11
    Join Date
    Apr 2011
    Posts
    245
    Feedback Score
    2 (100%)
    Sounds good so Far! I had to make changes to my SOHC plans due to I just noticed that I have some minor imperfections on the cylinder walls that i can feel with my fingernails. I was at the stock 75mm with vitaras, but since i am going to 75.5mm I am going with a higher compression piston (SRP 10.3:1) with a cometic .054 head gasket to drop it to 10:1 so I wont had to boost it so much. I am aiming for the 300 HP range tho.
  12. #12
    Join Date
    Feb 2004
    Location
    Springhill
    Posts
    2,455
    Feedback Score
    17 (100%)
    So I Decided Ima Go A Little Further Yes I Know Its A Dseries But Itll Be A Mind Doubter
    Aem Engine Management
    aem coil and pencil pack
    Super Damper
    water/menthol kit
    moroso oil pan
    1000+cc injectors
    bisimoto intake manifold
    im sure theres more but im so lost in space i go to bed thinking of this build wake up to this build and do nothing but researc and work on this build but im sure ill be posting pics and vids of the updates...friday the lsd gets put in thanks to some help on tr so thanks for looking at my build and ill take any info someones got for me
    b
    Springhill
    22" Nothing less
Thread Information
Users Browsing this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204
