#1 (permalink) |
Street racing is 4 ricers
Car: 1990 GS-T
Under The Hood
: 149493420 |
Update on my progesss.
How important is it to get the head resurfaced
when replacing the head gasket?? the car overheated for about 10 min but the coolant temp never went above 247, I don't know how high the temp goes before the head can warp, I will be using a felpro gasket and ARP studs, not getting the head milled will help me out a whole lot with money and time because this is my only transportation to work. Last edited by Todd's90 : 10-08-2008 at 04:53 PM. |
#2 (permalink) |
Car:
: 69985215 |
My Car Over heated for a month straight and atleast to the point where on a couple of occasions it wouldnt restart for an hour. But after finally figuring out it was the headgasket I replaced it and everything was perfect and the car pulled harder then ever....So I guess its just a roll of a dice, So if funds permit do it right the first time.
#3 (permalink) | |
Car: 1990 GS-T
Under The Hood
: 149493420 |
Quote:
what machine shops around here are trusted to do it right and what does it normally run. I'm going to start tearing into her in the morning. |
#9 (permalink) |
Car: 1990 GS-T
Under The Hood
: 149493420 |
how much of the turbo do i need to disconnect to get the manifold off of the head? I got the front water line and top oil line off, do i need to disconnect the oil drain and downpipe so the manifold will clear the studs on the head?
#10 (permalink) |
Dsm Addict
Car: 91 X2S,00 Civic Coupe(daily)
Bartow
: 294855430 |
Take the whole turbo off.Dont run the risk of bending a 18 year old return and feed line and getting a leak when its all said and done.Thats just the way i have always done it since its easier to me.
#11 (permalink) |
Car: 1990 GS-T
Under The Hood
: 149493420 |
1.5 hours ago:
![]() This is the mess I was left with, Oil/Water on everything. ![]() Now: ![]() Looks like their might be some rain headed my way. this is bullshit, it does not rain all week and so far it has rained on both days I have tried to work on the car. at least at the end of the day I will have the piece and mind of a new headgasket and ARP headstuds
#13 (permalink) |
Car: 1990 GS-T
Under The Hood
: 149493420 |
I'm at slowy's house. he's on mlk near the interstate. hopefully he will be able to help when he gets home but right now it keeps sprinkling on and off so it's hard to get crank'n on it. I might be able to get the head off today but the machine shop will probally be closed so nothing will get done after i get the head off. were the help will come in handy is putting everything back together but I don't know how long the head will be in the shop. I'll pm you my number so I can give you direction and let you know when I might need help getting it all back together, it's appriciated.
#15 (permalink) |
Car: 1990 GS-T
Under The Hood
: 149493420 |
Had to pack it up for the night, only had a few hours to work on it today due to shitty rain. you know you love a car when your sad to leave it somewhere
If im lucky the head will be flat when I get it checked and I could have it back on tomorrow. |
| Sponsored Links |
