+ Reply to Thread
Results 1 to 6 of 6
  1. #1
    Elitist Supra Asshole :) flubyux2 has a reputation beyond repute flubyux2 has a reputation beyond repute flubyux2 has a reputation beyond repute flubyux2 has a reputation beyond repute flubyux2 has a reputation beyond repute flubyux2 has a reputation beyond repute flubyux2 has a reputation beyond repute flubyux2 has a reputation beyond repute flubyux2 has a reputation beyond repute flubyux2 has a reputation beyond repute flubyux2 has a reputation beyond repute flubyux2's Avatar
    Join Date
    Jun 2003
    Location
    "Teh Hill"
    Posts
    2,629
    Feedback Score
    3 (100%)
    StarQuest G54BT DOHC head... Under R&D NOW!
    Yea, you read it right! My friend Kevin back in Ohio informed me recently that a member of his StarQuest forum has aquired an ORIGINAL HKS DOHC head designed for the G54 SOHC engine...the intial investment to get the ball rolling is $12,000 for R&D. The first run will yeild 20 units, @ ~$2000 each. each run thereafter will cost less. the intiial investors will also see a price break as well as profit sharing from non-intial investors (customers).
    this Head will be BETTER than the original HK$ version, as it will be cut from a solid piece of Billet aluminum, CNC'd design. There are SS valves already available for it, the Cams are already able to be produced, the hardware will be the same, only twice as much as before. And, cam gears are the same as stock... you just need a 2nd one. an appropriate length timing chain will be available. You can use all the stock gaskets, sheet metal valve covers will be produced. the seats are already installed and come with a 3angle valve job. and itll be threaded for NGK plugs.
    Only 40% of the design of the NEW head will be based off the original HK$ design, so its small enough to be considered an ORIGINAL design and have its own Patent number. the Original HK$ version was originally designed for a G54/G52 NA hybrid motor which had a 2.3L Diesel crank in it, which were used in the IMSA/GTU race classes... same series as the NA FC3S
    OH, and this new head will yeild a projected 18% increase in VE, all else remaining stock... including boost level on the 12A turbo.
    John's DOHC head webpage
  2. #2
    Chowdah-head PoppaSmurf has  hit bottom,  and can only go up! PoppaSmurf has  hit bottom,  and can only go up! PoppaSmurf has  hit bottom,  and can only go up! PoppaSmurf has  hit bottom,  and can only go up! PoppaSmurf has  hit bottom,  and can only go up! PoppaSmurf has  hit bottom,  and can only go up! PoppaSmurf has  hit bottom,  and can only go up! PoppaSmurf has  hit bottom,  and can only go up! PoppaSmurf has  hit bottom,  and can only go up! PoppaSmurf has  hit bottom,  and can only go up! PoppaSmurf has  hit bottom,  and can only go up! PoppaSmurf's Avatar
    Join Date
    Nov 2002
    Location
    12,000 feet above sea level
    Posts
    4,356
    Feedback Score
    1 (100%)
    anyone considering really modding a starquest should really look into this, the twin cam head would basically make 4G63 swapping obsolete, as the motor would retain its torquey traits, and recieve such a large increase in the overall volumetric efficiency of the motor..
    Poppa J. Smurf
    AIM-poppasmirf67
  3. #3
    Join Date
    Jun 2003
    Location
    "Teh Hill"
    Posts
    2,629
    Feedback Score
    3 (100%)
    ... i already sent Joey a PM w/ the link in it... hes gonna abandon supras
    next thing you know, peole are gonna be like "screw G4CS/G64, how do i put a G54 in my AWD???"
  4. #4
    tractionless MadisFastDSM is an unknown quantity at this point
    Join Date
    Sep 2002
    Posts
    322
    Feedback Score
    -1 (0%)
    i will be purchasing this head asap for my starion.... at the same time i will rebuild my bottom end so its super sick instead of just sick.... the 4g63 swap in a starquest is alot of fabrication anyways
    collision and refinising technician need bodywork/ paint call 727 776 7830
  5. #5
    Join Date
    Jun 2003
    Location
    "Teh Hill"
    Posts
    2,629
    Feedback Score
    3 (100%)
    actually, buschur has a set of mounts that he produces requierd to swap in a G63 motor into the StarQuest... the only problem is finding a Euro/Oz spec RWD G63 tranny to bolt in... :o My friend Kevin was stationed in London w/ the Airforce last fall, he went to some races and they were running starions over there. They have 4g63-equipped Starions over there, he was trying to find a few RWD trannies for us to send back... but no luck.
    anywho... i would so love to invest in this project... except im broke... i want to make a difference!
  6. #6
    Join Date
    Sep 2002
    Posts
    322
    Feedback Score
    -1 (0%)
    i could use an extra set of hands workin on her i apreciate the offer
Thread Information
Users Browsing this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201
