+ Reply to Thread
Page 4 of 65 FirstFirst 1 2 3 4 5 6 7 14 54 ... LastLast
Results 46 to 60 of 974
Thread: 2jz stage two
  1. #46
    Registered User BABILLARACING has a reputation beyond repute BABILLARACING has a reputation beyond repute BABILLARACING has a reputation beyond repute BABILLARACING has a reputation beyond repute BABILLARACING has a reputation beyond repute BABILLARACING has a reputation beyond repute BABILLARACING has a reputation beyond repute BABILLARACING has a reputation beyond repute BABILLARACING has a reputation beyond repute BABILLARACING has a reputation beyond repute BABILLARACING has a reputation beyond repute BABILLARACING's Avatar
    Join Date
    May 2005
    Posts
    3,052
    Feedback Score
    15 (94%)
    I did'nt do much today but here you go
    battery relocator box
    and finished to cut the holes for the cam gears
  2. #47
    Join Date
    May 2005
    Posts
    3,052
    Feedback Score
    15 (94%)
    today I redid the mounts cause I did'nt like the other ones (I am waiting for the supra ones to do the motor mounts again )
    old one
    new one in the making
    almost done
    done and painted
    installed (you can see a glimse of the exhaust I am making the magnaflow pipe be here monday )
    where the sifter sits
  3. #48
    i love drifting turbodorifto has a reputation beyond repute turbodorifto has a reputation beyond repute turbodorifto has a reputation beyond repute turbodorifto has a reputation beyond repute turbodorifto has a reputation beyond repute turbodorifto has a reputation beyond repute turbodorifto has a reputation beyond repute turbodorifto has a reputation beyond repute turbodorifto has a reputation beyond repute turbodorifto has a reputation beyond repute turbodorifto has a reputation beyond repute turbodorifto's Avatar
    Join Date
    May 2007
    Location
    my home..
    Posts
    1,142
    Feedback Score
    2 (75%)
    very nice build so far bro.. gl
    RB26dett s14 in progress
  4. #49
    Join Date
    May 2005
    Posts
    3,052
    Feedback Score
    15 (94%)
    thanks man
  5. #50
    Join Date
    May 2005
    Posts
    3,052
    Feedback Score
    15 (94%)
    here is what I did today not much but some progress . The shop was busy as hell today
    shifter installed
    flex pipe installed and bung for the wideband( it can't be seen in this angle)
    exhaust the way I want it as closed to the chassis as possible with out touching it
  6. #51
    Join Date
    May 2005
    Posts
    3,052
    Feedback Score
    15 (94%)
    I re did the cross memberr mounts this time I used the supra mounts instead of the 240
    the first one I did
    the second version
    first version of tranny mount
    second version
    fan clearance with new set up
    crossmember clearance
    finish the exhaust also
    installing the cooler
  7. #52
    Join Date
    May 2005
    Posts
    3,052
    Feedback Score
    15 (94%)
    today I had some time to finish the intercooler piping amd started working on the fuel supply
    here is the first time I let it go to the floor since I put the 2j on it it sits so low that I think I got to put stock spring for now while I gather some more money for the coilovers
    also I am installing a supra (denso) fuel pump but when I pulled out the one on the car Is as big as the denso , does anybody got a picture of the stock s14 fuel pump? cause the one on the car the only marking I saw it said jecs made in japan .I want to see is that is the stock one or an aftermarket
  8. #53
    Retired Epstein has a reputation beyond repute Epstein has a reputation beyond repute Epstein has a reputation beyond repute Epstein has a reputation beyond repute Epstein has a reputation beyond repute Epstein has a reputation beyond repute Epstein has a reputation beyond repute Epstein has a reputation beyond repute Epstein has a reputation beyond repute Epstein has a reputation beyond repute Epstein has a reputation beyond repute Epstein's Avatar
    Join Date
    Jan 2003
    Location
    Clearwater
    Posts
    6,343
    Feedback Score
    20 (95%)
    You're doing some great work there! Please keep the pics and updates coming.
    External size of the pump doesn't matter. The stock jecs pump is rather large for it's size. If it does say jecs on it, then it's stock. The only other Jecs pumps in use would be a Z32 pump or a Tomei pump. Both are uncommon swaps to say the least.
  9. #54
    FORE:sight longfellow2 has a reputation beyond repute longfellow2 has a reputation beyond repute longfellow2 has a reputation beyond repute longfellow2 has a reputation beyond repute longfellow2 has a reputation beyond repute longfellow2 has a reputation beyond repute longfellow2 has a reputation beyond repute longfellow2 has a reputation beyond repute longfellow2 has a reputation beyond repute longfellow2 has a reputation beyond repute longfellow2 has a reputation beyond repute longfellow2's Avatar
    Join Date
    Dec 2007
    Posts
    3,317
    Feedback Score
    3 (100%)
    Those are some heavy duty welds! What type of welder are you using? It almost looks like an Arc because of the size/thickness of the beads.
    Quote Originally Posted by Epstein View Post
  10. #55
    Join Date
    May 2005
    Posts
    3,052
    Feedback Score
    15 (94%)
    Thanks Epestein for the information and the copliments
    longfellow2 is a miller 110 mig welder(I dont remember the model if you need it I found out) the trick is butter the welds
    instead of circular motion or back and forth , move your wrist semi circle and do it a little bit quick and that will do the trick..hope this help..Omar
  11. #56
    Join Date
    May 2005
    Posts
    3,052
    Feedback Score
    15 (94%)
    today I finished the coolant system
    fuel pump denso supra fuel pump
    fuel lines transfer from passenger side to driver side (this is temporal cause I am planning to upgrade the fuel system,turbo and intake on couple of months)
  12. #57
    Join Date
    May 2005
    Posts
    3,052
    Feedback Score
    15 (94%)
    today I had sometime to work on the car
    modified 2j acelerator cable to work with s14 cable and cruise control
    cruise control server installed in the opossite side of engine bay
    fuel line system done (it will be temporary till I convert to single turbo and update fuel lines
    fuel filter relocated
    I did'nt take pictures of it but I by passed the heater core till I conver to single no room for the hoses
    tomorrow I gonna work on the fuel pump relay and hopefully order the drive shaft
  13. #58
    Function is my form. 240Cyanide has a reputation beyond repute 240Cyanide has a reputation beyond repute 240Cyanide has a reputation beyond repute 240Cyanide has a reputation beyond repute 240Cyanide has a reputation beyond repute 240Cyanide has a reputation beyond repute 240Cyanide has a reputation beyond repute 240Cyanide has a reputation beyond repute 240Cyanide has a reputation beyond repute 240Cyanide has a reputation beyond repute 240Cyanide has a reputation beyond repute 240Cyanide's Avatar
    Join Date
    Jan 2008
    Location
    ocala
    Posts
    9,673
    Feedback Score
    3 (100%)
    i love when someone actually does something right on TR. looks good
  14. #59
    Join Date
    May 2005
    Posts
    3,052
    Feedback Score
    15 (94%)
    thanks man glad you like it.............Omar
  15. #60
    Join Date
    May 2005
    Posts
    3,052
    Feedback Score
    15 (94%)
    yesterday I wnt I pick up some prosport gauges and today I made the console for the gauges
    hopefully this weekend if I have time I will be starting the car and by mid next week the driveshaft will be done (waiting on the tranny yoke coming from california)
Thread Information
Users Browsing this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201
