clutch replacement
on
clutch replacement
I got the car not to long ago but the guy I got it from put a clutch from autozone in it now im hoping to replace it with a act 2100lb clutch trying to find out what i'm in for?? What will I have to remove to do the job?? also why i have the trans out im going to do a Stainless Steel Clutch Line, how do i do this as well???? Thanks for the help.
i'll try to type it up as if it were in a Chiltons.
"remove tranny"
"remove clutch"
"install clutch"
"install tranny"
lol
friggin hanes manual,
"remove tranny"
"remove clutch"
"install clutch"
"install tranny"
lol
slowy and I have done it a few times. is it a AWD or FWD ??? FWD's are cake, my best advice is to make sure you use proper torque specs on the flywheel and more importantly the pressure plate. your flywheel must be resurfaced. it can be a pretty involved job because the axles need to come off the tranny, which means the some of the suspension/control arm needs to come apart. it might sound like alot but if you kinda have an idea of the direction you need to go it can be done somewhat quickly, slowy and I have done it in less then 3 hours.
Also if you have the tranny off it might be a good idea to take the end cover off and tighten up the bolt on the end of the 5th gear, This might tighten up some of the play in the shifter. use RTV when re-assembling.
OP.... you can put what kind of CAR you drive in your profile information so people don't have to ask you what kind of car you drive. it would also help to get better/more detailed answers
Originally Posted by Evil_GST;6082801...
Also if you have the tranny off it might be a good idea to take the end cover off and tighten up the bolt on the end of the 5th gear, This might tighten up some of the play in the shifter. use RTV when re-assembling.[IMG
http://i146.photobucket.com/albums/r246/Tbalestrini/Cars/synco2-1.jpg[/IMG]
That is very good advice. Make sure to re set the part that locks the nut on there (you can see the notched area on the nut circled in red) I learned it the hard way. I was driving my car and noticed that my shifter would move when I would take my foot off of the gas pedal. When I got home (about 25 miles later) I noticed a funny smell. I walked around the back of my car and noticed all $40 worth of my 500mile-old Royal Purple Synchromax sitting under my car.
The nut backed off and cracked that end cover (which can be a difficult part to find) and it chewed up my 5th gear synchro.
