+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 18
  1. #1
    Registered User DjNando has a reputation beyond repute DjNando has a reputation beyond repute DjNando has a reputation beyond repute DjNando has a reputation beyond repute DjNando has a reputation beyond repute DjNando has a reputation beyond repute DjNando has a reputation beyond repute DjNando has a reputation beyond repute DjNando has a reputation beyond repute DjNando has a reputation beyond repute DjNando has a reputation beyond repute DjNando's Avatar
    Join Date
    Aug 2007
    Posts
    505
    Feedback Score
    4 (100%)
    Question Question on mixing paint.
    I know this might be a stupid question, but i'd rather feel stupid than end up with a bad paint job after spending all the dough. Here is the thing, I have painted before using Matrix Systems paint. It was simple to mix being that I only mixed equal parts paint and reducer. The thing is now I am trying a different paint, Nason. This one requires me to do parts paint and one part reducer and 2oz. per quart of some activator.
    My question is simple, how do I know what equals 2 parts paint and 1 part reducer? Can someone give me an example using ounces?
  2. #2
    Painter Extrodionaire oldschool98 has a reputation beyond repute oldschool98 has a reputation beyond repute oldschool98 has a reputation beyond repute oldschool98 has a reputation beyond repute oldschool98 has a reputation beyond repute oldschool98 has a reputation beyond repute oldschool98 has a reputation beyond repute oldschool98 has a reputation beyond repute oldschool98 has a reputation beyond repute oldschool98 has a reputation beyond repute oldschool98 has a reputation beyond repute oldschool98's Avatar
    Join Date
    Mar 2004
    Location
    The Hill
    Posts
    1,467
    Feedback Score
    16 (100%)
    2 TO 1.. example: 24 oz. to 12 oz. If I understand you correctly- a sprayable quart would consist of approx. 20oz paint to 10 oz redicer and 2 oz activator.
  3. #3
    Join Date
    Aug 2007
    Posts
    505
    Feedback Score
    4 (100%)
    THats EXACTLY What I needed to know!!!! THANKS MAN!!!
  4. #4
    refinish artist 351coupe has a reputation beyond repute 351coupe has a reputation beyond repute 351coupe has a reputation beyond repute 351coupe has a reputation beyond repute 351coupe has a reputation beyond repute 351coupe has a reputation beyond repute 351coupe has a reputation beyond repute 351coupe has a reputation beyond repute 351coupe has a reputation beyond repute 351coupe has a reputation beyond repute 351coupe has a reputation beyond repute 351coupe's Avatar
    Join Date
    May 2003
    Location
    tampa
    Posts
    4,777
    Feedback Score
    18 (100%)
    Matrix Systems is good paint for the price.
    Visit my TR Shop Forum
    RIP Chester P.Anderson Jr.9/23/05 I love you dad,and miss you very much.
    RIP Kevin"Slo SI" 9/13/06,we will miss you homie,time heals wounds but you will never be forgotten
  5. #5
    Join Date
    Aug 2007
    Posts
    505
    Feedback Score
    4 (100%)
    Yea, I think Matrix is good stuff as well except I wanted to do a cheaper base and tried out this Dupont Nason Paint. I have used Nason clear before. THis is the first time I will use the base though.
  6. #6
    Registered User Krucial Kolors is an unknown quantity at this point
    Join Date
    Jan 2008
    Posts
    55
    Feedback Score
    new to the states is Wanda, a base from Akzo Noble. Vary easy to use for the price. Better than Matrix due to less modeling. Almost like Diamont but less inexpensive. TIA carries it
    No advertising without shop forum
    http://www.tamparacing.com/forums/tr-shop-forums/563400-how-do-i-get-my-shop-listed.html
  7. #7
    Join Date
    Mar 2004
    Location
    The Hill
    Posts
    1,467
    Feedback Score
    16 (100%)
    I use an Akzo Nobel line called U-TECH. Its lower dollar but I ve had great results. Gallon of base for around $120 and clear kits for the same.
  8. #8
    Join Date
    Aug 2007
    Posts
    505
    Feedback Score
    4 (100%)
    Is the Akzo easy to shoot as far as the CLear coat goes? Sounds like inexpesive stuff. A gallon of this Nason stuff cost me $260 for base. The clear kit from Nason is only $80.
  9. #9
    Join Date
    Mar 2004
    Location
    The Hill
    Posts
    1,467
    Feedback Score
    16 (100%)
    Nason clear is watery to me. The UTECH I use has a high and medium solids for better build.
  10. #10
    Join Date
    Aug 2007
    Posts
    505
    Feedback Score
    4 (100%)
    Yes, I have to agree. I have used Matrix clear when i had the money for it. I only had to use 1-2 coats for a solid hard layer rather than 3 coats with the Nason. But its not bado for the price. I will have to check the Akzo stuff out though.
  11. #11
    Registered User joeman2199 is an unknown quantity at this point
    Join Date
    May 2004
    Location
    tampa
    Posts
    12
    Feedback Score
    Ive seen nason used alot, but I dont like it b/c the base usually doesnt cover well b/c they use less pigment and more binder when they mix it compared to a higher end paint like dupont's chromabase. depending on the color you got 260 sounds like alot for nason
    Another thing to watch when buying basecoats is the mixture ratios. Your higher end paints are sometimes 1:1 so when you reduce it you actually get more paint to spray and it still covers well. In essense you pay more for the paint but you use less.
    As far as clears go, medium solid clears (4:1 mixture ratios) tend to be easier to spray because they have less solid content more solvent then a high solid clear that you need to push on to get it to flow out. Ive had good results with UPOL clears if im goin for price, they have a med solid 4:1 gallon kit for around $60 and a high solids 2:1 (5 ltr clear, 2.5 ltr hardner almost 2 gallons) for around $120.
    No matter who you talk to, everybody is going to give you a different opinion...
  12. #12
    Join Date
    Aug 2007
    Posts
    505
    Feedback Score
    4 (100%)
    I will keep that in mind while spraying base this time with Nason. I know that Matrix only needed 1-2 coats to cover an area pretty well. Hope I have no problem with Nason base. Now I have used Nason CLear and It is a 4:1 Ration clear. I know that everyone has there preferances. I just want to find a good reputable brand for the price for my next paint job. THanks Joe
  13. #13
    Join Date
    Mar 2004
    Location
    The Hill
    Posts
    1,467
    Feedback Score
    16 (100%)
    Utech base goes on like single stage. You can cover Zebra stripes in one heavy pass!
  14. #14
    Join Date
    Aug 2007
    Posts
    505
    Feedback Score
    4 (100%)
    NICE...lol...I will have to see were I can find that were I live. Thanks fella's!
  15. #15
    Wide Open and Sideways! importguy1208 has a reputation beyond repute importguy1208 has a reputation beyond repute importguy1208 has a reputation beyond repute importguy1208 has a reputation beyond repute importguy1208 has a reputation beyond repute importguy1208 has a reputation beyond repute importguy1208 has a reputation beyond repute importguy1208 has a reputation beyond repute importguy1208 has a reputation beyond repute importguy1208 has a reputation beyond repute importguy1208 has a reputation beyond repute
    Join Date
    Sep 2005
    Location
    Central Florida
    Posts
    2,279
    Feedback Score
    3 (100%)
    I've used Nason quite a bit and have never seen where it was a 2:1 ratio. I've always mixed it 1:1 with no problem.
    Central Florida Auto Works!!! Paint & Body Work, Fiberglass/Carbon Fiber/Kevlar, Mechanical/Fabrication/Welding Phone: (352) 274-3446 AIM: ImportGuy1208
Thread Information
Users Browsing this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204
