B18 into crv awd knock sensor and crank sensor
Ok so I put the motor in . its got a crazy miss . it fires right up but it has that miss. Will the knock sensor give it that bad of a miss? I did the crank sensor bypass to the ecu. (Oil pump) has no place for the crank sensor) block has no place for knock sensor. Obd1 engine block. . help plz
Rep is Returned
Acura
Rep is Returned
Acura
If you start pulling plug wires will that tell you where the miss is?
It will run bad with the wrong (non-missing) plug wire pulled,
but will not change with the wire pulled from the missing cylinder.
Scarface
For Sale/WTB Honda & Acura
12-19-2012 05:14 AM
hiboost
For Sale/WTB Nissan
02-19-2011 07:53 PM
TampaTraps
10-29-2005 10:14 PM
