Lexus sc400 1jz-gte swap
Owner: CarltonThe owners plans for this car ( for now lol) is to make a nice streetable car than can whoop ass so let's do it!Starting out with a clean example of an sc: The new powerplant Auto 1jz-gte Some goodies Turbonetics ceramic bearing 60-1 turbocharger , Turbonetics 38mm wastegate, Turbonetics raptor bov. & Tubular turbo manifold: Brian crower 264 cams , Aem uego wideband, Aem tru-boost boost controller/gauge, Greddy boost cut controller, Greddy speed cut controller, Walbro 255 fuel pump: New, motor mounts , PCB valve & thermostat ....cheap insurance: BIG ASS B&M cooler for tranny ( this thing is no joke definitely recommend if using the stock auto or and high stall applications ) some not so cheap insurance : b&m actually makes this for Yale on one of there forklifts compared to basic cooler: Minty new map sensor : pn's for you guys And some exhaust goodies so we can fab up a one-off exhaust:Vibrant resonator, RS muffler, Flex pipe, mild steel tubing everything will be in 3" turbo back With the motor out we began swapping injectors out for some 440cc injectors and installing the cams: New injectors in ...onto cams New cams in
Hybrid Motorsports LLC.
9470 Ulmerton Rd.
Largo FL. 33773
Unit 3E
Ph. 727.753.9664
Shop Forum: https://www.tamparacing.com/forums/hybrid-motorsports/
9470 Ulmerton Rd.
Largo FL. 33773
Unit 3E
Ph. 727.753.9664
Thanks Noah. After seeing your project come together, I wish I could do more but Justin said it best "the plan for now". I think we are running almost identical turbos.
14.7 psi all day and night, like its my job.
We got the engine finished up and ready for installation: new motor mount , turbo line, cam/crank seals, thermostat etc. etc. etc.
converted over to v-band:
9470 Ulmerton Rd.
Largo FL. 33773
Unit 3E
Ph. 727.753.9664
9470 Ulmerton Rd.
Largo FL. 33773
Unit 3E
Ph. 727.753.9664
Then we removed the 1uz (v80) and pressure washed the engine bay to have a clean platform to start on:
Before wash:
Install the engine, modified fuel lines , Install fuel pump upgrade, 12v mod, wire harness extension /conversion, And began intercooler piping:
Before wash:
9470 Ulmerton Rd.
Largo FL. 33773
Unit 3E
Ph. 727.753.9664
9470 Ulmerton Rd.
Largo FL. 33773
Unit 3E
Ph. 727.753.9664
Finding a place to mount the monstrous tranny cooler wasn't easy we ended up making a bracket and installing it behind the intercooler:
9470 Ulmerton Rd.
Largo FL. 33773
Unit 3E
Ph. 727.753.9664
9470 Ulmerton Rd.
Largo FL. 33773
Unit 3E
Ph. 727.753.9664
This build looks so familiar. I just finished my swap about two months ago. How did you power the coils, ignitor, and the injectors? Did you run seperate wires, use relays, or sent the harness off to Dr.Tweak? Overall looks similar to what I did. Looks impressive. I am subscribed and to see if the cams really help!
ImPortZracingshop
For Sale/WTB Honda & Acura
04-19-2009 08:10 AM
