+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 24
  1. #1
    Registered User omgosh has a reputation beyond repute omgosh has a reputation beyond repute omgosh has a reputation beyond repute omgosh has a reputation beyond repute omgosh has a reputation beyond repute omgosh has a reputation beyond repute omgosh has a reputation beyond repute omgosh has a reputation beyond repute omgosh has a reputation beyond repute omgosh has a reputation beyond repute omgosh has a reputation beyond repute omgosh's Avatar
    Join Date
    Apr 2005
    Location
    Brandon
    Posts
    2,047
    Feedback Score
    7 (100%)
    I need more front travel!
    What is the easiest way to recover some front suspension travel? I just ditched a set of AGXs and springs because they couldnt keep my car off the bump stops. I swapped them for some Koni struts with 8k Eibach springs...and Im still having the same issue. So I measured the front bump travel and came up with only 1.5'' of available compression before I hit the 1/2 inch poly stop...not gonna cut it...
    The only options I can think of now are either extending the strut tube, or grinding the welds off the housing mounting bracket and scooting it up the strut a couple inches.
    I have 6 inches between the pinch welds/jack points and the ground. So I figure I could definitely use at least 4 inches of travel...any thoughts?
  2. #2
    Ek mox92 has a reputation beyond repute mox92 has a reputation beyond repute mox92 has a reputation beyond repute mox92 has a reputation beyond repute mox92 has a reputation beyond repute mox92 has a reputation beyond repute mox92 has a reputation beyond repute mox92 has a reputation beyond repute mox92 has a reputation beyond repute mox92 has a reputation beyond repute mox92 has a reputation beyond repute mox92's Avatar
    Join Date
    Jul 2008
    Posts
    771
    Feedback Score
    14 (100%)
    coils?
  3. #3
    Join Date
    Apr 2005
    Location
    Brandon
    Posts
    2,047
    Feedback Score
    7 (100%)
    had coilovers. They sucked. Too stiff, no travel.
  4. #4
    buildin' it Empire has a reputation beyond repute Empire has a reputation beyond repute Empire has a reputation beyond repute Empire has a reputation beyond repute Empire has a reputation beyond repute Empire has a reputation beyond repute Empire has a reputation beyond repute Empire has a reputation beyond repute Empire has a reputation beyond repute Empire has a reputation beyond repute Empire has a reputation beyond repute
    Join Date
    Jan 2009
    Posts
    4,177
    Feedback Score
    something else has to be dramatically wrong.
    I've driven a car with agx struts and tien springs and couldn't come close to hitting the bump stops. Well, unless I was doing 50 over a speed bump or something like that.
    what is it like with the stock suspension on it.
    why would you want 4 inches of travel anyway?
    And on the eighth day, the Lord created the turbocharger
    Kings will never fall.
    - Tim, R.I.P
    Quote Originally Posted by UserName View Post
    If you got s14 problems I feel bad for you son, I got 99 problems but my s13 ain't one.
  5. #5
    Join Date
    Apr 2005
    Location
    Brandon
    Posts
    2,047
    Feedback Score
    7 (100%)
    What else could cause that? It mainly hits on the drivers side. I never feel the passenger side bottom out unless I go over a gutter sideways, or like you said hit a speed bump at ~20mph.
    With the stock suspension, it was quite bouncy but with it so high up, I never hit the stops. I have had all sorts of spring/dampers on this thing. Stock, gr2/sleeves, godspeed coils, stock s14/lowering springs, kei office coils, AGX with springs, and now this setup....all the non-coilover setups with lowering springs have had this issue. Coilovers were fine since the ones I had featured a threaded strut body so you can keep your travel while still lowering. So that is why I figure I can use more travel. I would probably be fine with about 3 inches...because with a static height of 6 inches at the pinch welds I could still clear a 3 inch bump at full compression. Make sense?
    Also, the car has always sat about a half inch higher on the drivers side front and rear, with the springs at the same length.
    And here is a pic of the current front setup next to the last one incase it matters.
  6. #6
    Project 4Rocker blownrunner has a reputation beyond repute blownrunner has a reputation beyond repute blownrunner has a reputation beyond repute blownrunner has a reputation beyond repute blownrunner has a reputation beyond repute blownrunner has a reputation beyond repute blownrunner has a reputation beyond repute blownrunner has a reputation beyond repute blownrunner has a reputation beyond repute blownrunner has a reputation beyond repute blownrunner has a reputation beyond repute
    Join Date
    May 2009
    Location
    Tampa, FL
    Posts
    128
    Feedback Score
    Install longer springs and to have your vehicle sit up higher. Being higher is the only was to keep from hitting objects. The lower you go, the stiffer the spring rate you also need to install with it to keep the car from bottoming out all the time. One of the things that the aftermarket coilover companies sometimes don't mention. When you lower your car via an adjustable coilover, the travel is reduced and the bumpstop is closer to the top of the strut. Driving over the same bump will compress the spring the same amount, only you are lower to start with. Install stiffer springs. Better yet, go back to stock and be done with it and eliminate the guesswork.
    -My Grandma can kick your Grandma's ass into next week:
    http://www.cardomain.com/ride/2124933
    -WOW:
    http://www.youtube.com/watch?v=aSaay...1&feature=fvwp
  7. #7
    Join Date
    Apr 2005
    Location
    Brandon
    Posts
    2,047
    Feedback Score
    7 (100%)
    Thanks for the comment. Ive got it covered though. Telling someone to go back to stock suspension is just silly. lol. The main issue is spring perch height combined with the adjustable coil sleeve. It was actually bottoming out on top of the sleeve (since I had it maxed out on low due to the stock-location spring perch).....This is using a 400lb/in 5'' Eibach wind...
    Soooo I drilled out the bottom of the strut tube till the strut insert pulled through a bit. Then stacked $5 of washers on the end and bolted it back up. Chopped the top of the strut tube accordingly. Added a helper spring and threw it back on the car. Issue solved.
  8. #8
    Offset-----Less is MORE!! burgy240 has a reputation beyond repute burgy240 has a reputation beyond repute burgy240 has a reputation beyond repute burgy240 has a reputation beyond repute burgy240 has a reputation beyond repute burgy240 has a reputation beyond repute burgy240 has a reputation beyond repute burgy240 has a reputation beyond repute burgy240 has a reputation beyond repute burgy240 has a reputation beyond repute burgy240 has a reputation beyond repute burgy240's Avatar
    Join Date
    Jan 2004
    Location
    Tampa
    Posts
    8,180
    Feedback Score
    17 (100%)
    You should re-invent s-chassis suspension because apparently no one has done it right yet. The lower you go the stiffer it NEEDS to be so you don't bottom out. G/L
    Looking to buy or sell Real Estate, give me a call.
    http://liberty-vip.com Flush ≠ VIP. Spread the word in 2012
  9. #9
    Join Date
    Apr 2005
    Location
    Brandon
    Posts
    2,047
    Feedback Score
    7 (100%)
    ^Cant tell if thats sarcasm? lol
    Seriously though, s chassis front suspension blows ass.
    8611 setups/coilover porn:
    Attached Thumbnails Attached Thumbnails I need more front travel!-koni_front_complete.jpg
  10. #10
    Racing Hart rhart has a reputation beyond repute rhart has a reputation beyond repute rhart has a reputation beyond repute rhart has a reputation beyond repute rhart has a reputation beyond repute rhart has a reputation beyond repute rhart has a reputation beyond repute rhart has a reputation beyond repute rhart has a reputation beyond repute rhart has a reputation beyond repute rhart has a reputation beyond repute rhart's Avatar
    Join Date
    May 2005
    Location
    St Petersburg
    Posts
    811
    Feedback Score
    11 (100%)
    Nice set up!!
    -Royce
  11. #11
    Moderator mewantkouki has a reputation beyond repute mewantkouki has a reputation beyond repute mewantkouki has a reputation beyond repute mewantkouki has a reputation beyond repute mewantkouki has a reputation beyond repute mewantkouki has a reputation beyond repute mewantkouki has a reputation beyond repute mewantkouki has a reputation beyond repute mewantkouki has a reputation beyond repute mewantkouki has a reputation beyond repute mewantkouki has a reputation beyond repute mewantkouki's Avatar
    Join Date
    Mar 2007
    Posts
    4,246
    Feedback Score
    10 (100%)
    I spy t3 camber plates.
    Quote Originally Posted by osama tim laden View Post
  12. #12
    Join Date
    May 2005
    Location
    St Petersburg
    Posts
    811
    Feedback Score
    11 (100%)
    How much $$ do you have tied up in that set up?
    -Royce
  13. #13
    Registered User BABILLARACING has a reputation beyond repute BABILLARACING has a reputation beyond repute BABILLARACING has a reputation beyond repute BABILLARACING has a reputation beyond repute BABILLARACING has a reputation beyond repute BABILLARACING has a reputation beyond repute BABILLARACING has a reputation beyond repute BABILLARACING has a reputation beyond repute BABILLARACING has a reputation beyond repute BABILLARACING has a reputation beyond repute BABILLARACING has a reputation beyond repute BABILLARACING's Avatar
    Join Date
    May 2005
    Posts
    3,200
    Feedback Score
    15 (94%)
    Quote Originally Posted by omgosh View Post
    nice set up you got there mister, if you don't mind me asking where and how much you paid for the cartridge housings? I am planning to do something like that
    My shit still slow
    618 whp 492 ft/lbs at 22 psi (Low Boost)on pump gas ,
    stock block ,more power coming soon ,stay tuned
    Tuned by Alpha @ Induction Performance
  14. #14
    Join Date
    Apr 2005
    Location
    Brandon
    Posts
    2,047
    Feedback Score
    7 (100%)
    ah I just pulled those pics off Nissanroadracing. The first two are 8611 double adjustables in user "veilside180sx" custom strut housings. They go for like $300. The chrome one is a koni yellow setup like mine. I picked my Konis up for $100 with ground control sleeves.
  15. #15
    Join Date
    May 2005
    Posts
    3,200
    Feedback Score
    15 (94%)
    damn $100 that is a hell of a deal. I guess i gonna fabricate some housings. Thanks again....Omar
    My shit still slow
Thread Information
Users Browsing this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204
