+ Reply to Thread
Page 3 of 3 FirstFirst 1 2 3
Results 31 to 45 of 45
  1. #31
    Registered User lancerman has a reputation beyond repute lancerman has a reputation beyond repute lancerman has a reputation beyond repute lancerman has a reputation beyond repute lancerman has a reputation beyond repute lancerman has a reputation beyond repute lancerman has a reputation beyond repute lancerman has a reputation beyond repute lancerman has a reputation beyond repute lancerman has a reputation beyond repute lancerman has a reputation beyond repute
    Join Date
    Jul 2002
    Location
    tampa
    Posts
    1,852
    Feedback Score
    7 (89%)
    its a relief that I can continue to play without a major step back. but just cant figure out where the problem lies. swapped in flaco ecu today with same result. going bonkers on this one...
    my favorite quote
  2. #32
    Registered User Boost Demon is an unknown quantity at this point
    Join Date
    Jun 2010
    Posts
    141
    Feedback Score
    Maybe try putting your normal UICP on until you get that injector driver box?
  3. #33
    Join Date
    Jul 2002
    Location
    tampa
    Posts
    1,852
    Feedback Score
    7 (89%)
    Quote Originally Posted by Boost Demon View Post
    I dont have injection wired in at the moment. the misfire is still there. no 2 injector just stops firing. I can plug in known good injector and it doesnt click. wiring problem of some sort. just doesnt make sense that the problem goes away when car is shut off for a minute. then it returns after 1-10 minutes of run time. tried a second ecu today and it made no change to problem.
    my favorite quote
  4. #34
    JR.
    JR. is offline
    Registered User JR. has a reputation beyond repute JR. has a reputation beyond repute JR. has a reputation beyond repute JR. has a reputation beyond repute JR. has a reputation beyond repute JR. has a reputation beyond repute JR. has a reputation beyond repute JR. has a reputation beyond repute JR. has a reputation beyond repute JR. has a reputation beyond repute JR. has a reputation beyond repute
    Join Date
    Jan 2006
    Location
    W. TAMPA
    Posts
    5,927
    Feedback Score
    13 (100%)
    Is those kind of problems that will make a dsmer part out his car, but knowing Jerry he will figure this out in a couple days.
    98 talon awd automagic
  5. #35
    Registered User cjackson2802 has a reputation beyond repute cjackson2802 has a reputation beyond repute cjackson2802 has a reputation beyond repute cjackson2802 has a reputation beyond repute cjackson2802 has a reputation beyond repute cjackson2802 has a reputation beyond repute cjackson2802 has a reputation beyond repute cjackson2802 has a reputation beyond repute cjackson2802 has a reputation beyond repute cjackson2802 has a reputation beyond repute cjackson2802 has a reputation beyond repute
    Join Date
    Sep 2009
    Location
    Spring Hill
    Posts
    1,120
    Feedback Score
    Quote Originally Posted by lancerman View Post
    could your resistor pack be the culprit? only other thing that controls injectors is the mpi, ecu, cas right?
  6. #36
    Join Date
    Jul 2002
    Location
    tampa
    Posts
    1,852
    Feedback Score
    7 (89%)
    was gonna try resistor pack today, that is a good possibilty
    my favorite quote
  7. #37
    Join Date
    Sep 2009
    Location
    Spring Hill
    Posts
    1,120
    Feedback Score
    yeah most likely. you have hall effect cas, swapped ecu, and if it was mpi you wouldnt have power to any of the injectors
  8. #38
    Join Date
    Jul 2002
    Location
    tampa
    Posts
    1,852
    Feedback Score
    7 (89%)
    had high hopes on the resistor pack. seems a failing one could cause same symptoms. but that didnt fix it.
    my favorite quote
  9. #39
    Join Date
    Sep 2009
    Location
    Spring Hill
    Posts
    1,120
    Feedback Score
    Take the next step. Drive it until #2 stops firing, and then see if you're getting any power to the injector clip. If you are getting power but its not pulsing then its either CAS or break in a wire. If you're not getting power then maybe mpi relay? Ive had a similar problem before, never found the culprit...I unplugged my whole engine harness, plugged everything back in and never had the problem again...lol
  10. #40
    Registered User danameisoj has a reputation beyond repute danameisoj has a reputation beyond repute danameisoj has a reputation beyond repute danameisoj has a reputation beyond repute danameisoj has a reputation beyond repute danameisoj has a reputation beyond repute danameisoj has a reputation beyond repute danameisoj has a reputation beyond repute danameisoj has a reputation beyond repute danameisoj has a reputation beyond repute danameisoj has a reputation beyond repute
    Join Date
    Sep 2005
    Location
    Spring hill
    Posts
    787
    Feedback Score
    4 (100%)
    you might have 2 different problems to occur this. (resistance or exposed wiring) or both combined.
    electricity will follow path of least resistance. check to see if you have any exposed sections of that portion of the harness. Excessive resistance could cause this to happen. If its exposed it could ground itself to where ever its open rather than the circuit doing it job.
    For the car to be working normally than shutting down its sounding like something is getting to hot and finding another way out or shutting itself down.
    NATT Certified
  11. #41
    Join Date
    Jun 2010
    Posts
    141
    Feedback Score
    Could an injector(s) have been overloaded somehow by not using a driver box?, or would that have caused the resistor pack to go bad (which sounds like it's been checked already and is okay?) I don't know if injectors can go bad in this way, but I thought I'd just throw it out there. Good luck man.
  12. #42
    Join Date
    Jul 2002
    Location
    tampa
    Posts
    1,852
    Feedback Score
    7 (89%)
    only the 2 added injectors in I/C pipe are running without resistor. the relay can handle 32 amps constant. plus the injectors only run under boost and are super cooled with ethanol. not too worried about them failing. the problem I am having is with the main injector #2 which stops firing. the injector itself is fine.
    my favorite quote
  13. #43
    Join Date
    Jul 2002
    Location
    tampa
    Posts
    1,852
    Feedback Score
    7 (89%)
    I figured this problem out on thursday. whenever you run a 1g cam sensor with a 2g ecu it will cause the ecu to throw misfire code. the reason I didnt find it sooner was because the car ran fine without throwing a code for two years. I did think to disable the DTC but when I did I think the car stalled after a pull and the checked box was not saved to permanent memory. It misfired shortly thereafter. I reenabled the checked box and kept searching for answers. So I was basically thrown two major curve balls here. But I am back on track now after five wasted days..
    finally felt boost again this morning with 70 degree intake temps. previously around 95. power band hits HARD. really impressed with the setup now.
    my favorite quote
  14. #44
    Join Date
    Jul 2002
    Location
    tampa
    Posts
    1,852
    Feedback Score
    7 (89%)
    Modding on hold for a couple weeks. New plans before final tuning are for port injection. secondary rail is from VW. Primary rail new found composite.
    Gonna be a little bit of work. But the improvements will be worth the effort.
    my favorite quote
  15. #45
    Join Date
    Jun 2010
    Posts
    141
    Feedback Score
    So your gonna use your custom meth setup and two sets of injectors? I saw on another forum that you said you found that black composite rail in a Sonata, nice find, hope you can use the flanges and it can take the pressue, could be a nice secondary rail for cheap if it works.
Thread Information
Users Browsing this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204
