Sponsored by: CARiD
building a turbo car
Old 03-19-2009, 11:15 AM
sirmichaelthe3's Avatar
Red face building a turbo car
hey guys i just wanted to ask when building a turbo car what is the general hp per psi. i have seen alot of people get alot of hp with not that much boast(675 at 18psi for an example) so what would be a goal for me to shoot for for under 20 psi. is it all in the set up or is it fuel u know i'm just amazed how people r cranking out mass hp and still staying in the mid to some what high boast range.
Old 03-19-2009, 11:22 AM
Caeser's Avatar
were did u get that example from?
n its not only boost tthat gives u all that power...im surre to get those types of numbers alot of engine work was done...
build motor...than boost
start small than go big.
JDM Pikachu crew member # 2
lol caeser u have 813 posts.
gangta
Old 03-19-2009, 11:36 AM
Hey its that guy!!
Thatguysstuff's Avatar
45lbs is a good number for boost PSi...
Old 03-19-2009, 11:40 AM
Caeser's Avatar
YouTube - K20 Civic 42 psi
lol about that haha
gangta
Old 03-19-2009, 11:42 AM
tito_12a's Avatar
its not about PSI, it's about turbo size and engine size.
R.A.P.S member number #0004
Rotaries
Against
Piston
Swaps
Tampa Bay Rotary Owners ClubMember # 5
Originally Posted by Empire
a girl just got identified by an ass pic...
that seriously just happened...
Tr is great.
Old 03-19-2009, 11:46 AM
yeah the example was a made up number lol sry if it's outrages but i was just asking cause like one of u said i saw a stock k20 produce over 600 hp on stock internals so i'm just wondering wtf u know how is that possible
Old 03-19-2009, 11:54 AM
i checked out the vid so that helps a lil but y for hondas do u need so much boast for hp but like 240s supras skylines they create more power with not as much boast. is it the displacement and what does that do for an engine of those types ? and can u do the same to hondas? displacement that is.
Old 03-19-2009, 01:07 PM
Never Follow!
PROTOTYPE's Avatar
Originally Posted by tito_12a
its not about PSI, it's about turbo flow characteristics/adibiatic effeceincy and engine Volumetric effeceincy.
Fixed.
"It's not about the make or model of a vehicle, IT'S HOW YOU BUILD IT!"
-Me
2004 Tupperware Mobile- DD Duty
1987 Toyota Supra- Hardtop and a swap. (In Progress)
2007 Suzuki Hayabusa- Gone but not forgot.
Old 03-19-2009, 01:19 PM
Never Follow!
PROTOTYPE's Avatar
Generally you see those types of vehicles run bigger turbos (Which have increased flow at lower boost numbers due to shear size, etc...) so they only run lower numbers to achieve what they want. Its like comparing a Big Mitsu 16G to a Holset Hx35 (H1C)... There is none! At about 13.5 psi it can put decently flowing engines into 300's while at 24 lbs the 16G is tapping out around 325-350 hp... Simply its sure volume the turbos can move.
Before you build anything I suggest reading MAXIMUM BOOST by Corkey Bell. Very imformative! Also pick some of the Turbo gurus brains a bit. And btw the reason you see such great numbers out of K/B series is due to them being Over square (Bore is bigger then Stroke) and there head flows are awesome. Power really is in how the Engines Volumetric Effeceincy (How well engine breathes.)
-Me
Old 03-19-2009, 01:29 PM
-eats the last cookie.
power2weight's Avatar
I know motors that make 1100 rwhp on 11 psi and others that make 220 at 20. Lots of factors are involved.
"They must really feed each other to the lions down there........"
