Forums Register TRHelp TRGarage TRader Ratings Classifieds Search Today's Posts Mark Forums Read Calendar
iTrader Mainpage
Browse All Members
FAQ Gallery Weather Log Out
Go Back   Tampa Racing > Technical Forums > Mitsubishi Tech
Old 10-06-2008, 11:04 AM   #1 (permalink)
Car:
Needfstwheelz has a reputation beyond repute: 34554052
TO4B 47 Trim.....help
This is the turbo im planning to put on my car in the next 2 weeks...but i havent heard anything good about it except from guys where im planning to have it installed at...it supports 380-400 hp safely and whet im trying to figure out is if this is a better option for a stock 2g as oppose to a small mhi 16g turbo.. any opinion/guidance would be helpfull..
Last edited by Needfstwheelz : 10-06-2008 at 11:10 AM. Reason: fear of being looked at as a retard...
Needfstwheelz is offline
Old 10-06-2008, 11:18 AM   #2 (permalink)
Car:
GRez has a reputation beyond repute: 517472390
Too small!
GRez is offline
Old 10-06-2008, 11:21 AM   #3 (permalink)
Car:
and also my other question is, ive seen some turbos with the intake directley onto the turbine wheel, obviously i cant do that (MAF) or is there a way other than the obvious translator??? is it even worth the effort ? keep in mind i still have stock intake...stock everything minus some ic piping....
Old 10-06-2008, 11:22 AM   #4 (permalink)
Car:
Too small...can i get a little more info...i heard it can give you 20g power with a 16 g spool up...do you mean the tubine is to small? because im pretty sure its bigger than one on a stock t-25
Old 10-06-2008, 11:58 AM   #5 (permalink)
Street racing is 4 ricers
Car: 1990 GS-T
Under The Hood
Todd's90 has a reputation beyond repute: 149493420
is your car FWD or 4WD?
Todd's90 is offline
Old 10-06-2008, 11:59 AM   #6 (permalink)
Throwback
Car: Mitsubishi GSX
Clearwater
Skip has a reputation beyond repute: 12364100
I installed this turbo on a evo 16g car. There was a noticeable gain, not huge, but noticeable. Both where at the same psi. Spool was nearly identical. Not a bad turbo for about the same cost of a 16g. It bolts up and is internally gated, no coolant lines, you have to modify for the oil lines and fan clearance.
I personally would save a few more pennies and get something bigger like a 50 trim or 35r (or anything ball bearing).
Skip is offline
Old 10-06-2008, 12:04 PM   #7 (permalink)
Car:
tru...any specific place i should order from?? im having a hard time finding sites that seem credible
Old 10-06-2008, 12:06 PM   #8 (permalink)
crankwalk
Car: 4 cyl. knight rider, Oh and a 1g
Palm Harbor
blackFLgst has a reputation beyond repute: 117823443
extremepsi.com slowboyracing.com maperformance.com
extremepsi and maperformance are my 2 favortite places to order from. Customer service is amazing and the shipping is unbelievably quick.
blackFLgst is offline
Old 10-06-2008, 12:07 PM   #9 (permalink)
Car:
and its fwd
Old 10-06-2008, 01:27 PM   #10 (permalink)
JR.
Car: 89 dodge colt & 98 cavy (dd)
W. TAMPA
JR. has a reputation beyond repute: 440077010
i would go with a 50 trim or even a 60 trim.
JR. is offline
Old 10-06-2008, 01:52 PM   #11 (permalink)
Car: 1990 GS-T
Under The Hood
a 30R would be nice if you have the money
Todd's90 is offline
Old 10-06-2008, 05:59 PM   #12 (permalink)
Car:
whats the downfall of having stock fuel injectors after upgrading my turbo to something like this?
Old 10-06-2008, 06:11 PM   #13 (permalink)
ryu
Evo IX FTW!
Car: 06 Evo IX
Sping Hill, FL
ryu has a reputation beyond repute: 51083265
Maxed out fuel injectors to where you are not able to use the full potential of the turbo because it will make you run too lean.
ryu is offline
Old 10-06-2008, 06:15 PM   #14 (permalink)
Car:
so for the 47 trim...how big of injectors should i run with
Old 10-06-2008, 06:25 PM   #15 (permalink)
crankwalk
Palm Harbor
id say you would be good with 680s or 720s
Sponsored Links
