#1 (permalink) |
SWFL Turbo
Car: i have too many
Cape Coral,FL
: 159457 |
crome wheel cleaning help!!
ok so i live in NJ now, and in the winter the snow and salt build a nasty hard black gunk shit on your rims. i used mothers mag wax with the powerball but only a little came off, it seem that this shit is caked on but can come off but i dont wanna take the wheels off the truck just to clean them up. do you think brake cleaner will work or will if fuck up the chrome?? any other cleaning solutions???? please help me out! these are the same rims i have
#4 (permalink) |
Car:
Winter Haven
: 610747109 |
not sure exactly what is on there, but if it is like a tar or asphalt tar you can use a little PB Blaster and it will loosen it up an it will wipe off. I have used it on an entire car that we got roof tar on from during the Hurricanes and it didn't effect the paint at all. Not sure if that helps but worth a shot. PB blaster is like WD40 in case you haven't heard of it.
#5 (permalink) |
civic97
Car: 97 ek coupe
brandon fl
: 32592 |
go to local store and buy some wheel cleaner make shure the rims are cool not hott... dont drive for a lil so that they are cool to the touch sense u live in n.j. get a bucket of water and a terry cloth towel or somthing that is abrahsive but not like sand paper wet them a lil bit then let the wheel cleanner soak on there for about 2 min dont let it dry .........then give a lil elbow grease and rinse off repeat if needed dont by any means use acid........
only ppl that have used acid before should use it ... acid will def.. destroy ur rims if ya dont know what ur doing .... any more??? pm me V.I.P Detailing Jose Vazquez 813 220 1477 coming to an area near u Last edited by casanova1514 : 06-13-2007 at 08:51 PM. |
#7 (permalink) | |
SWFL Turbo
Cape Coral,FL
: 159457 |
Quote:
#8 (permalink) | |
SWFL Turbo
Cape Coral,FL
: 159457 |
Quote:
#9 (permalink) |
is working on something
Car: Fords
tampa
: 1958438478 |
I was referring to cleaning the wheels with acid.As long as they are chrome and not hot acid will not hurt them and will clean them better then anything out there.But if you got it done by other means,good for you.I've acided out polished aluminum too,and after there polished back out,they look like chrome.
| Sponsored Links |
