Forums Register TRHelp TRGarage TRader Ratings Classifieds Search Today's Posts Mark Forums Read Calendar
iTrader Mainpage
Browse All Members
FAQ Gallery Weather Log Out
Go Back   Tampa Racing > Technical Forums > Nissan/Infiniti Tech
Old 08-26-2008, 05:55 PM   #1 (permalink)
Car:
Wild Streak has a reputation beyond repute: 42949718
Question S13 Stop Lamp problem
I have 1992 s13 240sx recently I noticed when I was stopping at night time that my stop lamps was not lighting up when I pushed in the brake pedal, So I opened the fuse box and it had a blown fuse I replaced it with another 20 amp fuse and I pushed in the brake pedal and it blew the fuse so I looked at the wires running to the tail lights and none appeared to be cut or grounding out. So then I put a 30 amp fuse in and it worked for a little while but when it did work when I pressed the brake pedal in my dash lights and guage lights would dim like it was drawing a lot of current, then when it melted that fuse I check the button for the brake pedal and replaced it and it still does it can anyone help me with my problem any suggestions would help my parking lights work tho I do have an sr20det redtop if that matters, but it just started I have had it for a while and it just started doing this.
Wild Streak is offline
Old 08-26-2008, 10:31 PM   #2 (permalink)
(SHIFT-YOUR SHITS WEAK)
Car: nissan 240sx s13 hatch (91)
Zephyrhills FL
A-ron has a reputation beyond repute: 447614865
its a ground wire is loose wiggle them to see witch one is loose
A-ron is offline
Old 08-27-2008, 09:24 AM   #3 (permalink)
OG Join Date: 6-15-00
Car: 20 of the same thing
Tampa, FL
presidential has a reputation beyond repute: 2147483647
Re-do all of the ground wires. Your lights will be brighter than before if you run individual grounds instead of the failure prone daisy chain of grounds.
presidential is offline
Sponsored Links
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
