+ Reply to Thread
Results 1 to 7 of 7
  1. #1
    Do it big.1 life to live. RhinoFLA has a reputation beyond repute RhinoFLA has a reputation beyond repute RhinoFLA has a reputation beyond repute RhinoFLA has a reputation beyond repute RhinoFLA has a reputation beyond repute RhinoFLA has a reputation beyond repute RhinoFLA has a reputation beyond repute RhinoFLA has a reputation beyond repute RhinoFLA has a reputation beyond repute RhinoFLA has a reputation beyond repute RhinoFLA has a reputation beyond repute RhinoFLA's Avatar
    Join Date
    Oct 2006
    Location
    ef.el.ayyy
    Posts
    1,100
    Feedback Score
    8 (100%)
    86 Hardbody z24 lost all power while driving
    Hey how's it going tr? So I was driving home from St. Pete the other day and was about 10 minutes from my house, I go to shift into 4th and there's no power there at all, I downshift and coast off of the road, as soon as I stopped the truck shut off. I started it, it started right up and then sputtered out, multiple times. Sat there for about 15 minutes looking for loose connections, vacuum leaks etc. and it started up, so I started heading towards my house, got about 2-3 minutes down the road and same result let it sit for a few then drove it all the way back to my house.
    The temp gauge doesn't work so I checked the coolant levels and checked to see if the thermostat was opening because it kind of seemed like an overheating issue and the ecm was going into limp mode or something? But the levels were fine.
    I drove it yesterday from Largo to St. Pete and it ran fine the whole way. Any thoughts as to what it might have been incase this problem resurfaces? I'm trading the truck to a friend next weekend and I'd like to make sure this is taken care of before he ends up getting stranded or something. Thanks for any input
  2. #2
    (SHIFT-YOUR SHITS WEAK) A-ron has a reputation beyond repute A-ron has a reputation beyond repute A-ron has a reputation beyond repute A-ron has a reputation beyond repute A-ron has a reputation beyond repute A-ron has a reputation beyond repute A-ron has a reputation beyond repute A-ron has a reputation beyond repute A-ron has a reputation beyond repute A-ron has a reputation beyond repute A-ron has a reputation beyond repute A-ron's Avatar
    Join Date
    Nov 2006
    Location
    Zephyrhills FL
    Posts
    3,088
    Feedback Score
    9 (100%)
    fuel pump if it sputters off
    Drifting:
    most fun you can have
    with your pants on.
  3. #3
    Join Date
    Oct 2006
    Location
    ef.el.ayyy
    Posts
    1,100
    Feedback Score
    8 (100%)
    Quote Originally Posted by A-ron View Post
    hmm you think so? I mean it's running fine now, starts up and drives great, but like I said I had been driving it for about 40 minutes or so the other day and mashed down the pedal when I was shifting into 4th and there was nothing there, then it'd start and sputter out repeatedly until it finally just started running again. I've never had a fuel pump go out, will they show signs like this? Randomly shutting off, and then one day just give out?
  4. #4
    Join Date
    Nov 2006
    Location
    Zephyrhills FL
    Posts
    3,088
    Feedback Score
    9 (100%)
    yea they do sometimes, they even get louder and then one day just not turn on..
    also if the truck gets spark from a coil pack it will get hot and cut out as well when ever it wants to..
    Drifting:
    with your pants on.
  5. #5
    TR OG obituary has a reputation beyond repute obituary has a reputation beyond repute obituary has a reputation beyond repute obituary has a reputation beyond repute obituary has a reputation beyond repute obituary has a reputation beyond repute obituary has a reputation beyond repute obituary has a reputation beyond repute obituary has a reputation beyond repute obituary has a reputation beyond repute obituary has a reputation beyond repute obituary's Avatar
    Join Date
    Oct 2001
    Location
    dover fl
    Posts
    913
    Feedback Score
    bad ground ! /short .
    1972 nova ss
    89 240 sr20det
    2002 chevy 1500 truck
  6. #6
    buildin' it Empire has a reputation beyond repute Empire has a reputation beyond repute Empire has a reputation beyond repute Empire has a reputation beyond repute Empire has a reputation beyond repute Empire has a reputation beyond repute Empire has a reputation beyond repute Empire has a reputation beyond repute Empire has a reputation beyond repute Empire has a reputation beyond repute Empire has a reputation beyond repute
    Join Date
    Jan 2009
    Posts
    4,177
    Feedback Score
    if the truck has a butt load of miles and hasn't ever had the fuel pump replaced, I'd start there. A dying pump will still pump fuel, but at a higher electric draw and the longer it runs, the hotter it gets, the higher the draw is. Was it a bit warmer out the day it was dying out on you?
    From there, I'd do the standard tune up if it has been a while. The fuel filter could be junked up. The plugs could be on their way out. They'll work for a while, but eventually the resistance will build up to the point where the spark isn't strong enough to ignite the fuel. Same with the wires. cap, rotor etc. All of that stuff can have a significant impact on how the truck runs.
    If that still doesn't solve the issue, then I'd move on to triple checking all of the connections. A loose/poor ground wire will be ok for a while, but then cause problems after a while. Same with vacuum lines. When things get hot, they expand, and that can cause issues.
    From there, I'd look towards the coolant temp sensor, the crank/cam angle sensor, throttle position sensor, mass air flow sensor
    much beyond that and you've got some major issues.
    And on the eighth day, the Lord created the turbocharger
    Kings will never fall.
    - Tim, R.I.P
    Quote Originally Posted by UserName View Post
    If you got s14 problems I feel bad for you son, I got 99 problems but my s13 ain't one.
  7. #7
    Join Date
    Oct 2006
    Location
    ef.el.ayyy
    Posts
    1,100
    Feedback Score
    8 (100%)
    appreciate the input. The trucks got around 106k miles on it, runs solid aside from that shit that happened the other day. Fuel filter, plugs and all that is on my list I've just been busy working a lot. I'll run through the grounds when I'm swapping all of that stuff out, I had a alot of plans for the truck but idk trucks just aren't my thing haha, trading it for a prelude this weekend. I'll start with basic maintenance like you said, appreciate it guys
Thread Information
Users Browsing this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204
