+ Reply to Thread
Results 1 to 13 of 13
11-11-2009 06:27 PM #1Top Secret
- Join Date
- Jul 2008
- Location
- florida
- Posts
- 654
- Feedback Score
- 1 (100%)
Replacing ka distributor without screwing timing
I have an s14 ka that i am putting in my s13.
The s14 distributor is still in the motor hasnt been knockedc around and i have the s13 distributor waiting to go in.
Can someone explain to me what I can do to replace the distributor while keeping the timing correct. I know it's not a simple procedure but i also know its not complex
Thank you.
11-11-2009 07:01 PM #2
11-11-2009 07:44 PM #3Top Secret
- Join Date
- Jul 2008
- Location
- florida
- Posts
- 654
- Feedback Score
- 1 (100%)
just align the rotor?
You dont have to make sure that anything else is lined up?
and i would have no idea how to reset the timing, you know how to do that?
11-11-2009 07:54 PM #4
you can check the rotor like A-ron mentioned. That'll make sure you're not a tooth off. The next part is the angle of the distributor's base. Before you remove the S14 one, look closely at where the bolt (the one that holds it in) is in relation to the slot. When you install the S13 part, make sure it's in the same place. That's just eyeballing it. You can get pretty close to perfect like that.
11-11-2009 08:03 PM #5Top Secret
- Join Date
- Jul 2008
- Location
- florida
- Posts
- 654
- Feedback Score
- 1 (100%)
alright that's more what i was looking for. Thanks a bunch A-ron and Epstein. You guys are awesome. I will do my best.
11-11-2009 08:17 PM #6(SHIFT-YOUR SHITS WEAK)
- Join Date
- Nov 2006
- Location
- Zephyrhills FL
- Posts
- 3,080
- Feedback Score
- 9 (100%)
to set the timing in a KA
i always use this method but people do if different
pull the spark plug out of cly #1
then pull the dipstick out and place it in cly #1
pull dizzy out with the cap off
turn over motor to you get to the compression stroke
then watch then get the dipstick as high as you can(have piston to the top)
set the rotor on dizzy to cly#1
insert dizzy
pull dipstick out put back in tube
put spark plug back in and the wire that goes to it.
see if it fires up.
if makes a popping noise(kinda sounds like under water) it's 180 out do it again lol.
if it runs but runs shitty loosen the bolts for the dizzy and twist it to it runs better.
that sums it up it's pretty easy bud
11-11-2009 08:31 PM #7Top Secret
- Join Date
- Jul 2008
- Location
- florida
- Posts
- 654
- Feedback Score
- 1 (100%)
alright that is fairly easy thanks a lot man. Im sure that will help more people than just me.
11-11-2009 08:45 PM #8
You can tell if you're on the compression stroke by looking at the #1 cam lobes through the oil cap hole. Lobes out is compression stroke. You can see TDC on the crank marks.
11-11-2009 08:49 PM #9
11-11-2009 09:05 PM #10Top Secret
- Join Date
- Jul 2008
- Location
- florida
- Posts
- 654
- Feedback Score
- 1 (100%)
Oh okay TDC simplified for me
haha i like
something simple just got simpler
11-12-2009 11:08 AM #11Formerly IThaJokaI
- Join Date
- Jul 2007
- Location
- New Port Richey
- Posts
- 5,301
- Feedback Score
- 19 (100%)
This is what I do, turn it to TDC when the EXH cam is pointing towards the manifold. After that, slide the dist till its lined up with cyl #1 or the fin on the dist is lined up with fin on the rotor.
Like so
Then put the cap back on, and tune it in more by the adjustment slots.
11-12-2009 11:26 AM #12Top Secret
- Join Date
- Jul 2008
- Location
- florida
- Posts
- 654
- Feedback Score
- 1 (100%)
Thanks Mike. Good pic.
11-12-2009 09:22 PM #13Top Secret
- Join Date
- Jul 2008
- Location
- florida
- Posts
- 654
- Feedback Score
- 1 (100%)
Awesome Nico site, found on the tech page.
Technical Articles: 240sx Distributor Timing
Thread Information
Users Browsing this Thread
LinkBack URL
About LinkBacks
