+ Reply to Thread
Page 17 of 19 FirstFirst ... 7 14 15 16 17 18 19 LastLast
Results 241 to 255 of 285
  1. #241
    Racing Hart rhart has a reputation beyond repute rhart has a reputation beyond repute rhart has a reputation beyond repute rhart has a reputation beyond repute rhart has a reputation beyond repute rhart has a reputation beyond repute rhart has a reputation beyond repute rhart has a reputation beyond repute rhart has a reputation beyond repute rhart has a reputation beyond repute rhart has a reputation beyond repute rhart's Avatar
    Join Date
    May 2005
    Location
    St Petersburg
    Posts
    811
    Feedback Score
    11 (100%)
    Excellent!!
  2. #242
    Join Date
    May 2005
    Location
    St Petersburg
    Posts
    811
    Feedback Score
    11 (100%)
    Picked up a nice set of headlight trim from Brett (Bullitt_s13). Thanks man!! I'll post up a few pics of them once they're on...just because its been a while since i've updated the progress on the car.
    Its the little thing i guess. Nice to look out the windshield and see the trim there rather than something that might poke someone's eye out.
    Also picked up this thing. I'm somewhat sceptical of how it may work. Though the primaries are decent size the collector exit is only 2". It may work well for torque and not so good for higher HP gains. It will help the velocity of the exhaust gases as they exits and it thearoy that may be somewhat an improvement over stock. And will dump into 2.5" for somewhat better folow. Plus these headers are notorious for cracking due to stress...i'm hoping that a decently bent down pipe with a flex section will help that. The complete exhaust have been done relatively inexpensively so if I need to upgrade to 3" i wont cry over it.
    I currently run an ebay class 4-2-1 on the car that I will keep just in case the GReddy sucks.
    -Royce
  3. #243
    Join Date
    May 2005
    Location
    St Petersburg
    Posts
    811
    Feedback Score
    11 (100%)
    updated...input welcome.
    -Royce
  4. #244
    buildin' it Empire has a reputation beyond repute Empire has a reputation beyond repute Empire has a reputation beyond repute Empire has a reputation beyond repute Empire has a reputation beyond repute Empire has a reputation beyond repute Empire has a reputation beyond repute Empire has a reputation beyond repute Empire has a reputation beyond repute Empire has a reputation beyond repute Empire has a reputation beyond repute
    Join Date
    Jan 2009
    Posts
    4,177
    Feedback Score
    eh. I favor the long tube headers more myself. I don't know that the short tube ones give you any sort of scavenging effect. But, that's all debatable since header design is such a "black magic" kind of art.
    It is going to flow a lot better than the stock one, thats for sure. Don't know that you'll notice a whole lot of difference between the greddy one and the one you have now. Might make for a touch better low end torque, but I wouldn't expect any high rpm gains.
    You're on the right track with the flex pipe.
    I have also seen where people have cut the flange in between each runner to give it some flex relief. And also reinforce the welds, especially the collector since that is the key area to crack.
    The general masses are split between the greddy and the hotshot headers. Some really like the greddy one, and others say the hot shot is better and made more power.
    I'm thinking I would more than likely keep the little section of down pipe you would need at 2 inches. I think. Maybe 2.25. too much larger and you run the risk of letting the exhaust gases slow down. That downpipe is supposed to go where the stock cat is located. If you have a cat, that would be the best place to step up to the larger exhaust pipe.
    I don't know how I feel about a 3 inch exhaust. I personally would not go that big for a NA build. Maybe for a turbo built. Depending on the size of the turbo. 2.5 might be too restricting for the turbo to spool up nicely if it is a decent size. But even for your supercharger, I don't know that I would go 3 inch. Just feels like overkill to me. For me, if you're using an off the shelf header, then I wouldn't go over 2.5 since all of the off the shelf headers I've seen have collectors either 2 or 2.5 inches. If you are going to go the custom header route, then I would say it depends on what the ideal runner diameter is. Crunch the numbers, get the ideal diameter of the runners, and the collector and base the rest of your exhaust on that.
    Too big of an exhaust allows the gases to slow down more, which can actually create more resistance than a pipe that is a little bit too small.
    And on the eighth day, the Lord created the turbocharger
    Kings will never fall.
    - Tim, R.I.P
    Quote Originally Posted by UserName View Post
    If you got s14 problems I feel bad for you son, I got 99 problems but my s13 ain't one.
  5. #245
    Join Date
    May 2005
    Location
    St Petersburg
    Posts
    811
    Feedback Score
    11 (100%)
    I understand exactly what you refering to. Most header design theory I read expresses the need to keep velocity up on the escaping gases and the scavaging affect. It is a whole lot of voodoo if you ask me. Fluid dynamics... all that jazz. Add a custom ported head to the mix and you can change everyting. I do understand the basics though. No 3" inch for this car. 2.5 after the CAT. Because it will be supercharged the exhaust side will need to breath free, but not like a big dump for a turbo outlet.
    I may eventually have a custom N1 Dual type cat back on the car...but thats down the road. For now I just hope this header does its job and stays whole until the plate for the SC is finsihed.
    This weekend will be devoted to pulling a subframe. Next weekend the header will go on...I hope.
    -Royce
  6. #246
    Join Date
    May 2005
    Location
    St Petersburg
    Posts
    811
    Feedback Score
    11 (100%)
    -Royce
  7. #247
    Join Date
    May 2005
    Location
    St Petersburg
    Posts
    811
    Feedback Score
    11 (100%)
    From this past weekend...
    Subframe swap...
    I asked about it in the tech section and here are the results. I finally swapped my z32 knuckle, 4.36 180sx vlsd equipped subframe into the gold car from the blue shell. It was much easier than I anticipated. Considering that i do not have a lift and did the majority of the work by myself I thought 6 hours (including a lunch break) wasnt too bad. Keep in mind that I also repacked the bearings in the axles and installed a new transmission tail shaft seal while I was at it. Here are the pix...
    Positioning the jack under the blue shell...thankfully this jack is a monster. Working on the ground/sand is for the birds...but I improvised.
    For tools I used the following:
    1/2" Breaker Bar: w/ 17mm(for the subframe bolts adn brakes), 19mm(for your wheel lugs)
    3/8" socket wrench: w/ 10mm(for e-brake line brackets on the subframe), 12mm(for front subframe brackets)
    (optional - 14mm to seperate the input shafts and axles to repack bearings since its easy access)
    Large Flat head screwdriver (for the e-brake retaining clips on the rear calipers)
    17mm wrench for removing the rear brake calipers
    i bet there are a few I missed...but yeah. Surprisingly small tools list.
    First off...
    My subframe as it appeared in the blue hatch: Cross drilled s13 rotors, stock brakes, though I do have the z32 rear calipers ready to install (just need the z32 rear rotors). Z32 knuckles, and the background a 5 bolt axled 180sx vlsd, and 180sx rear swap-bar (not pictured)...
    The shocks are just Monroe's for a z32 w/ Megan springs. Also running 15mm Ichiba spacers and extended studs.
    Fast forward and i've already lowered the jack after removing the four(4) subframe nuts...still need to remove the brackets that hold the e-brake lines to the subframe.
    All pulled out of the way. PLease note the blue hatch does not have a gas tank in it so there was more room to work with that in your standard s13. Plus the exhaust was already removed too.
    Here is the subframe in all its glory.
    The bushing were not completely shot...but they are on their way out. I could get by with aluminium colars. I wonder if the same method for motor mounts would work on the subframe mounts. polyurethane window weld inside the bushing...then capped with the aluminum colars? FTW or FTL?? I might try it... this one below was the worst of the bunch. still centered and not free floating, but still noticably warn.
    You can see where the axles have been slinging white lithium grease out of the assembly (white stuff above the cap in the picture). So, I took this opportunity to re-pack the bearings while it was out and easy.
    Lifted the gold hatch (higher due to less clearance from exhaust and gas tank) to repeat the process with the other sub frame...
    I know I could have been more thorough with the pictures but here it is all up under the gold hatch. I still needed to install the rear shocks and brakes but all in all this was a slick swap. Tons easier swapping the assembly as a whole than it could have been piece by piece.
    So...whats next?
    Power and Paint...
    This thing now is a blast to drive again!!
    Thanks for looking...
    -Royce
  8. #248
    i has double turbo sean1 has a reputation beyond repute sean1 has a reputation beyond repute sean1 has a reputation beyond repute sean1 has a reputation beyond repute sean1 has a reputation beyond repute sean1 has a reputation beyond repute sean1 has a reputation beyond repute sean1 has a reputation beyond repute sean1 has a reputation beyond repute sean1 has a reputation beyond repute sean1 has a reputation beyond repute
    Join Date
    Aug 2005
    Location
    seffner
    Posts
    1,819
    Feedback Score
    13 (100%)
    looking good man, how much of a difference did the 4.36 make?
    my honda sounds like a lawnmower, because it is one.
  9. #249
    Join Date
    May 2005
    Location
    St Petersburg
    Posts
    811
    Feedback Score
    11 (100%)
    Since gold hatch had an open diff before, installing this makes the car feel much more planted in all situations. The 4.36 gearing makes better use of the KA's power band. the need to shift comes much quicker and it takes advantage of a KA's torque. There isnt a huge difference in gas mileage either. Though I would stick with a 4.08 if all i did was highway driving, I've been to the NC with it in the blue hatch and the mileage was around 25mpg...about 4mpg less than what i saw in with 4.08s on the same trip in the same car the previous year.
    It increases the cars grin factor...lol.
    -Royce
  10. #250
    Join Date
    Jan 2009
    Posts
    4,177
    Feedback Score
    glad to see the swap went so easily.
    I think it would have been much more of a pain to try to do everything a piece at a time.
    You're right about the bushings, you could do the window weld stuff if you wanted to.
    Since I started really researching how to build a 240sx "rat rod" style, I have had quite a few guys tell me that they did similar things like that to their cars Not that they really had subframes in those kinds of cars, but the concept is still the same. Had one guy tell me he used polyurethane and heavy zinc washers to make his own bushings. It is really neat to see how people did/do things when there isn't aftermarket parts to buy. It is a lot of the same stuff that we have all learned over the years with "budget builds" and all of that, figuring out what parts from others cars to use (like 300zx brake and diff swaps) but taken a bit further.
    I'm planning, when I finally get another 240 down the road, to do pretty much that same thing, A drill and polyurethane, and see how far I can get with all of the bushings on the car, including the subframe.
    How does the driving impression compare to the blue car? Feel the same yet?
    speaking of gearing and gas mileage and all of that, you know what someone should do? get the gearing of the 6 speed transmission they used in the camaros. the T-56 tranny i think. and compare that to the stock KA tranny and see how the 1-5 gears compare. If they are similar, then you would get the same kind of performance out of it with the 4.36 diff, but then be able to drop it into that 6th gear and have nice low rpms for highway cruising. Then you would have the best of both worlds.
    hows the supercharger set up coming along?
    - Tim, R.I.P
  11. #251
    Join Date
    May 2005
    Location
    St Petersburg
    Posts
    811
    Feedback Score
    11 (100%)
    Compared to the way the blue hatch used to feel its errie how similar it is. Because of the fewer miles on the chassis it seems a little tighter. Its somewhat noiser because I had to remove a fair amount of sound deadening during the install of the wiring harness and dash stuff, but not cazy noisy.
    As a side note...the blue hatch is going to be picked up soon...junk man is grabbing it, no one wanted it as a drift missile...
    I'd like to do a 240sx 6spd...but i hear the s15's 6spd is "weak"(? a realitive term i'm sure) and over priced. I spotted a vq trans with a KA bell housing welded to it in the KAT.org Weld and Fab section today. That would be killer. I know the camaro's 6spd 6th gear is an underdrive type, something like a 0.50:1.
    I'm having dinner with Jeff the CNC guy tomorrow. I'm going to ask that he just cut the plate for me. I think he wants to engineer the whole thing, but all i need is the plate cut and who ever I tap to do the welding of the intake will have to deal with that headache.
    I've seen KA intakes recently on Ebay that could be modified for my application...designing the "hot pipe" for the supercharger to the intercooler should prove interesting.
    -Royce
  12. #252
    Join Date
    Jan 2009
    Posts
    4,177
    Feedback Score
    thats actually really awesome that it is really similar. Maybe you swapped enough stuff over you managed to "catch its soul" in the process.
    thats because they want their drift missles to look awesome and be magazine cover cool, so they can wreck them into the wall. That is one thing I never understood about drifters. Why they spend so much money on the way the car looks, just to destroy it. I would have a more enjoyable time using 100 dollar bills to light my cigars rather than buy aero and a front end conversion for a drift car.
    That VQ swap is a pretty cool thing. I remember a few years ago, someone on here did it. Don't know how much stronger that tranny is compared to some other options, but i do remember that it has a bit more aggressive gearing than say a VG tranny. If I remember right, the VQ tranny ends up at the same place as the VG but it does it with shorter gearing, and therefore, more quickly.
    I think I'm gonna start comparing gear ratios. If/When I build another 240 (its been put off for now) I want to build a awesome street machine, but still have the comforts and gas mileage of a daily driver and I think that camaro 6 speed might just be the ticket. I figure it gets those guys mid 20-25 mpg on the highway, It ought to be really awesome for a decently built KA. If it is really awesome, then I might just copy your supercharger set up, once I get to that point. Gonna throw some money at my truck and my Z for now. Gonna save up for a 240 that way it can be a toy, not a necessity.
    Hopefully he can get that thing cut soon. I'm getting anxious to see this thing start to come together. lol.
    Have you thought about just taking the stock manifold, cutting it really short, and welding on the log?
    Wouldn't exactly be pretty, but it could give you something to work with as far as getting it together. could always step up to something nicer down the road. Never know, you might find that you have to do things differently once you start getting it bolted together, and chopping up the stock manifold could save you some cash.
    as for the hot pipe, I can't remember exactly the route that it needed to go in, but you might look at stock 300zx piping. There are some sections that have the bends and everything that you might need and they are supposed to be good for something crazy like 500 whp.
    - Tim, R.I.P
  13. #253
    Join Date
    May 2005
    Location
    St Petersburg
    Posts
    811
    Feedback Score
    11 (100%)
    I've set up time to meet Jeff @ his house. He's about as excited as I am to get this thing off the ground. And probably make room in his garage...lol. Since he has the SC and a spare KA intake I gave him too we will be able the map out a plan to get it cut on his CNC machine. Jeff knows his stuff...he's suggesting a different grade of aluminum that disippates heat better and is less prowned to warping. Good Stuff!!
    -Royce
  14. #254
    Registered User P3RF3CTSHiFT is an unknown quantity at this point P3RF3CTSHiFT's Avatar
    Join Date
    Jan 2012
    Posts
    38
    Feedback Score
    I read this from beginning to present, what a build my friend, you've overcome some hella crazy obstacles too, I canNOT wait to see a supercharger on this thing, plain jane is coming along great, keep it up!
    Brotip #28
    Be careful what you wish for, bro. Remember, Simba "just couldn't wait to be king", then his dad got fucking DEALT with.
  15. #255
    Join Date
    May 2005
    Location
    St Petersburg
    Posts
    811
    Feedback Score
    11 (100%)
    Thanks so much P3rf3ctshift. I always appreciate the kudos from those that post in here. You hit it on the head too when you said this has been a hell of a process.
    The SC has been in the works for such a long time I'm super anxious myself. If I had not wrecked the blue car I might already be showing the finished product. I'll be focusing on that instead of making plain jane look pretty for the time being. I just replaced janes nasty rear bumper with the one from the blue hatch over the weekend. There are just a few more Items to swap over before the parts transfer is complete. Its very sad seeing the remains of the blue hatch in the yard...but i'm in agreement with Empire when he said some of the soul of the blue hatch has tranferred over.
    more pix to come soon...
    -Royce
Thread Information
Users Browsing this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204
