1996 Acura Intergra Overhaul.
Nothing spectacular, However worth posting because most people have the idea we only do performance or swaps....No.
We provide basic service and/or maintenance from A-Z no job too small..
Now, The customer came in with a blown head gasket, while in there we recommended to change as much as possible.
So we did, head gasket of course, water pump, timing belt, cam seals, valve cover gasket, intake manifold, valve stem seals, thermostat, coolant flush, oil change, etc. etc.
Sent the head out for warpage test.....good thing..... failed.
So milled the head, vacuum, pressure tested & cleaned
Head back from the machine shop:
All ready togo:
All ready togo:
Hybrid Motorsports LLC.
9470 Ulmerton Rd.
Largo FL. 33773
Unit 3E
Ph. 727.753.9664
Shop Forum: https://www.tamparacing.com/forums/hybrid-motorsports/
9470 Ulmerton Rd.
Largo FL. 33773
Unit 3E
Ph. 727.753.9664
