+ Reply to Thread
Results 1 to 1 of 1
  1. #1
    VTEChnician Jun_Tuning has a reputation beyond repute Jun_Tuning has a reputation beyond repute Jun_Tuning has a reputation beyond repute Jun_Tuning has a reputation beyond repute Jun_Tuning has a reputation beyond repute Jun_Tuning has a reputation beyond repute Jun_Tuning has a reputation beyond repute Jun_Tuning has a reputation beyond repute Jun_Tuning has a reputation beyond repute Jun_Tuning has a reputation beyond repute Jun_Tuning has a reputation beyond repute
    Join Date
    May 2005
    Location
    Bayshore NY, Kissimmee FL
    Posts
    1,892
    Feedback Score
    16 (100%)
    Hytech Replica Headers *Combo Deal*
    $370.99 + Tax =$396.96 (Florida residents)
    $370.99 (Non-Florida Residents)
    FREE SHIPPING
    to the lower 48 States
    Hytech Replica Headers Retails at $300
    BlackWorks Racing 2.5" Test pipe Retails at $120
    Plus you get FREE SHIPPING
    BRAND NEW!
    VERSION 4 : 2009 REDESIGNED!
    Honda / Acura TDM Hytech Style 4-2-2-1 Tri-Y Header
    BRUSHED Stainless Steel
    Fits: All B Series Engines (Vtec & Non-Vtec)
    This new redesigned version of the popular Rage Style version features a new revised version of its CNC Flange, we had some problems with the old version cracking on shipments. Also the header has a Brushed Stainless Steel finish for a cleaner look and durability. Be sure to get this new version, many other sellers/stores are selling their old 2007-2008 inventory at a lower price but that’s up to you.
    Many Honda / Acura engine builders have used this type header since early 90’s for their All Motor (Naturally Aspirated) projects. On that time they were custom made by a company named Hytech and they were about $900-1200 and took 2-3 months to be built. Now on 2007 this design is finally available at a affordable price. This is their last design which is the BEST HEADER for A B Series to date. It will outperform ANY header in the same price range. DYNO & RACE PROVEN.
    It will fit ALL B-Series Engines Honda / Acura. All B16(A/B), B17A, B18(A/B/C1/C5) and B20(B/Z) Honda Engines.
    · 304 Stainless Steel
    · High Flow Tri-Y Merge Collector
    · Hand TIG weld
    · NEW! Redesigned LASER CUT CNC machined flange
    · High Flow True 2.5" merge collector
    · BRAND NEW IN RETAIL BOX
    · Best Ground Clearance
    · Long Tube Design (4-2-2-1)
    * FREE OEM type header gasket ($30 value)
    Common USDM Applications:
    90-93 Acura Integra GSR (B17A)
    90-93 Acura Integra RS / LS / GS (B18A)
    94-97 Honda Civic Del Sol Si (B16A)
    94-01 Acura Integra GSR (B18C1)
    94-01 Acura Integra RS / LS / GS / SE (B18B)
    96-01 Acura Integra Type R (B18C5)
    96-00 Honda Civic Type R (B16B)
    96-01 Honda CRV (B20B)
    89-01 Honda Civic Si (B16A)
    Header Specs:
    Primary Tubes = 42.3mm to 44.3mm to 47.8 mm 4-2 collector = 47.8mm 2-1 collector = 50.8mm Outlet = 65mm (2.5inch)
    NOTE: This header will work in all type of B series swapped cars. Older models (1993 and lower) will need the cross member to be modified. This will happen on these cars with all types of headers. Just cut out the part that doesn’t let you fit in the header. Does not fit with factory Type R transmission (motor brace) transmission brace can be swapped with GSR/LS/B20. (Modifications required by purchaser to fit properly)
    HYBRIDWORKS
    Performance Inc.
    Repair shop / E-Tailer
    1-888-727-0568
    http://www.hybridworksperformance.net
    "TR Member Discounts Available"
    About Us
    TR "Old Skool EF" Crew - Member #126
    We Buy OBD1 Honda ECU's
    Non-VTEC:$20-up
    VTEC:$40-up
    ECU'S WE BUY: P28, P06, P72, P75
Thread Information
Users Browsing this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204
