+ Reply to Thread
Results 1 to 11 of 11
  1. #1
    Registered User srtboy2 is an unknown quantity at this point
    Join Date
    Feb 2010
    Posts
    112
    Feedback Score
    SAFCII is it good for tuning ???
    should i buy SAFCII to tune a eagle talon ??
    [IMG][/IMG] NEW BABIIE on da road
  2. #2
    Registered User cjackson2802 has a reputation beyond repute cjackson2802 has a reputation beyond repute cjackson2802 has a reputation beyond repute cjackson2802 has a reputation beyond repute cjackson2802 has a reputation beyond repute cjackson2802 has a reputation beyond repute cjackson2802 has a reputation beyond repute cjackson2802 has a reputation beyond repute cjackson2802 has a reputation beyond repute cjackson2802 has a reputation beyond repute cjackson2802 has a reputation beyond repute
    Join Date
    Sep 2009
    Location
    Spring Hill
    Posts
    1,120
    Feedback Score
    yeah if you just have 550cc's. even 650's. i had 780cc's, we set my gm maf-t for 650's and tuned the rest out. its just a piggy back, and will work great on a 16g setup or less. anything more, you're better off with ecmlink. you're pretty much just adding boost and fuel on stock timing. i had a big16g at 25 psi with an safc. spooled fast, and hit hard. never had a single issue.
  3. #3
    Non DSM.....DSM guy Tom N has a reputation beyond repute Tom N has a reputation beyond repute Tom N has a reputation beyond repute Tom N has a reputation beyond repute Tom N has a reputation beyond repute Tom N has a reputation beyond repute Tom N has a reputation beyond repute Tom N has a reputation beyond repute Tom N has a reputation beyond repute Tom N has a reputation beyond repute Tom N has a reputation beyond repute Tom N's Avatar
    Join Date
    Apr 2002
    Location
    North Port, Fl
    Posts
    3,982
    Feedback Score
    An AFC alters the airflow table. It is tricking the ecu into think the car is getting more or less air than it really is. The Ecu then adjusts fuel as well as timing based on adjustments you make with the AFC. It does not adjust the actual fuel map.
    Tom N
    94 Mitsubishi EVO I ( no times yet )
    91 Galant VR-4
    11.497 @ 119.55 (16g power)
  4. #4
    Join Date
    Sep 2009
    Location
    Spring Hill
    Posts
    1,120
    Feedback Score
    Quote Originally Posted by Tom N View Post
    Technically you're adding fuel buy putting bigger injectors in, and then adjusting the fuel delivery by tricking the ecu through the air flow signal.
  5. #5
    Join Date
    Apr 2002
    Location
    North Port, Fl
    Posts
    3,982
    Feedback Score
    He didnt say he was putting bigger injectors in nor do they have any bearing on what a AFC does. I`m not sure if this guy understands what a AFC does so I am making sure he does. Many think a AFC actually adjusts the fuel table and it doesnt. Under wot the car has a fuel table and timing table that uses rpm and airflow to decide how much fuel and timing to use. A AFC is manipulating the airflow signal that goes to the ecu. When you make an adjustment in the AFC it is altering the actual air flow reading the car is getting and in turn it is altering the fuel table as well as the timing table the car will use. It does not just affect fuel. You lean a car down with a afc you are also adding timing in most cases.
    Tom N
    91 Galant VR-4
  6. #6
    Join Date
    Feb 2010
    Posts
    112
    Feedback Score
    i am putting 650 injector on it ,, they told me to use the black one ?
  7. #7
    35.5 psi, stock sleeves BluRRboSi has a reputation beyond repute BluRRboSi has a reputation beyond repute BluRRboSi has a reputation beyond repute BluRRboSi has a reputation beyond repute BluRRboSi has a reputation beyond repute BluRRboSi has a reputation beyond repute BluRRboSi has a reputation beyond repute BluRRboSi has a reputation beyond repute BluRRboSi has a reputation beyond repute BluRRboSi has a reputation beyond repute BluRRboSi has a reputation beyond repute BluRRboSi's Avatar
    Join Date
    Jan 2005
    Location
    Haterville
    Posts
    1,886
    Feedback Score
    Have tuned many afc setups... Always tell the customer before they leave to start saving for a REAL management option. Period.
    Does it work, yes.
    If you have not bought it, I recommend saving a bit more for a better system that you will not have to eventually replace anyways.
    Purebred Performance Engineering
    Fabrication & Tuning Services
    813-451-7547 or 813-712-0202
  8. #8
    Join Date
    Sep 2009
    Location
    Spring Hill
    Posts
    1,120
    Feedback Score
    Tom, most people only use safc's when putting bigger injectors in, I think they are pointless with stock injectors.
    and it is plenty of management for a 16g setup. Why spend 500+ on an engine management system for a daily driven car when a piggy back will work just fine. It all depends on the person's goals.
  9. #9
    Probably $#%#ing broke. blackFLgst has a reputation beyond repute blackFLgst has a reputation beyond repute blackFLgst has a reputation beyond repute blackFLgst has a reputation beyond repute blackFLgst has a reputation beyond repute blackFLgst has a reputation beyond repute blackFLgst has a reputation beyond repute blackFLgst has a reputation beyond repute blackFLgst has a reputation beyond repute blackFLgst has a reputation beyond repute blackFLgst has a reputation beyond repute blackFLgst's Avatar
    Join Date
    Feb 2007
    Location
    Tampa, FL, Middle of Nowhere, Kansas, Martinsville, VA. 6 Acre FOB, Iraq, Wishing I Was Somewhere Else - Afghanistan.
    Posts
    1,264
    Feedback Score
    4 (100%)
    Because you got into cars for A reason. Why go for cheap parts? I had the black one in my 2g and I about ripped it out and ran it over. All its good for is cool factor for having sweet blue lights. Much like the nb02 sensor.
    REDLEG
    13F
    Trailblazer SS AWD
    2004 G35 Coupe
    Project "No-Traction" 1g DSM
    Mods: A bigger shot than your car has HP
  10. #10
    Join Date
    Feb 2010
    Posts
    112
    Feedback Score
    i have a safc right now but i am saving up to get either a aem or a microtech either one.. its just for now . since its going to be my dail driver. . i was wondering can i use a 2g aem on a 1g motor ??
  11. #11
    Join Date
    Apr 2002
    Location
    North Port, Fl
    Posts
    3,982
    Feedback Score
    If you are asking question about a AFC, a AEM or microtec probably isn't for you at this time.
    A 2g plug n play AEM is for a car with a 2g wiring harness.
    Tom N
    91 Galant VR-4
Thread Information
Users Browsing this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204
