+ Reply to Thread
Results 1 to 15 of 22
Thread: Car intermittently losing power.
02-05-2012 12:32 AM #1Registered User
- Join Date
- Feb 2009
- Location
- Lutz, FL
- Posts
- 111
- Feedback Score
- 0
So I'm driving home the other night on Hwy 41 in Lutz doing about 50 Mph and for a split second I feel the car lose power and then it came back. The next day, at a stop light I felt the car lose power again while at a dead stop. It's idling around 800 rpms which to me is kind of low. I've only had the car about two months and I'm worried that there may be a transmission issue that is going to cost a buttload of money. When I bought the car back in Dec 2011, I replaced the spark plugs with NGK single prong iridiums and also with NGK wires. I don't think it's a fouled plug. Also, the car takes a long time to get past second gear. It is a '95 with the only mods being an AEM aluminum intake and Megan Racing catback exhaust. The problem is not happening all the time and this is something new that just started. I'll know more when I get back in town tomorrow and drive it home (if I make it that far! LOL!). If anyone has any suggestions it would be greatly appreciated. Thx dudes!
Taite
02-05-2012 04:00 AM #2.....taste the rainbow
- Join Date
- Apr 2009
- Location
- Someones' sisters' pants
- Posts
- 1,304
- Feedback Score
- 16 (100%)
Losing power....like momentum or as if everything electrical is turning of for a split second? Your average car idles at about 7-750 RPMs in neutral, with the AC off. So 800 isn't all that bad. Shit, my car usual idles at 1400 rpms.
You know, somebody actually complimented me on my driving today. They left a little note on the windshield, it said 'Parking Fine.'
02-05-2012 11:05 AM #3
^ 1400? Damn.
Here is a list of things I would check:
Fuel pump sock
Fuel pump
Change fuel filter (cheap anyways)
Change distributor rotor and cap (cheap)
Check plugs
Grounds
Connections (maf plug, dist plugs, etc)
Make sure maf is clean.
Make sure all injectors are firing good
I would also do a compression test for peace of mind.
IIRC your car is auto. People throw away auto trannys, I myself have tossed a few. So you should be able to scoop one up somewhere worst case.Last edited by Super Coupe; 02-05-2012 at 11:08 AM.
02-05-2012 12:33 PM #4.....taste the rainbow
- Join Date
- Apr 2009
- Location
- Posts
- 1,304
- Feedback Score
- 16 (100%)
I have no IACV. It's blocked off.
02-05-2012 09:17 PM #5
wonderful story, bro. please tell me it again?
jk.
my suggestion is to do process of elimination of everything super coupe said plus check the spark plugs again to see what they look like, compression test, check timing, check alternator and battery voltage too. never know unless you check right?
also, may have been bad gas.. the car sputtering at all while you felt the power loss? maybe it felt like slippage of the torque converter? I know it can be expensive buying all these parts but that's what you gotta do to diagnose the problems on your own, narrow the list down to what you may think it could be or just take it to the best mechanic near you..Last edited by Kung.; 02-05-2012 at 09:21 PM.
02-06-2012 01:17 AM #6Congac, bannana bitch
- Join Date
- Feb 2006
- Location
- Homosassa(Above Spring Hill)
- Posts
- 1,624
- Feedback Score
- 34 (100%)
Sometimes at a stop the autos will do a funny idle dance intermittently, i've noticed that. Put some "Trans stop slip" b/s in there and see if that makes the slippage better. If not I have a good auto trans/converter/flywheel that i know is 100% good I could sell you for not a "buttload of money" lol. G/L
-Julien
02-06-2012 06:31 PM #7buildin' it
- Join Date
- Jan 2009
- Posts
- 4,177
- Feedback Score
- 0
Other than just listing the general basics of engine diagnosis, do you have any particular reason as to why you would suspect any one of those issues? Given the information given, the only two that come close to making sense would be to check the grounds and check the connections. If any of either of those are loose, it could cause a "split second loss of power" As for everything else, the symptoms wouldn't be a "split second loss of power"
Shit, while you're in there, might as well tear the thing down and rebuild the engine engine and send the tranny off for a complete overhaul. I don't know about any of you, but any fouled spark plug I have dealt with, hasn't caused a "split second loss of power" and it hasn't been every once in a while.
Fouled plugs don't spark, and if they do, they barely spark, causing the engine to run poorly all of the time. The plugs could tell you if you were running rich, but then the issue would be surging idles and the smell of gas. They could also tell you if you are running lean, but again, there would be misfires due to the vacuum leak, or other "all of the time" type of issues.
If it was a compression issue, again, it wouldn't be a "split second loss of power" A loss of power, sure. A miss fire, sure. But it would be all of the time. Not a random, "split second loss of power"
Given the aftermarket exhaust, the minor misses caused by the spark timing not being 100% perfect could be audible, but in my personal experience, as well as anyone I have worked with, no one has been able to describe one of those "pops" as a "split second loss of power" the other crazy thing about that is those pops, are there all of the time, not once and while and not for a split second.
Alternator and Battery Voltage? While I agree, it is a good idea to check them rather often so you have a good idea of what the electronic are doing in your car, I still have no idea what this would have to do with the symptoms given. A "split second loss of power" while it might be voltage related, it isn't going to be due to low voltage from either the alternator or the battery. If either one of those drops voltage, it isn't going to be for a split second. The only way they could be related is if a connection was loose and just happened to shake the right way to disconnect for a split second.
Bad gas would cause the engine to run poorly all of the time. Would also make it difficult to start. Hell, it could even cause it to diesel after it has been shut off. But I just can't see once tiny tablespoon amount of bad gas keeping itself concentrated enough to get all the way through the fuel system and cause a "split second loss of power"
The torque converter slipping is the one decent idea you came up with as a transmission issue could actually be possible since it is an electronically controlled transmission, it could "hiccup" which could feel like a random "split second loss of power"
You have got to be fucking kidding right?
You're just fucking with this kid because he's new right?
I hope all you're doing is trolling because that has to be the most stupid thing I have heard in days.
02-06-2012 07:33 PM #8Registered User
- Join Date
- Feb 2009
- Location
- Lutz, FL
- Posts
- 111
- Feedback Score
- 0
Thanks for all the replies. As for being new to the 240 game, that I am not. I've owned an S13 and a 5-speed S14. This is the first auto 240 I have owned (just had ACL surgery a few months ago and don't feel like pushing a clutch right now.). I drove the car home last night and no issues. Could be bad gas, maybe a fuel filter (like some have stated). Fuel filter is on the way (ordered a WIX filter online since no one local sells them). I don't suspect a fouled plug as they are just over a month old. I did run some Seafoam a week ago in the fuel, but have filled up with a full tank since then. Also Seafoamed the oil, and will change it out this week. Just to clarify, the loss of power is not an electrical issue (sorry!), it was a sudden loss of engine power. Driving an auto sucks! This is the first one I've owned. My previous car was an '07 Subaru Legacy GT which I got after trading in a rather mint S14 5-Speed. Dumbest mistake car-wise I've ever made. Thx again for the help!
02-06-2012 07:55 PM #9buildin' it
- Join Date
- Jan 2009
- Posts
- 4,177
- Feedback Score
- 0
Fuck guys.
Do you all seriously just throw parts at your cars and hope that it will start running better sooner or later?
Do you know that is actually the wrong way of doing it right?
It is shit like that, that makes everyone think that 240 drivers are totally retarded.
Can any of you even take the time to explain why you thought any of your suggestions might have been the issue?
Or even better yet, can any of you actually read the post and comprehend what was said in order to distinguish what the actual symptoms are?
Here, I'll help you out. I'll delete all of the extra crap and keep the important stuff.
Ok, so a possible miss fire at highway speeds under rather light load. Depends on what exactly the OP considers a split second, it could either be a simple misfire, or it could be a very brief moment where the engine bogged down and then caught right back up.
So this tells us that it most likely only happened once on that ride home. It would be safe to say that there were at least 5 more miles driven after that split second loss of power.
Ok, so since it happened at a stop this time, it is unlikely that it has anything to do with speed. It can also be safe to say that at this point, it has little, if anything to do with load. Not much load involved at a stop.
we know that 800 rpms isn't really all that low for an idle. But it would be worth asking why the OP thinks that is low. Did it used to be higher? Is it supposed to be higher because it is an automatic? Has he even had the car long enough to know what it used to idle at?
Guess that answers that question.
the OP is worried it might be a transmission issue. HHmmm... I wonder what the OP knows that would make him suspect a transmission issue.. Need to ask him to find out. Believe it or not, people don't always post every detail about the situation in their first post.
Since he thinks it is going to cost a buttload of money to have the transmission issue fixed, then we can figure that it is either A) an automatic transmission B) he is very new to 240s in general C) he has all of his work done at a shop. One, or a combination of each. Automatic transmissions to fix them the correct way, can be costly since most people don't have the skills to be able to fix them themselves. I personally have rebuilt engines, but wouldn't screw with an automatic tranny. Just not my deal. So it isn't anything for sure, but we can use it to help guide our thinking.
again, he hasn't owned this car very long.
Two things here. First, we can figure that this guy is more than likely one of those people that makes an effort to maintain his vehicle since he gave it new plugs and wires from the get go. Second, Why exactly did he feel like he needed to replace the plugs and wires? Was there a reason for it? What else was done?
A long time huh? According to what? Why does the OP think it takes a long time? Are we talking about it staying in second gear for a longer than normal amount of time? OR is it taking a long to to actually shift from second and into third?
Since he said the car takes a long time, this would affirm the thoughts we already have about it being an automatic, but because we don't want to take anything for granted, we're going to ask anyway. We already know that people have posted stranger things before.
What is the OP comparing this to? A totally different car? a previously owned 240? A buddies 240? Or just a feelin?
Has it always shifted like that? Or is this a new symptom that started about the same time as the "split second loss of power"
Shouldn't make much difference, but at least we know we are working with an S14.
The exhaust means we would be able to more easily hear misfires.
The intake tells us that it is more than likely not properly secured and is just loose and hanging there like 99% of all aftermarket intakes, especially the AEM ones since they don't even come with brackets to secure it new. Since it is loose, it could mean that it is vibrating around and the MAF plug has gotten worn and loose. Its a rather common issue and if it got bumped in just the right way, it could cause a split second loss of power. Vibrations and bumps happen at both 50 mph and idle. So thats a possibility.
So the issue just started and so far it appears to have happened only twice in two days. Beyond that, it appears that it is running, driving, starting, etc, just fine.
So the only issue is a sudden, "split second loss of power"
So the OP is looking for some suggestions and feedback so he can check things out as soon as possible. So we can rather safely assume that he'll be back to be able to answer any questions we might have to be able to get some more information out of him to offer even more accurate advice because we want to help him out, not tell him bullshit information using the excuse that you have to spend a ton of money and throw parts at your car to be able to figure out what is wrong with it. We're smarter than that. Smart enough to know that if we can't come up with an educated, intelligent, suggestion, that we'll be able to recognize, not only our lack of knowledge, but also our sheer lack of understanding, and therefore, keep our mouths shut.
See how much information you can get out of a single post?
And hell, this wasn't even a totally perfect post. Decent, but not perfect.
Now, lets review our notes so we can begin to form a response.
-So we want to know what the OP considers to be a "split second" since this could dramatically effect the possible causes. Perhaps we could ask: What exactly do you mean by split second? Are we talking about a single misfire, or was it different than that? We talking like literally less than a second, or was it maybe a couple of seconds?
-From there, we assumed that it happened only once on the ride home, but we want to be sure, : Did it only happen once on the ride home? How long did it run after that split second loss of power?
-We wanted to know why the OP thought a 800 rpm idle was a bit low: Why do you think that 800 rpms is a bit low? 240s are actually supposed to idle right around there.
-Why does the OP think it might be a transmission issue : What makes you think it is transmission related? Is it doing anything else that makes you think it could be the transmission?
-When the OP bought the car, why did he put in new plugs and wires? : What made you install new plugs and wires when you got the car? What else was done to the car?
- Why does the OP think it takes a long time to get passed second gear, and what exactly does that mean? : It is an automatic right? Why do you think it takes a long time to get passed second gear? Do you mean that it is in second gear for a long time, or do you mean the actual shift from second to third takes a long time? What are you comparing this time to?
- That intake could be bouncing around and hitting the MAF sensor plug, lets ask our questions first, then post that as what we think it could be so far : Is your AEM intake secured, or is it just attached at the throttle body? If it is loose, chances are it is bouncing around and that is putting stress on the MAF sensor plug, wearing it out and making it loose. Those split second losses of power could have been the plug getting bounced just right and causing it to temporarily come loose. That brief disconnect could have caused the engine to die for a split second and as soon as the plug settled and connected again, it would have gone back to normal. A lot of people will take a zip tie and zip tie the wire snuggly to the intake pipe to try and keep the plug tightly connected. It would be better to also secure the intake tube to stop it from flopping all over the place.
- the OP said it was a new issue, and only discussed it happening twice, was that it? : Did it only happen those two times? So once a day?
- the OP is concerned about making it home, : Why do you think it won't make it home? Is it getting worse?
Now, take all of that and compile it into a single, decent, halfway intelligent response.
What do you mean by "Split second" ? Are we talking about a single misfire, or was it more like the engine bogged down for a moment, and then immediately caught up and was back to normal? We talking literally less than a second, or was it maybe a couple of seconds?
Loss of power as in the engine started to die, or do you mean electrical issues?
Since it did it both while moving and while sitting still, it is unlikely that it is the transmission, unless there are some other symptoms.
240's are technically supposed to idle right at 750 rpms, but pretty much anything under 1,000 is pretty normal. So your 800 rpms is pretty typical. It won't hurt anything to leave it that way, but if you wanted, you could actually adjust the spark timing a little bit to try and bring it down just that touch more. not really a big deal. The key is that it is even and consistent.
Did you install new plugs and wires because of this issue, or was that before anything was wrong? Have you don't any other work to the car? before this issue? Trying to fix it?
It is an automatic right? When you say that it takes a long time to get passed second gear, do you mean that it is in second gear for a long time, or do you mean the actual shift from second to third takes a long time? It doesn't seem like the two things are related, but if the tranny is giving you shifting problems, then it is possible that the fluid has more than likely never been changed. A full change would probably be a good idea, but even just changing the filter and topping it off would be a big help. That lucas transmission stuff seems to do a pretty decent job at helping out an old tranny. here's some interesting info on the 240sx automatic tranny - Ultimate Guide to Nissan Automatic Transmissions
As far as that split second loss of power, I would be willing to bet that your intake isn't secured beyond just where it connects to the throttle body. Chances are it is bouncing around while you drive and that is putting a ton of stress on the MAF sensor plug. All of that movement can wear out the plug causing it to loosen up. Then, all it takes is just the right bump, and the pins inside the plug loose contact for a moment. That brief disconnect causes the ECU to think the MAF just took a crap and it wants to drop the RPMs and dump fuel. When you were driving down the road at 50, you could have hit a bump in the road just right to cause this and when you were at idle, the engine could have been shaking in just the right way to knock the plug around. A lot of people will fix this by taking a zip tie all the way around the intake and the wiring, so the wiring is snugged up against the intake. This puts pressure on the plug to keep it in place. A step better would be to secure the entire intake pipe, and air filter to keep it from bouncing all over the place. I had mine so that the plug was held in place, and so the intake tube was held down. That way the wiring wouldn't shake around, and the plug couldn't get hit on anything.
If there aren't any other symptoms, then I would start with checking out that plug.
See how that covered all of the bases, asked all of the right questions, and suggested a possible issue that made sense?
Now, the OP can go inspect the correct thing, isn't wasting time and more importantly wasting money throwing random parts at the car. And if the OP comes back with answers to those questions, we can then narrow down what else it could be because we'll have some more information to work with.
02-06-2012 08:03 PM #10buildin' it
- Join Date
- Jan 2009
- Posts
- 4,177
- Feedback Score
- 0
to the OP,
since you don't appear to need the education on how to read, comprehend, understand, and properly respond to a post, you can skip all of that.
given the way you describe what is happen, here's my 2 cents,
check the MAF sensor plug.
if you're aftermarket intake isn't secured, it is more than likely bouncing around causing stress on the MAF sensor plug, wearing it out, making it loose.
All it would take is the right bump for it to briefly loose the connection and that would cause the ECU to think the MAF just failed and start to go into limp mode, retarding the timing, dropping rpms, and dumping fuel. Which, especially in an automatic, would feel like a loss of power. And since it only lasts a moment, it would feel like a split second loss of power.
Nothing else really fits, unless there are other symptoms we don't know about.
any why do you think it takes a long time to get passed 2nd gear? you mean you are in second gear for along time? or the shift from 2nd to 3rd takes forever?
If it is crappy shifting, then the fluid is probably old as hell.
as for being in 2nd gear for a long time, I guess that depends on what you are comparing it to. But again, could also be fluid issues.
I would drop the pan, let it sit for a few hours at least, get a fresh filter on there, top it off with fresh fluid, and probably even toss in a bottle of lucas transmission fix. Especially if it has a bunch of miles on it. people tend to forget that the auto tranny needs maintained like everything else on a car.
02-07-2012 07:27 PM #11
riveting tale, bro.
I said "process of elimination".
usually what you do if you have no clue what the problem is,
the best bet for someone who isn't a mechanic and is a "do it yourself" type person.
I also said buying parts "can be" expensive when trying to diagnose problems on your own.
I didn't tell him to go out and buy any specific parts at all, super coupe only recommended changing fuel filter, cap and rotor..
bro if you can't afford those parts,you better apply at a new job if you even have one.
your novel didn't come up with anything different then what we said the maf , torque converter already brought up, oh, you said intake which is connected to the maf and change the fluid in the trans like that would make a loss of power...
breaking it all down when your really have no fucking clue how to comprehend anything, your trying to twist my words into some bullshit i didn't say, nice try though. guys like you are awesome, mister-know-it-all, you know how to copy and paste some fucking link on auto trans, fucking nerd. hahahaLast edited by Kung.; 02-07-2012 at 08:08 PM.
02-07-2012 07:57 PM #12Registered User
- Join Date
- Feb 2009
- Location
- Lutz, FL
- Posts
- 111
- Feedback Score
- 0
First of all, to Empire, thanks for the help. Some of the things you mentioned I have already thought about, the others I will seriously consider. I'm not a mechanically inclined dude, but once I tear into something, nine times out of ten I can get it back together the right way. Once again, thanks for the help.
Second of all, to Kung, thanks for the little bit of help you offered, but you kinda made yourself look like an ass when questioning whether I can afford to buy parts or not. You don't know my financial situation (just to give you some insight, I only have a mortgage and own three cars (own them, not the bank owning them)). And I make pretty close to $75,000 a year as an airborne communications operator for the Air Force. Not to mention that I get to travel around the world on a Gulfstream G-5 while the only G anything that you'll ever know anything about is the one mentioned in that stupid ass G-6 song. So, shithead, I do have a job (actually I have almost 20 yrs at my job) and I don't think that I need to worry about applying for a new one anytime soon. Before you open your mouth about something you know nothing about, maybe you should have your mouth/brain disconnect switch fixed. Maybe you can get Empire to walk you through that one smart guy. Lastly, like I mentioned before, this is the 3rd 240 I have owned, but the first auto transmission 240. Those of you that gave worthwhile and helpful advice, thanks!
02-07-2012 08:01 PM #13
another riveting tale but I was talking to empire, lol.
02-07-2012 08:13 PM #14buildin' it
- Join Date
- Jan 2009
- Posts
- 4,177
- Feedback Score
- 0
looks like English is still kicking your ass.
you said Tell me how that doesn't mean buying a bunch of unrelated parts, throwing them at the car and seeing which one solves the problem?
It doesn't have anything to do with being able to afford the parts or not.
1) throwing random parts at your car isn't a status symbol. Maybe in the retard 240 world the guy with the newest parts is the coolest, but not in the real world.
2) Why do parts that may be perfectly good need to be replaced? Just makes you look like an total idiot when you are replacing parts that don't even have anything to do with your problem.
process of elimination isn't throwing parts at it til it is fixed. Process of elimination is looking at the symptoms and eliminating any possibilities that don't produce those symptoms, BEFORE you buy any parts.
I could be wrong, but I would imagine the non-mechanic, do it yourself person would want to get the problem fixed the first time, and not spent money and more importantly time under the hood, changing out parts that don't have anything to do with the problem.
If you could read, you would have found that my "Novel" did come up with something different. It negated all of the stupid suggestions and brought it down to the MAF sensor plug being the possible issue. Even explained why that is more than likely the issue.
And yes, if you know anything about automatic transmissions, poor fluid condition can cause a dramatic loss of power. It can cause massive slippage issues due to over heating, which could feel like a loss of power. It can also cause the torque converter to cycle through lock up due to excessive heat. Bad fluid can cause the TCM to hang onto gears, and not shift properly, and try to lock the clutches up in the wrong times. If the fluid is really bad, it could even cause the TCM to go into limp mode, which causes all sorts of symptoms when you are trying to drive the car down the road.
Typically, the torque converter isn't the problem. It is more often than not due to bad fluid.
Since the OP mentioned the tranny hanging onto second gear for a long time, and since he thought that it might be a transmission issue to begin with, it would have been smart to point him into the right direction regarding fluid issues.
And since shits like you hate "novels" i decided that instead of typing all of the transmission information out that is contained within that link, I thought I'd save you all a page of reading and just post the link.
Still can't wrap my head around how that makes me a "nerd"
I guess doing research to not only learn the knowledge, but be able to understand it makes someone a nerd.
Also can't wrap my head around how I'm the one that can't doesn't have a "fucking clue how to comprehend anything" when I am the one that was able to break it all the way down, eliminate the stupid suggestions, explain why they were stupid suggestions, get the relevant info out of the first post that people like you seemed to have blindly missed, make and explain an actual valid possibility and provide additional information that might just be useful for the OP.
I didn't have to twist anything around. You said it. It is right there, clear as day. "it can be expensive buying all these parts but that's what you gotta do to diagnose the problems" How does anyone have to twist that around to mean anything but buy a bunch of parts and keep throwing money at it until the problem gets fixed?
If that isn't what you meant, then please, explain what it is exactly that you intended to relay on with that statement.
I know I'm pretty awesome, glad you think so too.
02-07-2012 08:26 PM #15Registered User
- Join Date
- Feb 2009
- Location
- Lutz, FL
- Posts
- 111
- Feedback Score
- 0
Forgot to mention that I do have the intake strapped down properly with brackets that came with the intake kit. So, the intake isn't just secured at the throttle body. Also, I cleaned the MAF element a few weeks ago with some electrical cleaner. The reason that I replaced the plugs that were in the car when I bought it is because they were fouled. Not to mention that the jackass who had the car before me used 4 prong plugs. And I figured that a good set of NGK plug wires couldn't hurt. I have found that the single prong NGK Iridium plugs have worked best in my cars (all stock KA engines). I've never had a turbo 240, maybe once I get these issues worked out I can start down that road. All the stuff that I've done to the car was stuff I've done myself. My so-called broke, dumb, hick ass can even change out a set of brakes! Hope to maybe see you dudes around town sometime! Thanks again.
Thread Information
Users Browsing this Thread
LinkBack URL
About LinkBacks
