OBD2A Harness to OBD1 Distributor HELP!!!!!!
Old 02-04-2011, 09:44 PM
My eBay>> Nthefastlane
stylnjj's Avatar
Default OBD2A Harness to OBD1 Distributor HELP!!!!!!
Ok I HAVE A 98 CIVIC EK "NOT" A 99-00!
I need a OBD2A harness to OBD1 distributor wire diagram..."A working one"
I used John Vegas (Pherable.net) Diagram and another one and the motors not even spitting! timing is perfect,fuel pumps priming,have fuel pressure,injectors work..I'm spent!
Droped a Gsr turbo in my ek in 3 hrs ..spent the last 3 days makign sure everything hooked up..multimetered the crap outta the car...Just got a working base map in my p28..the ecu does work..Ive use it numerous of times.I really thing its the wiring of the distributor.
Here is what I use so far..
http://i34.photobucket.com/albums/d1...altdizzy11.jpg
http://ff-squad.com/tech/wiring/obd1-2dizzywiring.jpg
Old 02-05-2011, 12:23 PM
stylnjj's Avatar
Ttt
Old 02-05-2011, 12:31 PM
Pops
BoostedRacerDad's Avatar
Wiring diagrams are indeed correct.
Jdm b18c R LSD CRX si
TR "Old Skool EF" Member #96
JoKie TuNinG
RANGCRX BUILT TYPE R
StricKlyMT
727-510-6301
Old 02-06-2011, 10:00 AM
stylnjj's Avatar
How can they both be right when there both total opposites?? Therese only one way to wirier up a dizzy correctly!
Old 02-06-2011, 10:04 AM
stylnjj's Avatar
Some one help!!!! I been stumped for the past 48hrs..My cars not movin help!!! Ive tried everything..first I wasn't gettin voltage to th dizzy so I jumped 12volts to the Black/yellow wire,now I got 12V on both neg and positive coil, but still no spark. Anyone!!!?? maybe the icm?? But why did i not have voltage on the black/yellow wire to begin with ?? Ignition switch faulty?
Old 02-06-2011, 12:05 PM
Pops
Again this is the correct way to wire this dizzy. Right from John Vega. I have used it many times. Your problem might be the coil,ICM, etc not the wiring.
http://www.phearable.net/tech/wiring...istributor.jpg
JoKie TuNinG
StricKlyMT
727-510-6301
Old 02-06-2011, 12:27 PM
Pops
No 12vdc from black and yellow to coil and ICM, car will NEVER start. Trace to ignition switch.
Use this troubleshooting guide.
Honda Acura ignition (no spark) troubleshooting tutorial - How to
JoKie TuNinG
StricKlyMT
727-510-6301
Old 02-06-2011, 03:59 PM
stylnjj's Avatar
Ok there no such "green" wire on a obd 1 ls distributor.....so where does the "green" wire go to on the obd1 distributor?? makes no sense!
Here is the wires I have, and how I currently have it wired up. The only two wires I have left over are Orange/Blue OBD1 & Green on the OBD2A end.
OBD1 OBD2A
ORANGE DARK BLUE
WHITE WHITE
ORANGE/BLUE GREEN
WHITE/BLUE RED
BLUE/GREEN YELLOW
BLUE/YELLOW BLACK
YELLOW/GREEN YELLOW/GREEN
BLACK/YELLOW BLACK/YELLOW
BLUE BLUE
Old 02-06-2011, 04:01 PM
stylnjj's Avatar
OBD1 to OBD2A
ORANGE to DARK BLUE
WHITE to WHITE
ORANGE/BLUE to GREEN
WHITE/BLUE to RED
BLUE/GREEN to YELLOW
BLUE/YELLOW to BLACK
YELLOW/GREEN to YELLOW/GREEN
BLACK/YELLOW to BLACK/YELLOW
BLUE to BLUE
Old 02-06-2011, 04:08 PM
stylnjj's Avatar
[ATTACH=CONFIG]147072[/ATTACH]
