Silvia OEM+ build
Got the refund for the Honda AEM, thankfully. Had to be escalated all the way to a Paypal claim before the guy would give me my money back. Will be purchasing an SR20 AEM V2 soonish, most likely brand new.
The build had to be started a bit earlier than expected, so the 240 is now in the garage:
Day 1, getting everything disconnected, drained, etc.
Tomorrow will (hopefully) see the SR come out of the car, and onto an engine stand to start the teardown. I've not decided to what degree I want to build the motor, it will all depend on how everything looks once its apart.
...and then I wondered why I was on Stanceworks forums...
Originally Posted by PJ Prendergast
i went to a scrapyard in Kilcock today looking for my 180sx tail lights, no luck though
With the help of a buddy managed to get the SR pulled late Tuesday. Picking up an engine stand hopefully tonight and then will start to tear down all the accessories next week.
Progress for this week:
Separated engine and trans, got engine on stand and stripped almost completely to longblock:
Upon disassembly I noticed unfortunately my ACT clutch and Spec lightweight flywheel were toast. Sigh.
And finally, to keep myself motivated, I test fit my new turbo setup.
Not sure if anyone is still following my build but I promise cool stuff is coming in the near future!
Update time!
I've had the head and block separated for a few weeks now:
Cylinder walls look good, still have factory crosshatching, and the pistons looked good as well:
Rod journals (didn't get a picture of the mains but they looked normal as well):
Bearings all had similar wear:
Here is the current state of the block, I still have some more parts to remove before it goes out to the machine shop, but I need a crank pulley puller to get at the front cover/oil pump first.
I also pulled out the engine harness to tidy it up a bit. Just a simple rewrap and fixing a few questionable splices/connections that I had. I'm also extending the injector wires to be able to run that section of the harness under the intake manifold as I've seen others do before.
I also pulled the MAF wires through the harness and relocated them into the section of the harness that goes near the battery area. I'm going to be running my Z32 MAF in a blowthrough setup and locating it just under the battery tray out of sight. I had originally intended on going full standalone.... but things have slowed down significantly at work and I want to drive the car again ASAP. A full standalone and ID injectors will come eventually, but for now I'll be enjoying the motor and breaking it in with my trusty Entalpy ECU.
(terrible picture of MAF wire relocation)
Here's this weeks purchases. Spec Mini Twinplate clutch, and genuine Greddy Type R BOV (it is real, the sticker is gone and I had a friend mirror polish the top part).
This weeks project is the valve cover, which I had my friend shave the letters from and he's currently in the process of doing a full polish on (thanks Devin, you're a braver man than I!).
Finally, I'll end this post with a picture of my garage, which the engine build has completely taken over. Hopefully in the near future I'll be sending the block and head to the machine shop, I'm hoping the car will be back on the road within 2 months!
