help 1g eclipse
help 1g eclipse
I went to drive the car and the idle started acting funny like it wanted to shut off. Then it started acting like the tps was screwed up when i held it at part throttle then after 2500 it would clear uo untill 4500 where it started break up. I took it back home and tried to adjust my idle which barely helped and checked my tps which was fine started the car up and now i cant even drive it. Cyl 4 and 3 header tubes are cold. So i changed plugs and same shit. So i took off my coil on plug setup and put on my oem coil pack and new plug wires and same shit. Checked power tr unit and its fine. Check injectors and they ohm fine as well. Wtf is goin on? I have a feeling its not getting spark but dont have anybody to turn the car over while i check spark. Please help
thezsez
07-28-2008 05:43 AM
6gcivic
Car Audio For Sale
11
07-09-2007 03:50 AM
