IY How to Clean an engine
https://www.youtube.com/watch?v=MFd_p9V8l7o
Greg - Your Car Angel shows the proper way to clean an engine. An engine detail should be done carefully because you are spraying water where there are electrical connections. They get fully protected using aluminum foil. This video will walk you through the exact steps you need to take. A final dressing of Trim Shine is applied to get the professional touch.
