+ Reply to Thread
Results 1 to 11 of 11
  1. #1
    I was born to fertilize. Flatline has a reputation beyond repute Flatline has a reputation beyond repute Flatline has a reputation beyond repute Flatline has a reputation beyond repute Flatline has a reputation beyond repute Flatline has a reputation beyond repute Flatline has a reputation beyond repute Flatline has a reputation beyond repute Flatline has a reputation beyond repute Flatline has a reputation beyond repute Flatline has a reputation beyond repute
    Join Date
    Jun 2008
    Location
    Port Shitty
    Posts
    602
    Feedback Score
    2 (100%)
    S13 Sr20 Engine mounts
    Ive read places that nismo mounts actually lift the engine up a little, and the Circuit Sports ones drop them.
    Im looking for a set that will lift it a tad bit, but if i can avoid dropping the cash for nismo mounts, i would like to.
    What about Megan racing? I cant seem to find any info on this about them. I've only browsed a little bit so i may just find it but i figured i would ask.
    My issue really is that with the way everything is set up in my car, the turbo outlet touches the steering shaft, and my down pipe is a hair away from the frame rail so twisting the engine seems like it'll move the DP closer to the frame.
    also, is it possible to clock the compressor and exhaust housing on the turbo to move it all in to fix any of this?
    Just thinking out loud really. Thanks in advance to anyone with anything to say on it.
    Tops Optional
  2. #2
    i has double turbo sean1 has a reputation beyond repute sean1 has a reputation beyond repute sean1 has a reputation beyond repute sean1 has a reputation beyond repute sean1 has a reputation beyond repute sean1 has a reputation beyond repute sean1 has a reputation beyond repute sean1 has a reputation beyond repute sean1 has a reputation beyond repute sean1 has a reputation beyond repute sean1 has a reputation beyond repute
    Join Date
    Aug 2005
    Location
    seffner
    Posts
    1,819
    Feedback Score
    13 (100%)
    i would prob just shim it a little bit, easiest/cheapest way,just me though
    my honda sounds like a lawnmower, because it is one.
  3. #3
    buildin' it Empire has a reputation beyond repute Empire has a reputation beyond repute Empire has a reputation beyond repute Empire has a reputation beyond repute Empire has a reputation beyond repute Empire has a reputation beyond repute Empire has a reputation beyond repute Empire has a reputation beyond repute Empire has a reputation beyond repute Empire has a reputation beyond repute Empire has a reputation beyond repute
    Join Date
    Jan 2009
    Posts
    4,177
    Feedback Score
    Quote Originally Posted by Flatline View Post
    how did you accomplish that?
    And on the eighth day, the Lord created the turbocharger
    Kings will never fall.
    - Tim, R.I.P
    Quote Originally Posted by UserName View Post
    If you got s14 problems I feel bad for you son, I got 99 problems but my s13 ain't one.
  4. #4
    .....taste the rainbow KRUKED has much to be proud of KRUKED has much to be proud of KRUKED has much to be proud of KRUKED has much to be proud of KRUKED has much to be proud of KRUKED has much to be proud of KRUKED has much to be proud of KRUKED has much to be proud of KRUKED has much to be proud of KRUKED has much to be proud of KRUKED has much to be proud of KRUKED's Avatar
    Join Date
    Apr 2009
    Location
    Someones' sisters' pants
    Posts
    1,304
    Feedback Score
    16 (100%)
    Clock the turbo outlet where you want it and then you will more than likely have to cut and refab the down pipe to get everything were you want it comfortable.
    You know, somebody actually complimented me on my driving today. They left a little note on the windshield, it said 'Parking Fine.'
  5. #5
    Join Date
    Jun 2008
    Location
    Port Shitty
    Posts
    602
    Feedback Score
    2 (100%)
    Quote Originally Posted by Empire View Post
    well its an aftermarket outlet with a divided section for the wastegate that sticks out. I think that engine shifted in the mounts bringing the driver side down causing that section to touch. The DP is a 3" and seems to touch. I have had the front subframe out before so it may have gone in crooked.
    Quote Originally Posted by KRUKED View Post
    well if i clock the outlet i have to clock the compressor. T25 wastegate mounts to the compressor housing. but i looks to me like clocking the turbo could solve both issues, while engine mounts could keep the outlet further from the steering shaft and keep the oil pan further from the ground.
    Tops Optional
  6. #6
    S one 4 Jr_SS has a reputation beyond repute Jr_SS has a reputation beyond repute Jr_SS has a reputation beyond repute Jr_SS has a reputation beyond repute Jr_SS has a reputation beyond repute Jr_SS has a reputation beyond repute Jr_SS has a reputation beyond repute Jr_SS has a reputation beyond repute Jr_SS has a reputation beyond repute Jr_SS has a reputation beyond repute Jr_SS has a reputation beyond repute
    Join Date
    Jun 2005
    Location
    Venice,Fl
    Posts
    787
    Feedback Score
    1 (100%)
    Don't be a cheapass, buy the Nismo mounts. They don't raise the engine, they just bring it back to where it sat from the factory. Your 20yr old mounts have sagged.
  7. #7
    Moderator mewantkouki has a reputation beyond repute mewantkouki has a reputation beyond repute mewantkouki has a reputation beyond repute mewantkouki has a reputation beyond repute mewantkouki has a reputation beyond repute mewantkouki has a reputation beyond repute mewantkouki has a reputation beyond repute mewantkouki has a reputation beyond repute mewantkouki has a reputation beyond repute mewantkouki has a reputation beyond repute mewantkouki has a reputation beyond repute mewantkouki's Avatar
    Join Date
    Mar 2007
    Posts
    4,246
    Feedback Score
    10 (100%)
    ^ + 9000
    Quote Originally Posted by osama tim laden View Post
  8. #8
    Join Date
    Jun 2008
    Location
    Port Shitty
    Posts
    602
    Feedback Score
    2 (100%)
    Well the count is above 9000 so i almost have to do it lol.
    just have to wait a couple weeks to do it. We'll see what happens.
    thanks again guys.
    Tops Optional
  9. #9
    Join Date
    Jan 2009
    Posts
    4,177
    Feedback Score
    above 9000
    - Tim, R.I.P
  10. #10
    (OO\____/OO) Blackzenki82 has a reputation beyond repute Blackzenki82 has a reputation beyond repute Blackzenki82 has a reputation beyond repute Blackzenki82 has a reputation beyond repute Blackzenki82 has a reputation beyond repute Blackzenki82 has a reputation beyond repute Blackzenki82 has a reputation beyond repute Blackzenki82 has a reputation beyond repute Blackzenki82 has a reputation beyond repute Blackzenki82 has a reputation beyond repute Blackzenki82 has a reputation beyond repute Blackzenki82's Avatar
    Join Date
    Oct 2008
    Location
    Gainesville FL
    Posts
    6,363
    Feedback Score
    13 (93%)
    hocky puck mounts and stacked washers is where it's at bro, fuck nismo, fuck corporations.....
    Threw It On The Ground - YouTube
    Quote Originally Posted by sean1 View Post
    Shit'll buff out.
  11. #11
    Join Date
    Jun 2008
    Location
    Port Shitty
    Posts
    602
    Feedback Score
    2 (100%)
    Such an amazing refrence song lmao
    Tops Optional
Thread Information
Users Browsing this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204
