+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 20
  1. #1
    aka The Twanksta! Presidential_Detail has a reputation beyond repute Presidential_Detail has a reputation beyond repute Presidential_Detail has a reputation beyond repute Presidential_Detail has a reputation beyond repute Presidential_Detail has a reputation beyond repute Presidential_Detail has a reputation beyond repute Presidential_Detail has a reputation beyond repute Presidential_Detail has a reputation beyond repute Presidential_Detail has a reputation beyond repute Presidential_Detail has a reputation beyond repute Presidential_Detail has a reputation beyond repute Presidential_Detail's Avatar
    Join Date
    Oct 2004
    Location
    Greater Tampa Bay Area
    Posts
    4,262
    Feedback Score
    26 (96%)
    Presidential Detailed: 1991 Acura NSX - KBM
    After a very fun weekend at Autogeeks Detail Fest, and a very informational class with Mike Phillips at the Meguiars training class it was time to get back to work on Monday morning. I had a beautiful black NSX waiting for me! I had just received my new G110 polisher earlier last week and was dying to give it a shot with the KBM and M105 and M205 as well! As with almost every other NSX I have seen, it had super soft paint so one or two passes with M105 on a 8207 Polishing Pad using the G110 on speed setting 5 with moderate pressure for the first couple passes and then lightening up for 1-2 more passes was good for full defect removal to my surprise, but who am I kidding, I used the KBM!! :chuckle:
    I have never had anything but great results using M105 no matter what method or machine I used and I was eager to try out M205. I used this with Megs 9207 Finishing Pad. It did a great job at clearing up any marring from the previous polishing step and left a pretty good finish, but I wasnt convinced it was the best finish I could get. I could pull the car into the sun, shine the halogens and there was no signs of holograms or swirls, but I noticed by using the flash on my camera the finish just seemed a bit hazy to me. This was later confirmed with one more pass using 3m Ultrafina on a 3m Finishing pad using the G110 as well, this left the finish unbelievably deep and glossy and the haziness I saw was no longer apparent. I am not by any means knocking on M205, as I believe it would be a great finishing product on maybe a little harder clear. The NSX has one of the softest clears out there, and M205 may have been just a little too aggressive to finish down completely on this particular car. Who knows, it could have been my technique being it was my first car to ever use a DA on! :waxing:
    Process:
    M105/Megs 8207 Polishing Pad KBM
    M205/Megs 9207 Finishing Pad MPM(Thats right, Mike Phillips method, a little something we learned last weekend )
    3m UF/3m UK Finishing Pad
    LSP:
    Optimum Opti-Seal left to cure overnight
    Dodo Juice Supernatural x2
    As soon as I pulled the car out it started to rain so I pulled out the EZ-UP tent and proceeded to prep the car for polishing.
    This did reveal one thing to me though, this car had a TON of wax on it as it was beading quite well.
    I ended up washing the car three times with Dawn Soap, twice before clay, and once after to ensure the surface was completely clean. The car was no longer beading at this point so I was happy.
    I removed the spare tire so that I could better access the front compartment..
    AFTER:
    The engine was cleaned up as well..
    Before:
    After:
    It was sprinkling still, which is why the airbox looks uneven, it was later touched up.
  2. #2
    Join Date
    Oct 2004
    Location
    Posts
    4,262
    Feedback Score
    26 (96%)
    The car was pretty rough after removing all the oils from the previous waxes, etc.
    I started with a test spot on the hood to see how much work this thing would need, and pleasantly it only took a few passes with M105/8207 to correct.
    I decided this area would be best to start with..
    After M105/205..the lighting makes it look worse than it really was.
    As you could see here, the finish is good, but not good enough!
    But after 3m UF, it looked MUCH better! You can notice the flash is more contained to itself.
    So now that I had my process down, I could begin my way around the car.
    Headlight Before..
    After 105/205..
    After 3m UF..
    The center of the hood..
    After 105/205..looks good right?
    My camera flash tells me otherwise, I need one of those handy brinkman lights!
    After 3m UF..
  3. #3
    Join Date
    Oct 2004
    Location
    Posts
    4,262
    Feedback Score
    26 (96%)
    I thought this area would be difficult but found it to be rather easy using the G110.
    Before..
    You can see the haze pretty good in this one..
    After 3m UF..
    Door Before..
    After M105/205..I didnt manage to get a picture after UF here.
    The rest of these I forgot to get pictures after UF..
    I also taped off all the painted moldings to make sure they were corrected as well.
  4. #4
    Join Date
    Oct 2004
    Location
    Posts
    4,262
    Feedback Score
    26 (96%)
    I removed the wing to get further access to the trunk panel..those empty Autogeek boxes sure come in handy!
    As you can see here, its had its days of hand polishing.
    After the 105/205/UF trio.
    Camera flash says its good, well see what the sun says in a bit..
    Coming to an end here, my workspace.
    Oh yeah, whats this thing called again?? :grinno:
    Polishing finally finished, letting the Opti-Seal cure overnight.
  5. #5
    Join Date
    Oct 2004
    Location
    Posts
    4,262
    Feedback Score
    26 (96%)
    Out in the beautiful FL sun!
    These pictures were taken before the final UF finishing step. Yeah, i still wasnt happy even at this point..its a weakness.
    The following pictures were taken AFTER finishing with UF.
  6. #6
    Join Date
    Oct 2004
    Location
    Posts
    4,262
    Feedback Score
    26 (96%)
    Some more..
  7. #7
    Join Date
    Oct 2004
    Location
    Posts
    4,262
    Feedback Score
    26 (96%)
    My favorite shot..
    Oh yeah, Supernatural looks nice!!!
    After the removing the dust from all the cracks/crevices and giving the car a final wash, I did a little mini photo shoot on my street.
  8. #8
    Join Date
    Oct 2004
    Location
    Posts
    4,262
    Feedback Score
    26 (96%)
  9. #9
    TR Balla Donor Supreme The_Answer has a reputation beyond repute The_Answer has a reputation beyond repute The_Answer has a reputation beyond repute The_Answer has a reputation beyond repute The_Answer has a reputation beyond repute The_Answer has a reputation beyond repute The_Answer has a reputation beyond repute The_Answer has a reputation beyond repute The_Answer has a reputation beyond repute The_Answer has a reputation beyond repute The_Answer has a reputation beyond repute The_Answer's Avatar
    Join Date
    Oct 2006
    Posts
    498
    Feedback Score
    2 (100%)
    You always do an amazing job with black cars! This car came out amazing!
  10. #10
    Call me Daddy 93coupeEX has a reputation beyond repute 93coupeEX has a reputation beyond repute 93coupeEX has a reputation beyond repute 93coupeEX has a reputation beyond repute 93coupeEX has a reputation beyond repute 93coupeEX has a reputation beyond repute 93coupeEX has a reputation beyond repute 93coupeEX has a reputation beyond repute 93coupeEX has a reputation beyond repute 93coupeEX has a reputation beyond repute 93coupeEX has a reputation beyond repute 93coupeEX's Avatar
    Join Date
    Jul 2004
    Location
    Saint Petersburg
    Posts
    5,988
    Feedback Score
    14 (100%)
    lookn good mang
  11. #11
    Join Date
    Oct 2004
    Location
    Posts
    4,262
    Feedback Score
    26 (96%)
    Thanks!
  12. #12
    /// kaluwa has disabled reputation kaluwa's Avatar
    Join Date
    May 2006
    Posts
    12,230
    Feedback Score
    18 (100%)
    Nice work as always Billy, looks great.
    Not questioning your knowledge because obviously you know what you're doing, but I'm just curious. By "dawn soap", do you mean dawn dish soap? I've always heard not to use dish soap.. Is it okay to use, or are you referring to a different "dawn soap"?
  13. #13
    Join Date
    Oct 2004
    Location
    Posts
    4,262
    Feedback Score
    26 (96%)
    Quote Originally Posted by kaluwa View Post
    I am using Dawn dish soap, I only use this for the initial wash because it does a pretty good job a stripping off any wax the car has built up. I wouldnt recommend this for your normal wash routine as it would leave your paint bare after only a couple washes. It doesnt matter for the initial wash for me because I will be spending the next 20 hours polishing the paint anyways! haha! I then do a final wash with a high quality car wash soap that is made specifically not to strip your wax. Hope that helped clear things up!
  14. #14
    Join Date
    Jul 2004
    Location
    Saint Petersburg
    Posts
    5,988
    Feedback Score
    14 (100%)
    Quote Originally Posted by Presidential_Detail View Post
    And since its harsher then car soap it does a pretty good job at removing "stains" on lighter colored cars, like those pesky brown marks from oak trees and stuff, saving you from having to bust out the "elbow grease" in the pre rinsing. I just had a lady customer the other day wondering why her 2006 white car had to be buffed, in her wash bucket? You guessed it palmolive and a mitt.
  15. #15
    Join Date
    May 2006
    Posts
    12,230
    Feedback Score
    18 (100%)
    Ahh gotcha. thanks
Thread Information
Users Browsing this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201
