+ Reply to Thread
Results 1 to 5 of 5
Thread: 24.5x9x13 slck touching fender
01-23-2012 06:38 PM #1
my brother has a b18 turbo crx which had 22's before we upgraded to the 24.5 slicks. the inside clearance is ok but the fender sits on top of the tire. need some helpfull ideas to raise the car a little to clear the slicks. we rolled the fenders and it helped a bit but i'm worried about after a fast run and braking the fender will come down on the tires and thats not good at all!
thanks for your help guys!
01-23-2012 08:23 PM #2
Coilovers aren't only for lowering cars, ya know. =]
01-31-2012 11:46 AM #3
ya you would need to raise the car up no way around it might want to do the back to i have 24.5 and had to raise the coil over almost all the way up to clear good luck
02-29-2012 02:21 PM #4
thanks bro! sorry for the late reply..not on much plus busy with multiple projects!
03-21-2012 03:58 AM #5Installs & Fixes Anything
- Join Date
- May 2005
- Location
- around Tampa Florida, Paradise
- Posts
- 6,427
- Blog Entries
- 1
- Feedback Score
- 19 (100%)
So what solution did you find?
Fender flares?
With some cars you can take a second set of fenders, carefully measure
the fender opening profile and cut the profile out with some extra metal
around the opening. Take that section and position it above the normal fender lip by
the appropriate amount and weld/rivet it in place. Cut out the original metal,
do the body work/paint and it looks stock, but the opening is higher up.
Most people can't tell that you did it unless your car is beside an identical car.
and if you need help with this, call me when you get the second set of fenders.
I can do it all and then leave the body/paint up to you.-Bob---- on-site *Aftermarket* spring/suspension installations --- on-site impact wrenching---street lowering with your own stock springs...........
Much more at Bob's Garage!
http://www.tamparacing.com/forums/bo...ontact-us.html
Have a great day! bobfixesitup@yahoo.com 813-839-4281 (24 hrs)
Thread Information
Users Browsing this Thread
LinkBack URL
About LinkBacks
