Chucky's Infinity G35 'Project Turbo'
Old 06-22-2010, 08:26 PM
Hybrid Motorsports's Avatar
Default Chucky's Infinity G35 'Project Turbo'
This car was sent down from Brooklyn, New York, For us to do a single turbo upgrade the car was previously superchagerd but the gain were minimal & and was low on the efficiency scale.
We're working with strict time constraints so let's get started!
Some goodies came in!
Hybrid Motorsports LLC.
9470 Ulmerton Rd.
Largo FL. 33773
Unit 3E
Ph. 727.753.9664
Shop Forum:
https://www.tamparacing.com/forums/hybrid-motorsports/
Old 06-23-2010, 03:54 AM
two_seven_two's Avatar
Yeah! I like the look of this project! Can't wait to see more.
Old 06-23-2010, 05:10 AM
NeKe1point0's Avatar
Lookin good J !
You shoulda sold him on a before and after dyno
Proven Power LLC
4505 N. 56th street
Tampa, FL 33610
813-988-DYNO(3966)
www.ProvenPowerTampa.com
Old 06-23-2010, 07:07 AM
bikeimports's Avatar
I know that was my idea, but he decided not to.
Old 06-23-2010, 03:59 PM
Default Update
Now We have the intercooler mounted we can run our piping, but first ; SOME MORE GOODIE CAME IN!
Garrett gt3582r T3:
The New Precision 46mm wastegate:
Kinetix SSV intake manifold:
Went ahead and did the fuel system:
Walbro 255 lph fuel pump was added:
fuel sending unit was modified & pump added:
New fuel damper line:
Siemen Deka 630cc injectors:
So we began removing the stock manifold:
After all of that, And finally being able to access the injector, out with the old, in with the new.
Then some new plugs while in there , a bit cooler on the heat range or at least hoped for.....
Onto installing the manifold!
9470 Ulmerton Rd.
Largo FL. 33773
Unit 3E
Ph. 727.753.9664
Shop Forum:
Old 06-23-2010, 04:12 PM
I have had sealing inssues installing those manifolds in the past. Hope you have better luck than us
What turbo/ex mani you guys gonna be using ?
Proven Power LLC
4505 N. 56th street
Tampa, FL 33610
813-988-DYNO(3966)
Old 06-23-2010, 08:21 PM
Thanks for the heads up. we'll pay close attention to that, were you using the ssv? i know they've made changes to them but i believe more towards the overall flow, which gasket were you guys using?
Single turbo, Turbonetics / custom crossover pipe / custom downpipe.
9470 Ulmerton Rd.
Largo FL. 33773
Unit 3E
Ph. 727.753.9664
Shop Forum:
Old 06-24-2010, 05:14 AM
Identical mani.
Its been months but im pretty sure we used supplied gasket set just a pita. Id just put a very light amount or rtv on both sides for cheap insurance.
Proven Power LLC
4505 N. 56th street
Tampa, FL 33610
813-988-DYNO(3966)
Old 06-25-2010, 11:09 AM
Default Update
Well back to the piping, It's a daunting challenge fitting 3" IC piping in this vehicle it's very tight & nissan used every square inch, so some things will need to be relocated.
9470 Ulmerton Rd.
Largo FL. 33773
Unit 3E
Ph. 727.753.9664
Shop Forum:
Old 06-28-2010, 02:43 PM
buildin' it
Empire's Avatar
neat stuff
