+ Reply to Thread
Results 1 to 1 of 1
  1. #1
    VTEChnician Jun_Tuning has a reputation beyond repute Jun_Tuning has a reputation beyond repute Jun_Tuning has a reputation beyond repute Jun_Tuning has a reputation beyond repute Jun_Tuning has a reputation beyond repute Jun_Tuning has a reputation beyond repute Jun_Tuning has a reputation beyond repute Jun_Tuning has a reputation beyond repute Jun_Tuning has a reputation beyond repute Jun_Tuning has a reputation beyond repute Jun_Tuning has a reputation beyond repute
    Join Date
    May 2005
    Location
    Bayshore NY, Kissimmee FL
    Posts
    1,892
    Feedback Score
    16 (100%)
    Performance Parts/ Head gaskets/ Complete Gasket sets Specials
    Honda Civic 92-00 Race Radiator w/ Fan & Shroud
    This is a 100% aluminum dual core lightweight radiator with aluminum end tanks w/ fan shroud kit. It can also accept aftermarket fans. It is designed to replace the OEM radiator for the 92-00 Honda Civic with manual transmissions only. A new radiator cap and drain plug are included.
    Dimensions:
    Total Size: 15.25" long x 18.5" high x 1.65" thick
    Inlet/outlet: 1.25"
    Core Size: 13.75" x 14"
    Aluminum Shroud with a 12" Performance Electric Fans
    Overall Size:Height - 14.1"
    Length - 16.6"
    Width - 2.5" (including fan)
    Performance:
    Flows 200% more coolant than the stock Honda OEM 5/8" thick radiator.
    Application:
    -Designed for use in any 1992 to 2000 Honda Civic
    -Direct OEM fit
    -Works with USDM or JDM engines
    Warranty : Lifetime warranty
    Price: $369.99
    Subaru WRX 01-07 Race Radiator w/ Fan & Shroud
    This is a 100% aluminum dual core lightweight radiator with aluminum end tanks w/ fan shroud kit. It can also accept aftermarket fans. It is designed to replace the OEM radiator for the Subaru WRX and STI from 2001-07. A new radiator cap and drain plug are included. All cores are polished to a mirror finish.
    Dimensions:
    Total Size: 28.4" long x 17.2 high x 4.45" thick
    Inlet/outlet: 1.25"
    Core Size: 13.54" x 27.24"
    Aluminum Shroud with two 12" Performance Electric Fans
    Height - 16.8"
    Length - 27.4"
    Width - 2.5" (including fans)
    Performance:
    Flows 200% more coolant than the stock Subaru OEM radiator.
    Application:
    -Designed for use in any Subaru WRX and STI from 2001-07.
    -Direct OEM fit
    Price: $369.99
    Scion TC 2005+ Race Radiator w/ Fan & Shroud
    This is a 100% aluminum dual core lightweight radiator with aluminum end tanks w/ fan shroud kit. It can also accept aftermarket fans. It is designed to replace the OEM radiator for the Scion TC 2005+. A new radiator cap and drain plug are included. All cores are polished to a mirror finish.
    Dimensions:
    Total Size: 30.5" long x 18.2" high x 3.7" thick
    Inlet/outlet: 1.35"
    Core Size: 23.62" x 16.06"
    Height - 16"
    Length - 26.3"
    Performance:
    Flows 200% more coolant than the stock Scion OEM radiator.
    Application:
    -Designed for use in any Scion TC 2005+.
    -Direct OEM fit
    Price: $369.99
    Mitsubishi Evo 7, 8, 9 01-07 Race Radiator w/ Fan & Shroud
    This is a 100% aluminum dual core lightweight radiator with aluminum end tanks w/ fan shroud kit. It can also accept aftermarket fans. It is designed to replace the OEM radiator for the Mitsubishi Evo 7, 8 and 9 (01-07). A new radiator cap and drain plug are included. All cores are polished to a mirror finish.
    Dimensions:
    Total Size: 28.2" long x 19.5" high x 2" thick
    Inlet/outlet: 1.25"
    Core Size: 14.76" x 27.08"
    Height - 16.8"
    Length - 27"
    Performance:
    Flows 200% more coolant than the stock Evo OEM radiator.
    Application:
    -Designed for use in any Mitsubishi Evo 7, 8, 9 (01-07)
    -Direct OEM fit
    Price: $369.99
    Honda/Acura Head Gasket
    Dimensions: Stock OEM size
    Performance: Stock OEM performance
    Application: Can be used for JDM or USDM models.
    For: D16/15, B16/18, H22
    Price: $45.99
    Complete Engine Gasket Sets
    engine gasket set for the Honda JDM B16A1 1.6L DOHC VTEC engine. Can also be used for the Acura Integra 1.8L GS-R B18C1 and Acura Integra 1.8L Type-R B18C5.
    NOTE: The intake manifold gasket will not fit the GS-R motor.
    Set includes: Cylinder head gasket, intake manifold gasket, exhaust manifold gasket, valve cover gasket, valve cover grommets/seals, cam seals, valve seals, injector O-rings, oil pan gasket, waterpump gasket, main crank seal.
    Weight: 2 lbs.
    Also Available for H22
    Price: $229.99
    Note: Prices listed above do not include state tax.
    HYBRIDWORKS
    Performance Inc.
    Repair shop / E-Tailer
    1-888-727-0568
    http://www.hybridworksperformance.net
    "TR Member Discounts Available"
    About Us
    TR "Old Skool EF" Crew - Member #126
    We Buy OBD1 Honda ECU's
    Non-VTEC:$20-up
    VTEC:$40-up
    ECU'S WE BUY: P28, P06, P72, P75
Thread Information
Users Browsing this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204
