Chucky's Infinity G35 'Project Turbo'
Old 07-27-2010, 05:09 PM
  #21 (permalink)
randy!'s Avatar
fucking nice homie got to pass by the shop man long time (By the way love the fabrications...)
http://www.flickr.com/photos/elrandyspics/
FOR SALE 8" ALPHASONIK
http://www.tampaforums.com/forums/au...t-deal-342616/
WANT CUSTOM PIPING, EXHAUST, WELDING OR ANY OTHER PERFORMANCE ? CHECK THIS OUT !
https://www.tamparacing.com/forums/hy...brication.html
Old 07-27-2010, 05:20 PM
  #22 (permalink)
Photoshop Newb
Ninja Havoc's Avatar
How much would that IC-to-TB piping cost separately?
Old 07-27-2010, 09:30 PM
  #23 (permalink)
Hybrid Motorsports's Avatar
^ Pm sent
Hybrid Motorsports LLC.
9470 Ulmerton Rd.
Largo FL. 33773
Unit 3E
Ph. 727.753.9664
Shop Forum:
https://www.tamparacing.com/forums/hybrid-motorsports/
Old 08-29-2010, 06:41 PM
  #24 (permalink)
the_third_lobe's Avatar
how come you didnt use a same side intercooler to cut down on the length of the cold side pipe?
Old 09-02-2010, 09:35 PM
  #25 (permalink)
Absolutely no room to spare
9470 Ulmerton Rd.
Largo FL. 33773
Unit 3E
Ph. 727.753.9664
Shop Forum:
Old 09-16-2010, 09:05 AM
  #26 (permalink)
Frostdragon1's Avatar
Hey Justin its Aaron with the del sol. looked at your work and great stuff man im excited to send you my car and see what you can do with it im emailing you the list you wanted today too. thanks for you help and once again great stuff!!
Old 10-05-2010, 08:07 PM
  #27 (permalink)
Thanks Aaron!
9470 Ulmerton Rd.
Largo FL. 33773
Unit 3E
Ph. 727.753.9664
Shop Forum:
Old 10-05-2010, 09:30 PM
  #28 (permalink)
Default Update
Well it's been some time since the last update, been busy working on some shop related business.
So we'll pick up with getting the turbo manifold piping installed, 'this is no attempt to brand bash' however we have to be honest, this was suppose to be a turbonectics kit, however for some reason absolutely nothing fit. everything was modified, I'm not saying that if you order a turbonectics kit it won't fit just our luck.
Had all types of problems with the y-pipe not fitting, most of the problem was in the u-pipe being off: this is how much we modified it.
The up-pipe was off aswell, again you can see the modifcation.
Making of the custom crossover pipe:
Finished Custom made cross over pipe:
Everything all done & heat wrapped:
Up-pipe with wastegate:
Extra up-pipe brace added:
Up-pipe installed w/heat wrapped and finally fitting, new a/c line also installed pictured here:
Getting all the lines, fittings etc. together:
Turbo mounted, fittings/lines made & installed:
While all of this was going on, we decided to surprise the customer and give it a Hybrid touch, by painting his intercooler piping pearl white to match the vehicle:
(paint, base coat white, black hybrid motorsports decal, pearl clearcoat seal)
Maf bung welded in, not bolted like turbonetics ic piping kit, this was done to aid in eliminating possible leaks:
The piping is a very tight fit due to large size, so our blow off valve was left homeless in it's normal ic piping position & the fact that it was paint wanted to keep a clean look, So:
now that we have our turbo in place we did turbo-to-intercooler piping short & efficient (also 3")
9470 Ulmerton Rd.
Largo FL. 33773
Unit 3E
Ph. 727.753.9664
Shop Forum:
Old 10-05-2010, 09:37 PM
  #29 (permalink)
NeKe1point0's Avatar
Painted piping came out great !
now about that downpipe ?
Proven Power LLC
4505 N. 56th street
Tampa, FL 33610
813-988-DYNO(3966)
www.ProvenPowerTampa.com
Old 10-05-2010, 09:54 PM
  #30 (permalink)
Default Update
Wow! This was bye far the trickiest downpipe that i've built, Installs like a corkscrew, The turbonectics kit has a two-piece setup but wanted to keep cost down (with v-band sets going for $70 a pop) and so it won't have to be serviced i.e loosen up we decided to opt for with a one-piece configuration.
Heat wrapped:
Installed:
Then Moved onto the custom built mid-pipe with supporting brackets:
Installed, you can see the flex pipe, wideband senor bung, 2 stock bungs & transmission brace in this picture, going into stock exhaust right before the stock resonator.
Close up on tranny brace, Used 2 mounting points to reduce it from loosening on a pivot:
9470 Ulmerton Rd.
Largo FL. 33773
Unit 3E
Ph. 727.753.9664
Shop Forum:
