tech question???
Old 01-26-2015, 05:28 PM
zcnitroso's Avatar
Default tech question???
do it safe to use oem valve with skunk2 dual springs, and why???
I miss tampa fl
Old 01-27-2015, 02:19 PM
I have no experience with Skunk2 dual springs.
I want to believe their engineers will have designed them properly.
Sometimes a company that makes valve springs will make the valves as part of a package installation.
You might try asking Skunk2 if their springs will work well with OEM valves.
If a person uses OEM valves, we know for sure that OEM springs will be the right height, etc
I have had good luck with Clearwater Cylinder head putting in valves and springs for stock engines.
You might ask their advice.
You might also research for valve spring installation articles from cam manufacturers.
I read a good one sometime back from Iskendarian Cams. Talking about spring height, blueprinting
for competition and other subjects.
What are the valves going into and what are your plans for the engine?
Old 01-31-2015, 01:27 PM
zcnitroso's Avatar
well running out of money but it have eagle rod, wiseco 11.1 piston, stage 3 cams and dual spring skunk2 with titanium retainers and the list go on!!!
I miss tampa fl
Old 01-31-2015, 10:42 PM
WOW! Sounds like you are building a pretty strong motor.
Old 02-01-2015, 10:13 AM
zcnitroso's Avatar
yea!! i guess wait a littler bit and buy the valve, better be safe than holly shit!!! thank for you input..
I miss tampa fl
Old 02-01-2015, 02:24 PM
Stop by Tampa Racing often. We have a lot of forums here. A lot of things to read.
Hundreds of people read our posts every night. Already 90 people read your posting.
You can also post pictures of your car on Tampa Racing under Members Rides.
https://www.tamparacing.com/forums/members-rides/
ProjectRedSuns
Mazda Tech
7
04-19-2004 11:00 AM
Cronic
09-03-2003 06:15 AM
813kr$
Mazda Tech
17
07-28-2003 09:03 AM
Sam@Coastal
01-19-2003 08:04 AM
Quick Reply: tech question???
