Forums Register TRHelp TRGarage TRader Ratings Classifieds Search Today's Posts Mark Forums Read Calendar
iTrader Mainpage
Browse All Members
FAQ Gallery Weather Log Out
Go Back   Tampa Racing > Motorsports & General Tech > Paint, Body, and Detailing
Old 11-22-2007, 10:20 PM   #1 (permalink)
Can't Take It With You...
Car: 94' EJ1
The Burg
3m0k1d has a reputation beyond repute: 85966025
Sanding Question
My car is fully painted right now but I wanna sand it down, prime it and re-paint it.... what grits would I need to start sanding?
3m0k1d is offline
Old 11-22-2007, 10:23 PM   #2 (permalink)
Car: 86 N/A 300ZX
Hudson
hudsontitans has a reputation beyond repute: 28311672
it depends... are you gunna paint it the same color? if so just just get like 1000 gritt then wetsand it then prime and paint
hudsontitans is offline
Old 11-23-2007, 12:02 AM   #3 (permalink)
Car: 94' EJ1
The Burg
I wanna paint it either Blue or Red and right now its red but the guy who owned it before me did a shitty job, its got horrible orange peel everywhere so I wanna sand it down and bondo all the lil dents then primer and paint it...
3m0k1d is offline
Old 11-23-2007, 12:09 AM   #4 (permalink)
Car: 94' EJ1
The Burg
By the way its a 94 Civic Coupe, I want either Milano Red, Nighthawk Black or Vivid Blue Pearl?
3m0k1d is offline
Old 11-23-2007, 02:06 AM   #5 (permalink)
Lethal Fabrication
Car: S10 Hardbody 64 caddy 41 chevy
Brandon
killerMikeD has a reputation beyond repute: 119260933
24 grit
j/k i would start with 180 if your going to re prime the whole car, fix your dents (strighten the metal as much as possible BEFORE YOU APPLY "bondo" Bodyfiller isnt really meant to FILL holes per say.) then prime the car, and i would HAND BLOCK SAND WITH 400-600 grit, then apply the base and clear coat. and BLOCK All of your work, esp after primering, if u DA it chances are it will suck
killerMikeD is offline
Old 11-23-2007, 02:22 AM   #6 (permalink)
Car: 94' EJ1
The Burg
ok so 180 to bare metal or factory primer?
3m0k1d is offline
Old 11-23-2007, 05:26 PM   #7 (permalink)
Lethal Fabrication
Brandon
u dont have to go to bare metal, just sand it down, past the clear and sand out any imperfections, any serious dents you should grind out to bear metal then apply filler and sand down. on bodyfiller use 80grit 1st.
Sponsored Links
