How To Remove swirl marks and scratches
https://www.youtube.com/watch?v=1-hr71oylIM
Chemical Guys VSS Scratch & Swirl Remover is the easy-to-use polish that creates a mirror finish in just one step. VSS cuts strong to quickly remove swirls, scratches, and defects. The advanced one-step polish finishes like a fine polish to restore lustrous shine and deep reflection. Use VSS to remove swirls and scratches from single stage, clear coat, and even ceramic finishes on any car, truck, motorcycle, or RV.
Chemical Guys VSS is formulated for fast work time using any dual-action or rotary polishing machine. VSS is water-based, body shop safe, and OEM approved, which means it will deliver great results in a fraction the time of standard 2 or 3 step polishes. For the fastest one-step scratch and swirl removal use Chemical Guys VSS Scratch & Swirl Remover!
Chemical Guys VSS Scratch & Swirl Remover is an all-in-one scratch and swirl remover that creates a mirror finish in one step. The advanced polish is formulated using diminishing abrasive technology. These innovative abrasives cut fast to quickly remove swirls, scratches, and oxidation, then finish like a fine polish to create a wet mirror finish on all painted surfaces. The innovative swirl remover restores a lustrous scratch-free finish permanently without filling in or covering up swirls, scratches, or defects.
VSS Scratch & Swirl Remover delivers a perfect finish in less time while being equally effective on single stage, ceramic finishes, and clear coat paints. The ultra-refined swirl remover is engineered to achieve the finest level of optical clarity by removing scratches, swirls, imperfections, and 2500 grit sanding marks. Use VSS Scratch & Swirl Remover for a mirror finish in one pass.
JDMslider
For Sale/WTB Nissan
11
07-24-2011 12:25 PM
luvsracin87
Nissan/Infiniti Tech
05-17-2004 05:56 AM
