Causes for injectors not spraying?
Page 1 of 2 12 LastLast
Results 1 to 15 of 17
  1. #1
    Registered Hater FoxHondaRider's Avatar
    Join Date
    Aug 2008
    Location
    North of Tampa, FL
    Posts
    3,247
    Feedback Score
    11 (100%)
    I have fuel to the rail, spark, compression, the motor cranks but it wont start. I am getting power to the injector connectors 12.5V on the one wire and 3.9V on the other. The injectors wont spray/open though. I kept cranking, checked everything, took a plug out to smell the cylinder for fuel and nothing. Pulled the rail off and cranked it nothing came out of the injectors. What causes them to not work? The ECU was perfectly fine last time it was running. I'm sensing thats the only fault that controls them unless SRS plays some dumb role thinking the car was in an accident and cuts signal?
    Quote Originally Posted by *JamReX* View Post
    The only thing worse than ****ing ricers, VW .... who think theyre style is somehow supreme to all others.
    Honda builds go from yay to gay in the matter of a K.
  2. #2
    Join Date
    Jan 2008
    Location
    Dade City, Florida
    Posts
    581
    Feedback Score
    7 (100%)
    Stupid question... fuel pressure? Was you gettin some?
    1999 Honda Civic Si
    1984 S10 355 small block drag truck
    1971 Toyota Pickup Converted 4x4
    TR em1 crew #43
  3. #3
    Join Date
    Aug 2008
    Location
    North of Tampa, FL
    Posts
    3,247
    Feedback Score
    11 (100%)
    Yep fuel pressure, fuel in the rail, spark to all but the 3rd cylinder now and everything else works in the car. I'm thinking either A: the ECU fried, B: ECU/Injector ground bad or C: cam sensor. I think one has to be the problem, maybe all IDK. No spark on 3rd cylinder also now, my cap and rotor are burnt a little. The reason I say cam position sensor is the motor needs either a crank or cam position and JDM motors have a cam not crank. It needs to know where everything is for the duty cycle to know which injector to open. The cam position sensor is located inside the distributor, maybe something fried hence the burnt cap and rotor and 3rd not sparking and maybe it burnt up the sensor? How should I check the ECU to make sure its grounded? Before I go buying a bunch of things I want to try and check everything to see exactly what needs to be replaced.
  4. #4
    turbo hhhmmmm?
    Join Date
    Jan 2004
    Location
    tampa
    Posts
    702
    Feedback Score
    14 (100%)
    check the magnets in the dizzy and the parts that hit the magnets to make sure they aren't broken. the dizzy controls injector pulse
    Steve: (813) 810.4146 <~ call or text
  5. #5
    Join Date
    Aug 2008
    Location
    North of Tampa, FL
    Posts
    3,247
    Feedback Score
    11 (100%)
    Quote Originally Posted by luvsracin87 View Post
    you sure? That would sound probable though and make sense the dizzy and injectors running together cause its the same cycle. ISIS didnt seem to show that. Maybe the whole dizzy is bad? IDK how but it seems like that could definately be the source of all the problems. A new one from Honda is a ridiculous amount of money! Maybe I'll call Steve at HMO Monday and see what he has in stock with low miles.
  6. #6
    Join Date
    Apr 2002
    Location
    Largo
    Posts
    507
    Feedback Score
    11 (100%)
    Did you not try a known good working ECU yet?
  7. #7
    Join Date
    Aug 2008
    Location
    North of Tampa, FL
    Posts
    3,247
    Feedback Score
    11 (100%)
    Quote Originally Posted by Vtec4theChildren View Post
    I don't have a spare P73.
  8. #8
    Join Date
    Apr 2002
    Location
    Largo
    Posts
    507
    Feedback Score
    11 (100%)
    Time to start looking for one or asking nicely if someone wouldn't mind swapping ecus so you can see if your car fires up.
  9. #9
    Porno Music Producer zhillz's Avatar
    Join Date
    Jan 2006
    Posts
    8,523
    Feedback Score
    14 (100%)
    Dude your gunna jizz in your pants when you finally get this thing running lol.
  10. #10
    Join Date
    Aug 2008
    Location
    North of Tampa, FL
    Posts
    3,247
    Feedback Score
    11 (100%)
    Quote Originally Posted by zhillz View Post
    LMAO I know. I call my build the mystery machine, in my old car everything worked. I put the motor in my new car and I have a shit ton of problems lol
  11. #11
    OH LAWD JESUS ITS A FIRE! K20A2's Avatar
    Join Date
    Aug 2006
    Location
    VTAKistan™
    Posts
    13,982
    Feedback Score
    5 (100%)
    Thermostat ground? Is the ECU getting power?
    -Winston Churchill
  12. #12
    Join Date
    Aug 2008
    Location
    North of Tampa, FL
    Posts
    3,247
    Feedback Score
    11 (100%)
    Quote Originally Posted by K20A2 View Post
    I checked it so many times lol yeah the thermostat ground is connected. If the ECU wasnt getting power wouldnt that mean nothing would work in the car?
  13. #13
    Choir boy Bad1flip's Avatar
    Join Date
    Apr 2010
    Location
    Miami
    Posts
    Feedback Score
    blast it with piss
  14. #14
    90% grind 10% sleep integra's Avatar
    Join Date
    Nov 2002
    Location
    clearwater/wick city
    Posts
    6,963
    Feedback Score
    35 (100%)
    dizzy
    727-510-6301
    Honda Valve Adjustments 50$
    I TUNE KPRO AND S300
    I DO NOT WORK FOR FREE
    Quote Originally Posted by THE_ONE View Post
  15. #15
    Every dog has his day. HonkeyDong's Avatar
    Join Date
    Jun 2007
    Posts
    3,812
    Feedback Score
    13 (100%)
    ^+1 **** distributors
    Mattbuilt
    AEM | Mugen | Skunk2 | Hasport | Hondata | Koni |Ground Control |
Thread Information
Users Browsing this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
