Sponsored by: CARiD
garrett turbo help
Old 01-11-2011, 03:39 PM
Bred2Run
GT5.0HO_STANG's Avatar
Default garrett turbo help
I have a 94 mustang gt with a stock 302 motor....i plan on doin a single turbo custom setup producing at least 380hp
question i have is that i have a 60 trim turbo with .82ar and .60ar t3 housing. from research i have seen only t4 housings on 302 motors.
Can i take a t4 housing and and just put it on my turbo and would it produce the numbers as wanted???
any help would be appreciated
Old 01-11-2011, 05:58 PM
Eluzzionz's Avatar
yes you can swap the turbine housing...you need to figure out what trim turbine wheel you have..then find a turbine housing that will fit it..the most common is P trim however theres N and O as well..measure ur turbine wheel to figure it out..make sure to measure both the small part(exducer) and large part(major) of the turbine wheel...then compare to these to figure out which you have
T3/T4 Turbine Wheels
Old 01-13-2011, 05:17 AM
Bred2Run
i know its a pwheel so i'll measure that and see........thanks for the help
Old 01-13-2011, 06:20 AM
Eluzzionz's Avatar
if its a P trim wheel then no need to measure..just find a P trim turbine housing in the AR you desire and swap it on there..
