+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 28
  1. #1
    aka The Twanksta! Presidential_Detail has a reputation beyond repute Presidential_Detail has a reputation beyond repute Presidential_Detail has a reputation beyond repute Presidential_Detail has a reputation beyond repute Presidential_Detail has a reputation beyond repute Presidential_Detail has a reputation beyond repute Presidential_Detail has a reputation beyond repute Presidential_Detail has a reputation beyond repute Presidential_Detail has a reputation beyond repute Presidential_Detail has a reputation beyond repute Presidential_Detail has a reputation beyond repute Presidential_Detail's Avatar
    Join Date
    Oct 2004
    Location
    Greater Tampa Bay Area
    Posts
    4,262
    Feedback Score
    26 (96%)
    Presidential Detailed: Frshly painted EG, almost ruined by a hackjob.
    This customer came to me after having his civic freshly painted black, everything was done the right way, the car was completely stripped of everything including glass and seals so that no area was missed. He was then referred by his painter to a "detailer" in the same complex to perform a wetsand/buff on the car. Well, unfortunately he got a hold of the biggest hack I have ever come across. There were severe holograms, swirls, sanding marks that hadnt been completely removed and worse of all he burnt through most of the edges on a fresh paint job!!!
    He was well aware that he was getting a service that wasnt up to par once he got the car back and pulled the car into the sun only to find the car looking like a 20 year old car again. He pointed out everything to the guy and he declined any wrong doing, telling him that the swirls are normal for a fresh painted car and they will go away after a month. So he waited a month only to find they are worse and called me up to perform a 50/50 on the hood to show this guy what he was doing was completely wrong. I was able to get the hood looking like it should again and the guy claimed there was no different and trust me it was VERY different! haha! Long story short, the guy didnt even have a legitimate business and I ended up taking on the entire job. I had my work cut out for me!
    Are you ready for a nightmare? Keep in mind this cars paint is barely even a month old.
    The Hood.
    Roof.
    Rear Bumper
    The painter for some reason shot extra clear but taped off the inner portions, it looked horrible and your eye is drawn straight to the tape line. I later sanded these portions level to reduce the eye sore.
    This is a close up of the roof, if you look deeper into the paint past the circular swirls, you will see straight line scratches. These are sanding scratches that the previous guy failed to remove creating a horrible haze on the entire car.
    Here is where the real nightmare begins,
  2. #2
    Join Date
    Oct 2004
    Location
    Posts
    4,262
    Feedback Score
    26 (96%)
    Before starting the long buffing process I knew was going to be required on this car, we took out the lights, moldings and anything that was easily removable to make my job a little easier and to get a full correction all the way up to the edges.
    Side Moldings and Skirts Removed.
    The flourescents really brought out the worse of the sanding scratches, bringing them to focus.
    The 50/50 from a few weeks prior that the hackjob declined seeing a difference between what he did and what I did. He must be nuts.
  3. #3
    Join Date
    Oct 2004
    Location
    Posts
    4,262
    Feedback Score
    26 (96%)
    A quick walk around the car with halogens really lets you see how bad this thing looked in person. Once again, remember this is a BRAND NEW paint job!!
    A close up of the sanding scratches that werent fully removed.
  4. #4
    Join Date
    Oct 2004
    Location
    Posts
    4,262
    Feedback Score
    26 (96%)
    Knowing that I am going to have to cut into this thing pretty hard to get the sanding marks out I pulled out my Meguiars Red Wool Pad and began to prime it using the KBRM for fast hard cutting results. This combination is VERY aggressive and wouldnt recommend it to anyone without proper experience with a rotary.
    Part of this method is applying M105 to the pad.
    To my surprise, this method even being as aggressive as it was, totally blew away the finish left by the previous guy. I could only imagine he used rocks and a broom to polish this thing! haha! This is only the first step for me, still gets better!
    Here is the passenger door panel untouched..
    Here is the passenger fender after cutting with M105 and polishing with M205.
    Passenger Door before.
    After M105.
    After M205 with camera flash.
    rear 1/4.
    After M105
    After M205.
  5. #5
    Join Date
    Oct 2004
    Location
    Posts
    4,262
    Feedback Score
    26 (96%)
    Driver Rear 1/4.
    After M105.
    here you find the difference between my very aggressive cutting stage on the rear 1/4 next to whatever the heck this guy did.
    Driver Door After M105.
    Driver Fender Before.
    After M105.
    No more swirls, just LOTS of dust!
    Finally starting to see some depth in the paint again!
    Here is the full hood completed.
    Then moved onto the rear hatch/bumper area with a 50/50.
  6. #6
    Join Date
    Oct 2004
    Location
    Posts
    4,262
    Feedback Score
    26 (96%)
    And finally, the results youve been waiting for! These were the best sun shots I could get.
  7. #7
    Ro.
    Ro. is offline
    Ū Ro. has a reputation beyond repute Ro. has a reputation beyond repute Ro. has a reputation beyond repute Ro. has a reputation beyond repute Ro. has a reputation beyond repute Ro. has a reputation beyond repute Ro. has a reputation beyond repute Ro. has a reputation beyond repute Ro. has a reputation beyond repute Ro. has a reputation beyond repute Ro. has a reputation beyond repute Ro.'s Avatar
    Join Date
    Feb 2007
    Posts
    2,720
    Feedback Score
    7 (100%)
    Looks amazing
  8. #8
    Join Date
    Oct 2004
    Location
    Posts
    4,262
    Feedback Score
    26 (96%)
    Thanks!
  9. #9
    Registered User mrjamaica98max is an unknown quantity at this point
    Join Date
    May 2008
    Posts
    34
    Feedback Score
    u do the damn thing.
  10. #10
    Registered User labkreationz has a reputation beyond repute labkreationz has a reputation beyond repute labkreationz has a reputation beyond repute labkreationz has a reputation beyond repute labkreationz has a reputation beyond repute labkreationz has a reputation beyond repute labkreationz has a reputation beyond repute labkreationz has a reputation beyond repute labkreationz has a reputation beyond repute labkreationz has a reputation beyond repute labkreationz has a reputation beyond repute labkreationz's Avatar
    Join Date
    Apr 2006
    Location
    south tampa
    Posts
    1,907
    Feedback Score
    3 (100%)
    way to save the day!
    custom graffiti!!!
    get anything you want done in graffiti.
    i do rooms in house, inside, outside, custom canvas art. helmets. hats etc. ANYTHING!!!
    IF YOU HAVE ANY IDEAS please contact me. via
    pm or email maxprime1@hotmail.com
    also email for pics.
  11. #11
    meh SuburbanNoize has a reputation beyond repute SuburbanNoize has a reputation beyond repute SuburbanNoize has a reputation beyond repute SuburbanNoize has a reputation beyond repute SuburbanNoize has a reputation beyond repute SuburbanNoize has a reputation beyond repute SuburbanNoize has a reputation beyond repute SuburbanNoize has a reputation beyond repute SuburbanNoize has a reputation beyond repute SuburbanNoize has a reputation beyond repute SuburbanNoize has a reputation beyond repute SuburbanNoize's Avatar
    Join Date
    Aug 2007
    Location
    Pinellas
    Posts
    7,279
    Feedback Score
    19 (100%)
    Beautiful. The other guy must have been a super hack!
    TR DC CREW MEMBER #4
    B A Customs
    813.476.2785
    StricKlyMT
    727-510-6301
  12. #12
    - - - - - - - - - - - - - BtZ..AcCord has a reputation beyond repute BtZ..AcCord has a reputation beyond repute BtZ..AcCord has a reputation beyond repute BtZ..AcCord has a reputation beyond repute BtZ..AcCord has a reputation beyond repute BtZ..AcCord has a reputation beyond repute BtZ..AcCord has a reputation beyond repute BtZ..AcCord has a reputation beyond repute BtZ..AcCord has a reputation beyond repute BtZ..AcCord has a reputation beyond repute BtZ..AcCord has a reputation beyond repute BtZ..AcCord's Avatar
    Join Date
    Jan 2007
    Location
    Palm Coast
    Posts
    1,836
    Feedback Score
    5 (100%)
    wow i love black hatches....you do good work
    R.I.P Mazda Speed 3
  13. #13
    Join Date
    Oct 2004
    Location
    Posts
    4,262
    Feedback Score
    26 (96%)
    Thanks everyone for the comments!
  14. #14
    Watagatapitusberry YaNPeR has a reputation beyond repute YaNPeR has a reputation beyond repute YaNPeR has a reputation beyond repute YaNPeR has a reputation beyond repute YaNPeR has a reputation beyond repute YaNPeR has a reputation beyond repute YaNPeR has a reputation beyond repute YaNPeR has a reputation beyond repute YaNPeR has a reputation beyond repute YaNPeR has a reputation beyond repute YaNPeR has a reputation beyond repute YaNPeR's Avatar
    Join Date
    Dec 2005
    Location
    Hialeah
    Posts
    10,488
    Feedback Score
    36 (100%)
    holy crap what an improvement!
  15. #15
    Call me Daddy 93coupeEX has a reputation beyond repute 93coupeEX has a reputation beyond repute 93coupeEX has a reputation beyond repute 93coupeEX has a reputation beyond repute 93coupeEX has a reputation beyond repute 93coupeEX has a reputation beyond repute 93coupeEX has a reputation beyond repute 93coupeEX has a reputation beyond repute 93coupeEX has a reputation beyond repute 93coupeEX has a reputation beyond repute 93coupeEX has a reputation beyond repute 93coupeEX's Avatar
    Join Date
    Jul 2004
    Location
    Saint Petersburg
    Posts
    5,988
    Feedback Score
    14 (100%)
    how was the quality of the paint job? Looks damn good Good paint job + good detailer = sex
Thread Information
Users Browsing this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201
